Old 10-02-2006, 07:43 PM   #1
Computer doesn't resume from standby...Opus 120
So, I've had my carPC since spring time, and it works fine, basically, my computer will go into standby when i take out my keys, but when I turn the car on again, it will start up windows from scratch, not resuming from standby...
I just installed a sub today, and I don't know if some wires got messed up, but is it a jumper issue? I didn't see anything different in the wiring, or is it a windows setting?
VIA 13000
Opus 120
2.5" HD
512mb ram
Everything was working fine up to this point, it resumed from standby and everything, but all of a sudden, it will go into standby, but do a normal startup when the key comes back...I checked windows "power options" settings, and nothing seems wrong...
Any ideas? I'm sure this issue has been asked before, but I can't find a situation that matched this, so if this has been posted before, a link would be appreciated, thank you for your time.
senseless228 is offline   Reply With Quote
Old 10-03-2006, 10:41 AM   #2
strohj's Avatar
Make sure that the red wire on your opus still has power when you turn the car off...
strohj is offline   Reply With Quote
Old 10-03-2006, 10:42 AM   #3
why wouldn't it get power?What could potentially stop it from getting power, just so i know what to look for.
Old 10-03-2006, 10:46 AM   #4
strohj's Avatar
you said you wired a sub... so I would guess you wired a amp as well.. and somewhere you might have gotten wires mixed up etc etc...
take a voltmeter and make sure you still have 12v at it when the car is off.. cos if your power supply doesnt have power.. your computer wont have power.... and then standby wont work...
Old 10-03-2006, 12:07 PM   #5
If the RED stays on the PC will never get triggered to shut down (standby) so that is kinda besides the point. Make sure your middle jumper is loaded. Do you get 2 blinks at any point?
zigi13 is offline   Reply With Quote
Old 10-03-2006, 12:42 PM   #6
strohj's Avatar
are you sure its not the yellow wire that triggers it?
but then again.. I might have the two wires confused...
Old 10-03-2006, 12:49 PM   #7
strohj's Avatar
I stand corrected .. the yellow wire does indeed need to be wired to always on 12V... its the red wire that is the ignition wire....
my bad....
EDIT: btw.. its RED for constant 12V on the OPUS 150w and yellow for ignition... you would think they would keep things the same between their different models.. but I digress....
Old 10-03-2006, 05:03 PM   #8
well, it boots up on ignition, and it goes into standby properly, and I haven't checked yet, I haven't been to the car all day, but I have a feeling that the jumper got loose...I'll take a look at all the suggestions, but it seems that everyone thinks its a hardware/wiring issue, and not a software issue in windows.
Thank you for your time and suggestions.
Old 10-04-2006, 03:41 AM   #9
If you have an IBM Netvista im afraid your Screwed, They and the Opus 120 don't work together for Standby.
P4 Celeron 2.2 - 512MB - OPUS 250 - Audigy SE - BU353 - HQCT - No Speakers though :-(
ryan-neil is offline   Reply With Quote
Old 10-04-2006, 06:04 PM   #10
*sigh* as i was installing the sub, I somehow knocked off the jumper on the opus, and putting it back solved it...thank god the jumper was laying right under the powersupply, otherwise I didn't feel like doing a bit of soldering while laying down. Thank you for your time everyone.
Opus 120 and MB896 standby. Naamanf General Hardware Discussion 7 06-02-2006 07:16 AM
opus 120 watt psu restarts computer when i start car..??? jaded_gti Power Supplies 1 10-13-2005 05:06 PM
Opus stays on in standby camarossguy2 Power Supplies 10 08-10-2005 11:31 AM
Opus 120 Cheekz185 Power Supplies 1 06-17-2005 03:08 PM
How long can an opus power the computer running without Durango running?? nolmscheid Power Supplies 9 11-01-2002 11:21 AM
