Old 07-24-2006, 11:24 AM   #1
gianler's Avatar
Question Powering external DVD
Hello boys (and girls, I hope ) this is my first post.. so my greeting to everybody.. I believe this is the most complete forum in the world I read it from several months! I'm an italian boy ( world fifa champions ) and I begin with my first request for help:
I ordered (not yet delivered) this slim and slot-in DVD LITEON SLW-831SX ( http://www.newegg.com/Product/Produc...MP=OTC-yah00TT ). This has USB connection to PC but a little flaw : external power.
How can I power this item? I believe it's 5v.. was someone able to give it power through USB?
Thank you
gianler is offline   Reply With Quote
Advertisement Sponsored links
Old 07-24-2006, 11:41 AM   #2
_
you will need to power it via the external power line. Since it's 5v you can power it off of the 5v rail on the PSU.
Which PSU are you going with?
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 07-24-2006, 11:53 AM   #3
gianler's Avatar
If you see from this pic http://www.newegg.com/Product/ShowIm...1SX+%2D+Retail there is a 110/220 power adapter with jack. Is there any cable-adaptor USB-jack?
It has a very little consumption ( http://www.cdfreaks.com/article/271/8 )
0W on mode and 9W in operation mode..
Old 07-24-2006, 11:55 AM   #4
gianler's Avatar
No.. I haven't inverter, i would like to power it off of the 5v..
Old 07-24-2006, 12:00 PM   #5
_
I'm not understanding your second post. What are you trying to tell me?
I'm telling you that you can power (and need to power) that drive off of the 5v rail on your power supply for your carPC.
Jan Bennett
Old 07-24-2006, 12:15 PM   #6
gianler's Avatar
this is the rear of DVD
how can I power the drive off of the 5v rail on my power supply for my carPC?
MyCarPC:
Monitor: Lilliput 7" Touchscreen Vga+comp
MoBo: Epia Nano n10000
RAM: 1024Mb
PSU: M2-ATX
STORAGE: HD 80Gb 2,5"
GPS: Holux USB
Ampli: self-made 25Wx4
FM Tuner: SiLabs USB FM Tuner
Old 07-24-2006, 12:23 PM   #7
_
the same way you would power anything else.
Cut the wall wart off of the end of the plug that goes to the wall, tap those wires into the wires on the PSU for the 5v line.
I'd really suggest you do a LOT more research before you go much further into this:
start off here:http://www.mp3car.com/vbulletin/newbie/78795-new-carpcs-dont-know-where-start.html
Then here: http://www.mp3car.com/vbulletin/faq-emporium/51489-attention-newbies-faq-faqs.html
Jan Bennett
Old 07-24-2006, 12:31 PM   #8
gianler's Avatar
start off here:http://www.mp3car.com/vbulletin/showthread.php?t=78795
Then here: http://www.mp3car.com/vbulletin/showthread.php?t=51489
I searched but all complicated.. thank you
MyCarPC:
RAM: 1024Mb
PSU: M2-ATX
GPS: Holux USB
Old 07-24-2006, 12:34 PM   #9
_
no problem.
however, I will warn you up front that this is a complicated hobby. It requires a lot of research and a lot of trial and error. Use this forum to help you with all of that and things should be a lot easier for you.
Good luck!
Jan Bennett
Old 07-25-2006, 02:32 AM   #10
gianler's Avatar
no problem.
Good luck!
The hobby is not complicated for me, the carpc works fine.. it's complicated to search the answer: if you try to search what I need, tell me if you find it
MyCarPC:
RAM: 1024Mb
PSU: M2-ATX
GPS: Holux USB
Old 07-27-2006, 03:59 AM   #11
gianler's Avatar
did someone make an usb+jack (DVD) to usb cable? Thank you
MyCarPC:
RAM: 1024Mb
PSU: M2-ATX
GPS: Holux USB
Old 07-27-2006, 06:56 AM   #12
_
not that i've seen.
not sure you would want it anyways.
Power next to signal on that level would probably interfere with the signal.
Jan Bennett
Old 07-27-2006, 07:09 AM   #13
gianler's Avatar
..sure, separate. jack to usb for power it. usb connecion has already the cable. I heard that the slim DVD works w/o external power from desktop PC or laptop, so I believe that it doesn't work for poor amperage (?! understand, I don't know it's the right term). In the M2-atx there are the 20pin connector (for the MoBo) and 4pin connectors (is it only 12V?). Thank you
MyCarPC:
RAM: 1024Mb
PSU: M2-ATX
GPS: Holux USB
Old 07-27-2006, 09:33 AM   #14
_
ok - I think your english is creating a few problems on my end.
The DVD drives don't work without a seperate power sourse. They can't get enough power down the USB line. something like 100 milliamps is all that can travel down the USB power line.
If you try and run much more power down the USB line, you're going to run into noise issues. Where you are going to be causing interference with the signal wire.
On the M2 - the 4 pin wire is a 12v power connection. For the P4s.
Jan Bennett
Old 07-27-2006, 09:43 AM   #15
gianler's Avatar
so, I believe to take the red wire (5v) from 20p Mobo and I can power the dvd.. exact?
MyCarPC:
RAM: 1024Mb
PSU: M2-ATX
GPS: Holux USB
Slim DVD & IDE to USB - DVD QLTY ZimZimmer Newbie 21 01-19-2007 05:37 PM
SERIOUS Problems! w/ Panasonic Slot DVD in external enclosure iamConceyted General Hardware Discussion 30 08-13-2006 04:12 AM
Powering a slim DVD Cris General Hardware Discussion 1 03-21-2005 12:20 PM
Powering the Panasonic DVD without an enclosure muldrick General Hardware Discussion 8 03-09-2005 08:58 AM
FS: External Slim Line DVD burner for sale! EsKALad Classified Archive 6 02-06-2005 07:48 PM
