Old 03-01-2006, 02:59 PM   #1
dfk70's Avatar
dfk70 is on a distinguished road
Convert an ATX power supply to workbench power supply
Here's a link: Power Supply
I've done it and it works pretty good.
2003 F-150 Harley Davidson Edition
"The horse is here to stay, but the automobile is only a novelty - a fad." --- Marshall Ferdinand Foch, French military strategist, 1911
dfk70 is offline   Reply With Quote
Old 03-01-2006, 03:12 PM   #2
cpjolicoeur's Avatar
cpjolicoeur is on a distinguished road
thanks for the link
STATUS: Planning / In Progress / Completed
COMPLETE: [*********] 100%
CAR: '02 Mitsubishi Lancer OZ Rally
SYSTEM: EPIA M10000
GPS: HaiCOMM 303e GPS, Routis 2004
DISPLAY: 7" Xenarc 700TSV
POWER: OPUS PW-70a + ITPS Combo
MISC: DVD, WLAN
cpjolicoeur is offline   Reply With Quote
Old 03-05-2006, 08:04 PM   #3
Simbo is on a distinguished road
It'll work, But It's not safe!
Simbo is offline   Reply With Quote
Old 03-06-2006, 01:39 PM   #4
dfk70's Avatar
I'm curious as to what isn't safe about it? Can you elaborate?
Old 03-06-2006, 03:17 PM   #5
PC power supplies are intended for use in a PC, which has a case connected to mains earth. If you dig out a schematic for pretty much any PC PSU, you will find that the mains isolation is not fantastic. If the switching FETs go short due to an over load, the ouput can become line voltage, and the only protection is a few diodes to crowbar the output and blow the mains fuse.
I've seen the effect this can have on a pc mobo, I'd hate to think a person might be on the recieving end!! (I know, I've been electrocuted more than once)
The other consideration is the current available. 5volts at 30-40 amps is almost enough for arc welding!!
Another point is don't load across the supply rails eg: -12v to +12 to get 24v, these power supplies are not designed for this and will lose regulation and may fail.
If you do decide to build such a power supply, use fuses on the outputs, make sure it's earthed and connect 0v (the black wires) to mains earth inside the PSU.
Linear power supplies (ones with transformers in) are much safer for experimenting, and fully isolate from the mains line.
I bought a 30 amp bench power supply from a local surplus outlet for £15.
I hope this helps.
Just thought i'd add this note while i'm thinking about it: brick type switchmode PSU's (laptop style) are just as bad, even though they look nicer.
ATX power supply question dudah85 Power Supplies 3 10-10-2006 05:49 PM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 01:13 PM
Very Small/Mini Power ATX Power Supply? xBrady Power Supplies 10 06-20-2004 07:22 PM
ATX, ITX DC-DC Power Supply Navigator_82 Power Supplies 4 03-14-2004 11:26 AM
What are the ATX DC to DC power supply options? Squeezer Power Supplies 6 07-08-2002 05:25 PM
