The MP3car.com Store
Thread Tools Display Modes
Old 07-04-2006, 01:57 AM   #1
My Photos: (0)
Lilliput TC1000 12V Power Cable
G'day All,
Am new to this forum so hopefully I've come to the right place!
I have a Lilliput TC1000 and the 12V Power Cable that came with it is 5 core however the colour of the wires don't match up with whats in the user manual.
Here's a picture of the cable...
This is what the user manual says each one is for;
- red one to +ve power
- black one to -ve power
- white one to automobile electric control lock (ignition I assume?)
- blue one to ground
Now first of all they have only listed four.
Second there is no white or blue lead.
So which one goes to which???
I'm guessing that the red and black ones where there is only 2 pins on the top row is the +ve/-ve to the battery, but the other 3 pins I don't know which is which.
Any ideas??
Cheers,
Paul.
Paul75 is offline   Reply With Quote
Sponsored Links
Old 07-04-2006, 09:48 AM   #2
Vehicle: vw passat
My Photos: (0)
looks like the 2 black are grounds
the 2 reds are live
and the brown is acc from your car
turner brown is offline   Reply With Quote
Old 07-06-2006, 01:14 AM   #3
soundoff's Avatar
Vehicle: Lifted 1991 Subaru Liberty 4WD
My Photos: (0)
same guess as me
anyone actually own one and has wired it up? Its jsut a VIA TC1000 mainboard
soundoff is offline   Reply With Quote
Old 07-06-2006, 02:22 AM   #4
My Photos: (0)
Why would they have 2 wires for power though?
Old 07-06-2006, 02:33 AM   #5
OmegaAvenger's Avatar
Vehicle: 1998 Ford Mustang v6
My Photos: (0)
Look at the ATX plug for a motherboard, it has multiple wires for each voltage. Its primarily to cut costs I believe. You spead the current across multiple smaller wires instead of one large wire. That or it may be two idependent circuits powered from the same plug
OmegaAvenger is offline   Reply With Quote
Old 09-14-2006, 05:34 AM   #6
Gamer64's CarPC Specs
Gamer64's Avatar
Vehicle: 1998/Opel/Omega 2.5L V6 24V
My Photos: (1)
The other 2 (red and black) are outputs. At least, that`s where i used them for.
Gamer64 is offline   Reply With Quote
Old 09-14-2006, 09:38 PM   #7
My Photos: (0)
Gamer64,
What did you use these for? Output to what?
Cheers,
Old 09-15-2006, 03:07 AM   #8
Gamer64's Avatar
My Photos: (1)
I don`t remember exectlay what i hooked up to them. But you could hook up your monitor to them. If u want constant 12v on it.
Old 05-09-2008, 05:42 AM   #9
locutusmouse's CarPC Specs
locutusmouse's Avatar
Vehicle: Renault Laguna Sports Tourer
My Photos: (0)
Hi Guys
Same problem as Paul75. My power lead has 6 wires - 2 yellow, 2 black, 1 green & 1 red. Pin 1 is green, pin 2 is black, pin 3 is yellow. The red is above the green and black above black, yellow above yellow. Any ideas?
locutusmouse is offline   Reply With Quote
Old 06-14-2008, 05:07 AM   #10
My Photos: (0)
I e-mailed Lilliput and they sent over a new manual which has the six wire power lead. The following picture makes a lot more sense. The green one I have also put to ground that way, as you will know, it works while driving (the whole point of our hobby) if not it will only work when the handbrake is applied
I trust everyone, it's the devil inside them I don't! [img width=17 height=18]http://planetsmilies.net/vicious-smiley-1772.gif[/img]
Sponsored Links
vB code is On
Trackbacks are Off
Auto Power On 619 Lilliput - Programing Guide Anointed LCD/Display 132 02-15-2008 04:27 PM
Lilliput red light.. not getting power all of a sudden 700mx6 LCD/Display 13 09-19-2005 12:02 PM
A different way to Auto – Power – On your lilliput intense LCD/Display 32 05-05-2005 10:49 AM
12V line power requirements rushnrockt Power Supplies 11 03-08-2005 01:02 AM
Xenarc - USB Power cable? Coeus Power Supplies 4 01-13-2005 08:07 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
