Old 03-05-2006, 04:22 PM   #1
temposs is on a distinguished road
Ground Loop Isolate - Good Results!
My cpu system is a Gigabyte MATX board running a Sempron 2600+, 512mb ram, Lilli 629 molded into my dash, 220watt atx PSU, and a 700 watt (400rms) Vector Inverter with the Mpegbox Startup/Shutdown controller. I am using onboard sound/video from the mobo. I am totally headunitless now, going from the CarPC to my amps to my speakers/subs. I had initially been getting a fairly bad hiss (especially from the subs), which I suspected was a ground loop.
So I bought the ground loop isolator from Radioshack for 15.99. It solved about 95% of my sound hissing/popping. The subs have absolutely no hiss/buzz at all anymore, and the front componets have only a tiny bit at high levels. Just wanted to put it up here that this thing, in some cases, actually works and makes a dramatic difference. I think I'll be holding off on buying an M2-ATX now until they get all the bugs out of it.
temposs is offline   Reply With Quote
Old 03-05-2006, 04:34 PM   #2
PCModifiers's Avatar
PCModifiers is on a distinguished road
I will keep that info in mind when I go to install my setup. Thanks for the great info!
I love what Radio Shack puts in the description of the item: Be the only one humming to the music.
PCModifiers is offline   Reply With Quote
Old 03-05-2006, 10:47 PM   #3
Perrosky's Avatar
Perrosky is on a distinguished road
Ok.
Well I'm looking for a lower configuration that the one that I use to have
something like an amd athlon xp 1900+ that cpu does not draw more than 55w at max. but I can't find that procesor on the internet .
anyone got a place where I can find it? or another idea o configuration??
if some one wants to talk to me by msn messenger here is my addres
p-santiagojr@hotmail.com
thanks
Perrosky is offline   Reply With Quote
ground loop isolators work! nealric Car Audio 1 02-23-2006 08:40 PM
Finding good ground to prevent Ground Loop lookinco Power Supplies 27 11-04-2004 02:23 PM
Learn and fix ground loop noise 14.4vTech Car Audio 3 07-03-2004 09:55 PM
Question: Arise psu: ground, neg, and pos.....? Tony S Power Supplies 2 05-02-2001 08:54 AM
Alpine / PC Challenges all around... acitrano General Hardware Discussion 5 11-10-2000 08:45 AM
