Old 11-06-2006, 11:45 AM   #1
bluehcc's Avatar
static _whirl noisy using carntix
Last night i finally get sometime to test my carpc to figure out where the noisy and static noisy from. This is how i setup the carpc. My compaq laptop is powered up by Carntix P1900, the sound output of laptop go through the cd changer port (using a auxilary adapter). I soldered the power button of the laptop. The pc working fine till day with the noisy. Last night i unpluged the DC power into my laptop, let it run from laptop battery, all the noisy and static, and static to the lcd screen is gone. so is there anybody can help me figure out what's my next step??
2006 Camry
Compaq Laptop
Holux GPS Iguidance 3.0
7" Xenarc Touch Screen
Carnetix 1900 Power Supplied, Wireless b/g
bluehcc is offline   Reply With Quote
Old 11-06-2006, 08:16 PM   #2
bluehcc's Avatar
anybody has any thought???
2006 Camry
Compaq Laptop
Old 11-06-2006, 08:40 PM   #3
Zeroaviation's Avatar
u getting noise while the vehicle is running? or not?
Zeroaviation is offline   Reply With Quote
Old 11-07-2006, 08:03 AM   #4
bluehcc's Avatar
both on and off. static noisy when its off, both static and whirl noisy when on
2006 Camry
Compaq Laptop
Old 11-07-2006, 04:43 PM   #5
you might wanna try using some sort of "choke" AC filter, ...... i had a problem similar to this, i was getting AC noise through the PS, i picked one of these handy dandy Isolaters, "a choke and some capaciters..."Walmarts AC filter try adding that between your Audio out and in on your AUX adapter, Thats the best i can explain it, i suck at explaining things o.O
Last edited by Zeroaviation; 11-07-2006 at 04:46 PM. Reason: Cause i cant frekin spell, still.......
Old 11-17-2006, 06:24 PM   #6
My noise completely disappeared after using a PAC noise filter/ground loop isolator. I have an extra one available, Private Message me if interested.
BlackStealth is offline   Reply With Quote
Old 11-18-2006, 11:50 AM   #7
miwise's Avatar
I'm getting the same noise, and my fan on the psu is acting up. I think that it is the power supply. My power supply is even making a clicking noise (not through speakers, this is the unit itself) in addition to the noise in the speakers and lcd. I had another power supply for my laptop that didn't do this (cheap ebay dc dc supply) even with the car running. I'm sure that my power supply is defective as I tested it on my jump start battery in the house and the fan does the exact same thing with it.
Lexus SC400/Factory Amps/Sub
HP/AMD 1.1 Ghz Mobile/Upgrade Imminent
512 RAM-DVD/7" Touchscreen
WinXP-Shelled to Roadrunner for now
Progress:
Software: Still trying to decide
Hardware: 95% done. . .need GPS
Installation: 90% done. . .clean up phase
miwise is offline   Reply With Quote
Waves of Static Viscouse General Hardware Discussion 0 01-24-2006 02:19 PM
Noisy Harddrive TheLlama General Hardware Discussion 13 10-27-2005 11:23 AM
periodic static loscooby Car Audio 0 10-19-2005 01:20 AM
Exiting videos causes static in MP3s ddogg_777 Centrafuse 2 02-16-2005 08:43 PM
Carputer finally in...static issue... -al- General Hardware Discussion 12 11-04-2003 07:27 AM
