The MP3car.com Store
Thread Tools Display Modes
Old 04-25-2006, 04:05 AM   #1
Tim Lake's CarPC Specs
Tim Lake's Avatar
Vehicle: 1999 Nissan Primera
My Photos: (0)
Question External DVD stops the PC booting
I had a problem that my PC would freeze right at the memory check stage (before it even starts booting the OS).
After several troubleshooting efforts I unplugged the DVD and immediately the machine unfroze and booted normally.
My question is, could this be caused by too much power being drawn from USB as I have several devices (GPS, wifi, bluetooth, keyboard, mouse) all drawing power from the USB ports and the DVD is doing so too.
If I power the DVD externally (direct from the car) will it solve the problem?
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Bluetooth, 802.11g, GPS
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
NLited XP with Road Runner and MapMonkey
Tim Lake is offline   Reply With Quote
Sponsored Links
Old 04-25-2006, 04:26 AM   #2
madkad's CarPC Specs
madkad's Avatar
Vehicle: Ford Fiesta Zetec-s
My Photos: (0)
does it have a cd in and have you got the bios to check for the usb on load etc etc
Car Computer 98%[|||||||||-]
Install Plan 100%[||||||||||]
Styling 20%[||--------]
Install 0%[----------]
My Car Computer Before The Crash | Car Computer Forum |Dust overheating pc, AMAZING |
madkad is offline   Reply With Quote
Old 04-25-2006, 04:46 AM   #3
Tim Lake's Avatar
My Photos: (0)
It had a DVD movie in which I took out but it still caused the issue. I haven't checked the BIOS setting but it was working for months and I haven't changed anything in the BIOS since then.
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
Old 04-26-2006, 09:56 AM   #4
Tim Lake's Avatar
My Photos: (0)
bump
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
Old 04-26-2006, 10:14 AM   #5
ZtH01's CarPC Specs
ZtH01's Avatar
Vehicle: 99 Saturn SC2
My Photos: (0)
Most likely not. Mine did that randomly. Sometimes it was good for a week, sometimes it happened 5 times a day. Sometimes it would freeze at the BIOS, sometimes it would freeze at about half through resuming XP. I ended up putting a switch on the power line so I could cut power to the DVD without having to unplug it.
I had an external 2 amp 6v regulator for it too, and it still did it. It was rock solid once you got into Windows though...
I ended up getting sick of it, and switched to firewire. Haven't had a problem since. And i got to ditch the 6v regulator, as the firewire port powers it just fine. Luckily both my VIA board, and external enclosure had firewire ports, does yours?
-ZtH01
ZtH01 is offline   Reply With Quote
Old 04-28-2006, 07:24 AM   #6
Tim Lake's Avatar
My Photos: (0)
Yes it does. Perhaps that's the way to go then. How can I find out if the DVD is compatible (I bought it off ebay and it was just taken out of a dud machine so not too much documentation!)
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
Old 04-28-2006, 07:34 AM   #7
WarDriver's Avatar
Vehicle: 4Runner
My Photos: (1)
It has more to do with your external case than the drive.The drive just has an IDE to usb/firewire adapter. So, if you do have firewire you should be fine.
-WarDriver-
Real Men Pay With CA$H
My DC to AC Inverter Mod
My Laptop Remote Switch
WarDriver is offline   Reply With Quote
Old 04-28-2006, 07:51 AM   #8
ZtH01's CarPC Specs
ZtH01's Avatar
My Photos: (0)
If the enclosure has firewire, and your motherboard has firewire, use firewire. And get your cables from Ebay... Local places wanted like $35-40 for a 15' 6pin to 6pin. Got one off of Ebay for $8 out the door...
-ZtH01
Old 04-28-2006, 05:46 PM   #9
nameeri's Avatar
Vehicle: 2003 Honda Civic
My Photos: (1)
My external USB drives was also causing my system to hang during boot and waking from hibernation. i found out that it wasnt the USB, it was becuase the drive was mounted vertically. I have a slot loading slim dvd drive, and apparently it doesnt like being mounted vertically. After I unplugged it, it works fine.
Civiputer: Dont have one anymore, but here is what is used to be!
nameeri is offline   Reply With Quote
Old 04-28-2006, 08:19 PM   #10
ZtH01's CarPC Specs
ZtH01's Avatar
My Photos: (0)
Wierd. So it works fine if it was horizontal? Mine's always been mounted horizontally, so I know that wasn't it.
-ZtH01
Sponsored Links
Old 04-28-2006, 08:24 PM   #11
nameeri's Avatar
My Photos: (1)
Yeah, it works fine when its plugged in and sitting horizontal. I know, its the strangest thing. The drive would always spin up, and the light would blink on it but it wouldnt do anything. There was no disc in there. This would cause the computer to hang. Once i unplugged the drive, it would continue to boot. If the drive was sitting horizontal, it booted and resumed from hibernation perfectly everytime.
Old 04-29-2006, 09:39 AM   #12
My Photos: (0)
I had this same problem w/ freezing the loading... and it was sometimes intermittent just like you guys. I had it runnin fine after I changed something in the BIOS, and then a lil while later it started doing it again. Only solution was to unplug the USB connection.
I'll look into firewire and see if my laptop has a port for it...
Cube is offline   Reply With Quote
Old 05-10-2006, 05:08 AM   #13
Tim Lake's Avatar
My Photos: (0)
Anyone know where I can get a Firewire enclosure for a laptop dvd drive (preferably UK)?
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
Old 05-10-2006, 07:30 AM   #14
WarDriver's Avatar
Vehicle: 4Runner
My Photos: (1)
Does it have to be for a laptop drive? I know desktop external firewire drives are easy (an inexpensive) to find. But otherwise check this link on eBay.
-WarDriver-
Old 05-10-2006, 07:44 AM   #15
Tim Lake's Avatar
My Photos: (0)
It does matter really. I have a slot loading dvd/cdrw which I'd want to use so I don't want to pay out foir another drive
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
Sponsored Links
vB code is On
Trackbacks are Off
Static When Computer Booting - External Soundblaster snoe MacCar 3 03-23-2006 04:25 PM
DVD plays few secs then stops and error cjjacquez Mobile Impact 1 10-19-2005 05:44 PM
using dvd indash touchscreen for pc morgan06 Input Devices 11 02-19-2005 02:09 PM
PC not booting (or doing anything) mkkbb General Hardware Discussion 5 04-14-2002 06:13 PM
Million $ Questiosn: HD screw size and wahz a good PC DVD player? Tony S General Hardware Discussion 14 05-05-2001 01:31 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
