The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 02-25-2006, 12:03 AM   #1
gameboy's CarPC Specs
gameboy's Avatar
Vehicle: 2003 Nissan Altima 2.5S
My Photos: (0)
Angry dsatx issue
ok, my system has been working fine now for quite some time (since christmas)
got a msi mobo, 2800 semperon(on board video), 3 usb periferals(touchscreen, gps mouse, sound blaster audigy), sound blaster audigy nx powered by dsatx also, in addition to 1 40gb harddrive. that's all thats powered from the dsatx.
now the system will not boot at all, no LED activity.
i've checked all fuses, they are all fine(even the little 20 amp one on the dsatx)
i've plugged the mobo in inside the house to a "normal" power supply, boots fine.
i've checked voltage levels, and made sure acc is still working fine(all voltages are with the car running and are averaging 13.5 volts)
i've unhooked the powerswitch jumper, reversed it, jumpered the mobo manualy.
nothing, will absolutly not work at all.
(oh, yeah, i'm running 2 awg wire from the battery to a distro block in the trunk were the dsatx gets a 8ga wire, along with my 2 amps)
like i said, it has been working with no problems from the dsatx since around christmas. it worked in the morning on my way to work, but on the way home, it would not power up.
it is mounted in a clear lexan case, using tapped holes and mobo standoffs, has a 80 mm fan right above it.
anyhelp would be apreciated.
95 Mazda Protege LX
Worklog
Overall [Project Dead] 0%
2003 Nissan Altima
[XXXXXXXX--] 80% Planning
[XX--------] 20% FABRICATION/INSTALLATION
Worklog
gameboy is offline   Reply With Quote
Sponsored Links
Old 02-25-2006, 01:19 AM   #2
Vehicle: 04/Acura/TL/6MT
My Photos: (0)
You might need a firmware update.. I'll PM you..
Another thing you can try is hiting the reset. VERY CAREFULLY put a jumper on pins A2 and B2, then take it back off.
MPEGBOX - Plexiglass Computer
www.mpegbox.com
zootjeff is offline   Reply With Quote
Old 02-25-2006, 04:12 PM   #3
gameboy's Avatar
My Photos: (0)
i'll try this RIGHT NOW....
i've jumpered it, and still nothing,
i've answered your pm
thanks zootjeff, i wish more product manufactors i deal with were like you. most of them are a headache.
95 Mazda Protege LX
Worklog
2003 Nissan Altima
Worklog
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
DSATX Power Supply on LV-673 MoBo Caelric Power Supplies 59 12-17-2007 03:21 PM
DSATX and PCI Sound speedjunkie Power Supplies 17 01-24-2007 03:45 PM
My DSATX 220w experience tj!2k4 Power Supplies 8 11-16-2006 08:47 PM
DSATX Issue - shuts off unexpectedly - LED remains blinking 4x mmdb Power Supplies 3 11-19-2005 08:23 PM
DSATX not powering up alti Power Supplies 12 10-30-2005 11:37 AM
Sponsored Links
Ad Management by RedTyger
