The MP3car.com Store
Thread Tools Display Modes
Old 11-28-2006, 09:05 PM   #16
My Photos: (0)
Shut down issue with laptop. Consider going stand by mode
Have switch to inverter shut down w ignition switch. (Simple low volltage relay) Have laptop screen closed when installed in car. Set power options for laptop to go to standby mode when screen is closed. When laptop goes from ac power to battery power it will go to standby mode. When you start car up and inverter comes on laptop will boot back up automatically. Thanks, Richard
Should work but you know how Winblows is. Sometimes it takes some tweaking to get windows to operate properly.
iceking69 is offline   Reply With Quote
Sponsored Links
Old 11-29-2006, 09:13 AM   #17
LUWE SYGABU's CarPC Specs
LUWE SYGABU's Avatar
Vehicle: 2006 Honda Civic
My Photos: (0)
FYI, you need to activate setup and set your startup and shutdown times using the menu and select buttons, prior to turning the ingintion. It is designed to be able to run setup without acc on. It will save your selections into the eeprom and they remain there until you either change the setting or reprogram the chip.
May all your dreams come true.....unless your dreams are nightmares ~ L.S.
http://www.mp3car.com/vbulletin/showthread.php?t=67759
LUWE SYGABU is offline   Reply With Quote
Old 11-29-2006, 09:23 AM   #18
My Photos: (0)
I think that having a laptop mounted on your dash is certainly an option, not desirable by most. It is much less space consuming not to mention self gratifying to have a touch screen mounted in the dash. Sometimes more difficult = more fun. Even if you are not intending to mount the laptop on the dash, some aren't using a laptop in their system. Good idea for a simple laptop power control though.
Old 12-19-2006, 11:13 AM   #19
optczr's Avatar
My Photos: (0)
I have attached a revised drawing, which shows a some changes from the original.
1. R2 was changed from 1K to a 10K resistor.
2 The PIC16F877A, VDD line is listed as +5 and the VSS is now listed as GND.
Also wanted to say thanks to Luwe for his help.
optczr is offline   Reply With Quote
Old 01-04-2007, 06:46 PM   #20
optczr's Avatar
My Photos: (0)
In the process of making a board and if everything goes good, I'll get my screen tomorrow and install this into my car Saturday (after testing)
Sponsored Links
Old 01-04-2007, 07:29 PM   #21
My Photos: (0)
Good goin
Lookin good OP!!! Looks like you're doin all the right stuff, I'm happy for ya. I hope everything goes well. I'm sure some would appreciate you posting your PCB file and labeling. I would also love to hear about your success. Thanks for all you have contributed to this little project for everybody.
LUWE
Old 01-12-2007, 12:15 AM   #22
enhanced08's CarPC Specs
enhanced08's Avatar
Vehicle: Slammed 2000 Chevy S10 Xtreme
My Photos: (0)
How much did this cost you to build? I really want to try this! I have some electronics background but have never done any chip programming, where should I start with learning? do you need a special device to program the chip?
enhanced08 is offline   Reply With Quote
Old 01-12-2007, 11:09 PM   #23
optczr's Avatar
My Photos: (0)
Hi Enhanced08: The startup circuit doesn't cost that much to make. The most costly parts are the LCD and the PIC16F877A, but you can purchase these items from Ebay for just a few dollars. As for all the other components, they can be purchased at any local electronic store for just a few dollars. I believe that I have spent about 25 dollars on the one I making and that’s with two PIC16F877A that I purchased from Ebay for 11 dollars. I also built a board for the circuit, making it easier to put this together. Luwe has also listed the HEX file on this thread for download, so all you have to do is program the PIC with a PIC programmer, which you can also purchase from Ebay. I’m almost done with mine and when I am, I will have some extra parts and circuit board, so if you are interested, let me know.
Old 01-12-2007, 11:13 PM   #24
optczr's Avatar
My Photos: (0)
Hey Luwe:
Once I have everything working and looking good (I have already made changes), I will post the PCB file so that everyone can download it.
Old 01-13-2007, 01:21 PM   #25
FLAC is for flacid
parksgm's CarPC Specs
parksgm's Avatar
Vehicle: Mustang GT
My Photos: (4)
Subscribed.
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Old 01-14-2007, 11:02 PM   #26
My Photos: (0)
Wink 1
Hey guys, I changed my mind a little on the power to the LCD. The way I designed the circuit, the LCD had power to it 100% of the time. This isn't necessary, and you can help preserve the life of your LCD by putting a transistor on your LCD power wire. And this will work with the HEX I previously provided since this was my original intent when I first began the software design, and coincidentally, I left the code in place. Pin D6 is programmed to go HIGH whenever the LCD is needed, so all you have to do is put a PNP transistor in line.
Enhanced:
You are further ahead than I was last spring when I got into this stuff. I've always loved electronics but knew very little about it. I started learning about both electronics and microcontrollers concurrently originally with this particular project in mind. I wish I had got into it a long time ago, it's awesome to let your imagination go with the possibilities. I would suggest you get some ebooks or PIC programming books. There are plenty of online sources for free that you can access to train you. Get a development board that will allow you to expand your knowledge. I bought an EasyPIC from Mikroelektronika. I use MicroCode Studio with PicBasic Pro Compiler. Start simple, but I'm sure your probably smarter than me so you'll be able to do whatever you want.
OP: I want to see some pics of your PCB too man.
Old 01-14-2007, 11:22 PM   #27
My Photos: (0)
If you guys want to mess with the source code. Here you go....
I used microcode studio from mecanique with picbasic pro from microengineering
Old 01-15-2007, 03:09 PM   #28
optczr's Avatar
My Photos: (0)
I have made a few layout changes from the first board layout, I posted a few days ago. I've posted a photo to show the board and its size. I will begin making the board this evening and should be done by tomorrow or the next day. If everything works and I don't have to make any changes, I'll post the board layout... I've also included the additional pads for the PnP transistor. Thanks Luwe.
Old 01-16-2007, 04:54 PM   #29
optczr's Avatar
My Photos: (0)
I have made the PCBoard last night, using the laser printer method. If you don't know what that is, I have listed the web address. http://max8888.orcon.net.nz/pcbs.htm. Otherwise, the photo of the board is below and everything so far is looking good. I will begine stuffing the board this evening and if everything fits right and the board works, I will post everything for the board tomarrow.
Old 01-16-2007, 05:46 PM   #30
My Photos: (0)
Hey alright, that looks real good OP. I'm excited to hear how it works for ya.
Sponsored Links
vB code is On
Trackbacks are Off
WTB DSSC Shutdown startup controller xs10x Classified Archive 3 04-26-2006 05:23 AM
LCD screen size for double din opening...??? EclipseGSturbo Newbie 6 01-30-2006 12:24 PM
FS: 10.4 lcd screen with controller ect. nmiller35 Classified Archive 7 07-15-2004 11:35 PM
8.4" Sharp screen + earth lcd controller cruzc_99 Classified Archive 10 07-01-2002 06:56 PM
latop lcd screen with controller card? schrodos General Hardware Discussion 3 11-20-2000 10:34 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
