Old 11-06-2006, 10:09 AM   #1
Kamakazie2 is on a distinguished road
5v DC power supply for us heavy USB laptop users..
http://www.trcelectronics.com/Meanwell/sd-50a-5.shtml
About $40 dollars and this will power up to 10amps @ 5 volts. They also have smaller versions but this gives you the most bang for the buck. Most of you may use your computer power supply but this is more of a solution for us laptop users who dont have a large power supply to start with.
It takes 9.8 to 18 volts input and regulates it to 5v output. 70% eff rating
Why 10 amps? Why not? Think of it:
2~3 amps for DVD-R drive
500mA for Wifi
250mA for Bluetooth
100mA for Shuttle express
500mA for HQCT
400mA for XM PCR
100mA for Touchscreen
50mA for mini usb keyboard
500mA for sound card (if usb)
Thats almost 7 amps!
1 powersupply to power all your usb hubs and your hqct and external DVD drive. I have used this for about 2 weeks now and everything runs great.
-Jack
2006 Chrysler 300C AWD
IBM T30 Thinkpad / RoadRunner
XMPCR/GPS/SIRIUS
(RIP) HDRadio project: http://www.mp3car.com/vbulletin/hardware-development/93791-someone-here-has-able-crack-hdradio-car.html
Kamakazie2 is offline   Reply With Quote
Old 11-06-2006, 10:18 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Excellent find!
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 11-06-2006, 04:49 PM   #3
Ruffy's Avatar
Ruffy is an unknown quantity at this point
more specs
http://www.trcelectronics.com/Meanwell/pdf/sd50.pdf
Ripple & Noise 100mVp-p
Rated Power 50W
Voltage Tolerance +-2.0%
Line Regulation +-0.5%
Load Regulation +-0.5%
Efficiency 70%
Overload Protection 105 ~ 150% Rated output power, Fold back current limited protection
Over Voltage 5.75 ~ 6.75V /10% Load, Hiccup recovery
Working Temp -10 ~ 60Degrees Celcius, 20-90% Humidity
Ruffy is offline   Reply With Quote
Old 11-06-2006, 06:07 PM   #4
psyrex's Avatar
psyrex is on a distinguished road
I, and a couple of other people here, use the 12v one. There are 15W, 25W, and 50W models. These are just DC-DC converters -- there is no SDC.
Gen 1: Pentium 3 1GHz - ATX - 2005
Gen 2: Pentium M 1.6GHz - ITX - 2006
Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
...it never ends
psyrex is offline   Reply With Quote
Old 02-03-2007, 12:28 AM   #5
Ruffy's Avatar
I was heavily considering this one but the 70% efficiancy rating worried me. I'd rather not have a component that wastes so much power making heat. Just a thought for anyone who might want one
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Old 02-03-2007, 12:33 AM   #6
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
70% really isnt too bad for cheap regulators. As long as you dont put it in a confined space, it should be fine
Old 02-03-2007, 12:34 AM   #7
Ruffy's Avatar
oh it would definitel be in a confined space. which is why im staying away
I love the fact that it has a it's own casing. Easy install with screw down terminals. But the heat man, the HEAT!
Old 02-03-2007, 02:30 AM   #8
raxy is on a distinguished road
cosel is much too expensive !!!
raxy is offline   Reply With Quote
Old 02-03-2007, 03:51 AM   #9
Ruffy's Avatar
Not really. You would have to buy 3 carnetix 5v POL units to get 9amps, this unit does 10 amps for only double the price of the carnetix(Actually less than double)
but alot of that will be wasted putting out heat.
Old 02-03-2007, 03:56 AM   #10
Ruffy's Avatar
they also have a 3amp 15watt 5v POL
http://www.trcelectronics.com/Meanwell/psd-15a-05.shtml
again lower efficiency but more components.
Enclosed
http://www.trcelectronics.com/Meanwell/sd-15a-05.shtml
5amp enclosed $32
http://www.trcelectronics.com/Meanwell/sd-25a-5.shtml
Old 02-04-2007, 12:21 AM   #11
Ruffy's Avatar
welp talked to my friend who has bought their 5amp unit. Apparantly it puts out tons of heat when in use and stays quite hot.
I would nmot reccomend them for anyone using them in tight confined places without actual fan cooling. Looks like I'll be getting the carnetix, if I need more amperage I can always buy two.
edit : UPDATE
got to check out my buddies rig, he drives a flatbed truck and has two units installed. a 12v and a 5v. Both got fairly hot (over 50c at least, opertating temperature is only a max of 60c...) This was with a bunch of usb devices all on. Both were installed under his passenger seat so plenty of air space but no extra cooling. If you get a meanwell consider fan cooling for best usage.
Old 02-04-2007, 04:40 AM   #12
USD39 for a 12V-4.2A out 9-18V in :
http://www.trcelectronics.com/Meanwell/sd-50a-12.shtml
Old 02-04-2007, 09:27 AM   #13
GibsonLP's Avatar
GibsonLP is on a distinguished road
2 questions:
1. Do you think I can put the 5vdc 5A unit in the trunk without using a fan? (however - it's in the trunk, not such a confined space).
2. In practice - how do I hook up such a unit to my units? what about units that have no power supply input, just usb input? can I just "power" my entire usb network with this unit?
Thanks.
Edit:
What do you say about this converter -
http://store.altenergystore.com/Char...nverter/p1302/
Looks pretty efficient (but expensive...)
GibsonLP is offline   Reply With Quote
Old 02-04-2007, 10:38 AM   #14
Ruffy's Avatar
Quote: Originally Posted by GibsonLP View Post
2 questions:
Thanks.
Edit:
Nice find but yes very very expensive for only 5 amps. You could get 2 carnetix 5v POL's for $50 and end up with working amps.
1: As for the meanwell. Mounting in the trunk should be fine. but I'm not going to risk it. The psu is going to be enclosed with my laptop underneath a panel of wood. I am going to be using fans to circulate air in and out of the enclosure but not alot of them. After feeling how hot the meanwell got I wouldn't reccomend using it any tight enclosed areas. If you mounted it to the widewall or top deck of the trunk then it should be fine. but behind carpet would be a no no.
2: You can either splice the cable. Buy a USB dual head cable and splice into the extra connector. Or just use one of these devices to power a USB hub. That way all your devices get max power. Remember at most a usb device used 500mA And thats only the high end stuff. Very few items surpass that (some usb drives) To overcome that they almost always include a secondary input jack. But everything else generally gets its power off the usb bus so a powered usb hub is the win.
Old 05-17-2007, 03:05 AM   #15
miztahsparklez is on a distinguished road
sigh i wish i would have read thoroughly before i ordered. im in the process of installing mine. i think overloading my p5v was causing instability of my computer system. I wanted something inexpensive to supplement the p5v so i bought the 10 amp system listed above. the main thing that worries me is that this will be under a floor with many other hot devices, such as amplifiers and my carputer.
anyone know what i can do to make this work out?
Carputer HIFI car stereo project!
[XXXXXXXXXXXXXXXXXXXXX-]
95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
[XXXXXX--------------]
30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
miztahsparklez is offline   Reply With Quote
dc - dc power supply vs. an inverter deepdivered Newbie 1 01-05-2006 10:42 AM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
DC DC power supply modh1984 Power Supplies 10 11-23-2005 01:56 PM
Has any one had any luck converting a standard PC power supply to a DC to DC unitl? pronerd Power Supplies 14 02-11-2005 07:35 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
