Old 08-01-2006, 05:33 PM   #1
pardoe16V is on a distinguished road
opus 150 stupid???
is my opus stupid??? my GPS is always on and my CD drive even though my iginition is off, after a few days this is draining my battery, is my opus stupid? or is this normal? or is there a jumper i can change a setting?
all fitted but its having a wobler!
pardoe16V is offline   Reply With Quote
Old 08-01-2006, 06:15 PM   #2
v8 scimitar's Avatar
v8 scimitar is on a distinguished road
its normal the opus doesnt shut down the 5v line. Have a search and you will find a design to put a relay and some diods on the power supply that will cure this. I think you can send it back to opus and they can change the firmware that will shut the 5v down too.
v8 scimitar is offline   Reply With Quote
Old 08-01-2006, 06:39 PM   #3
albysure's Avatar
albysure
try this
98% complete. Couple of tweaks to the fabrication.
http://www.cardomain.com/ride/212327/14
albysure is offline   Reply With Quote
Old 08-01-2006, 06:45 PM   #4
Tainted Love
Cris's Avatar
Cris is on a distinguished road
Subscribing...as this used to happend to me sometimes.
Cris is offline   Reply With Quote
Old 08-01-2006, 07:25 PM   #5
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
same here. what's the diagram mean? sorry, I'm electrical-schematically challenged..
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 08-02-2006, 11:55 AM   #6
the bit between the opus and the computer is the circuit you make. Its a relay and 3 diods. So long as the mobo is getting 12v the relay is closed and the sytem gets 5v. When the opus shuts the 12v down the relay drops out and the 5v line is cut. When you put your ignition on (ACC) the relay sees 12v again and closes the circuit reconecting the 5v as well as the opus switches the power on so it all boots up.
So from a cold boot you get
ACC on relay closes and power supply boots everything up.
ACC off (you switch the ignition off) Relay stops seeing the ACC but still gets 12v from the opus, the opus stops seeing the ACC and shuts down or hibernates the pc. When the pc has shut down the opus shuts off the 12v power, the relay is now no longer getting 12v so it opens and disconects the 5v line.
No more power drain and your battery stays charged.
Old 08-02-2006, 12:06 PM   #7
jay_tu's Avatar
jay_tu is on a distinguished road
This doesnt happen with mine ......... may be the 5v line is on... but the cd drive and gps are off with the ignition.
04 Corolla
Modifications:
Upgrading pc 99%
Progress
jay_tu is offline   Reply With Quote
Old 08-02-2006, 01:29 PM   #8
WiCKeD 5.9L is on a distinguished road
Is this fixed with the newer ones? I haven't hooked up my GPS/CD-ROM yet.
Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D T7200 / MB: MSI Fuzzy 945GM2 / SC: E-MU 1212M SC / RAM: Corsair 512MB / HD: Hitachi 7K200 2.5" 100GB / DVD: Panasonic UJ-815B / PSU: Opus 150w / LCD: 7" Xenarc
WiCKeD 5.9L is offline   Reply With Quote
Old 08-02-2006, 01:35 PM   #9
albysure's Avatar
albysure
i'm albysure84 on im. usually on at night. i can explain it to you better
Old 08-03-2006, 01:26 PM   #10
cheers matey
I dont use this forum much but it always come in handy!
Old 08-06-2006, 02:08 PM   #11
Tainted Love
Cris's Avatar
Let us know if you come up with a solution.
Old 08-06-2006, 04:20 PM   #12
mine is only a couple of months old so I doubt opus have changed anything in production. I don't think all motherboards leave the 5v live when switched of so maybe this is why some USB ports aren't live.
Old 08-06-2006, 04:22 PM   #13
3g Jester's Avatar
3g Jester is on a distinguished road
does the 250 pull this crap? or does anyone know yet
3g Jester is offline   Reply With Quote
Old 08-09-2006, 12:49 PM   #14
Saturated_Fat's Avatar
Saturated_Fat is on a distinguished road
Err.. I think this happened to me. Ended up draining my battery to the point of not starting . Is there a way to just turn off USB devices in the bios when not powered or something similar ???
Shotgun! - An Advanced CarPC Software Solution!
Saturated_Fat is offline   Reply With Quote
Old 12-01-2006, 01:54 AM   #15
romanman69's Avatar
romanman69 is on a distinguished road
i keep having the same problem with my opus. many motherboards have a jumper to turn off the 5v to usb when the pc is off. Mine doesn't, but hopefully the rest will have better luck.
i was wondering, is there any way to connect a single toggle switch to atx connector. I'm pretty bad with power supplies so i dont have a clue as to which wires to connect it to however.
romanman69 is offline   Reply With Quote
DIY Opus 150 5v Stndby power cut mod antimatter Power Supplies 7 08-31-2005 11:00 AM
Should I ditch my Opus 150 for my CF-bases system? ayclens Power Supplies 3 08-22-2005 11:30 PM
will the opus 150 power my system? I have all the figures intense Power Supplies 13 04-15-2005 03:55 PM
Opus 150 and Netstumbler hibernate/shutdown problem slick rick Power Supplies 3 03-28-2005 10:54 PM
Stupid question about OPUS wiring RS3RS Power Supplies 16 08-31-2004 02:33 PM
