The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 03-20-2006, 07:56 AM   #1
My Photos: (0)
Mini-ITX Vehicle PC Case w/ built in 120w power supply question
i have the SP13k, a 100gig laptop hdd, 512 of RAM, a wireless NIC and a bunch of USB devices all connected to my 120w vehicle psu that came with the Mini-ITX Vehicle PC Case w/ built in 120w power supply. Obviously, i run less than 120w. I am using a 400w atx psu as a bench tester untill i get my car (wednesday, march 22nd.)
So here is my problem:
The only way i can start my motherboard is by using a power switch that i took out of an old atx computer (same thing as the start-up and shut-down power button that you can buy off the mp3car.com store. If i connect the power switch wire from the PSU it will give me the 2 blinks of green, indicating a boot-up failure, regardless of which way the pins are connected to pins 6 and 8 on the f-panel. If the case is together, the pins for selecting voltage is showing, as there is a slot to change the jumpers.
What i basically need to know is where is pin 1 when it is in the case? I have tried just about every jumper configuration there is, and i still receive this 2 blink indication when i connect the acc-on wire to the +12v.
now, does it absolutely need to be connected to a car battery to even use this feature of the psu? do i need to connect some type of fuse to bench test it? anybody have this problem?
via epia sp13000 mobo
512mb ddr ultra slim ram
100 gig hdd
mp3car in-dash TS
much more to come!
shocker1185 is offline   Reply With Quote
Sponsored Links
Old 03-20-2006, 09:28 AM   #2
srcstc's Avatar
Vehicle: 00 BMW 323Ci
My Photos: (0)
I have the same case and what I did when I had it out of the car is connect the yellow and black wires to my power supply, wait for the blinking light, then connect the Acc. wire to the yellow wires.
-Rich
srcstc is offline   Reply With Quote
Old 03-20-2006, 09:51 AM   #3
My Photos: (0)
yeh thats what ive been trying. what is your jumper setup on J1? i was reading the manual yet again, and i guess i need to put one on pin 3 to activate the accessory on as a power switch...
could you possibly take a picture of your jumpers?
100 gig hdd
mp3car in-dash TS
much more to come!
Old 03-20-2006, 10:19 AM   #4
srcstc's Avatar
My Photos: (0)
do you mean JU1?
Old 03-21-2006, 07:00 AM   #5
My Photos: (0)
yes, ju1.
i figured it out. i needed to jump pin 3 on ju1 to turn on standby on or something liek that, and then on j6(i think), the jumper setting, not the auxilary out, i needed to set a jumper on that and then it booted up fine, yeah.
100 gig hdd
mp3car in-dash TS
much more to come!
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
ATX power supply question dudah85 Power Supplies 3 10-10-2006 04:49 PM
VIA and Mini-box Announce First Sub-$300 Car PC Kit Goofus General Hardware Discussion 27 03-13-2006 11:28 AM
Pc Mini fungke General Hardware Discussion 7 06-02-2005 04:43 PM
ATX, ITX DC-DC Power Supply Navigator_82 Power Supplies 4 03-14-2004 10:26 AM
power supply question perlmax90 General Hardware Discussion 0 12-07-2000 11:16 PM
Sponsored Links
Ad Management by RedTyger
