The MP3car.com Store
Thread Tools Display Modes
Old 11-12-2006, 11:03 PM   #1
Vehicle: 2005 Dodge Stratus R/T
My Photos: (0)
Laptop Power Hardwire
Hi all, I want to put together a car pc using my old hp omnibook laptop. Right now I am trying to figure out how to connect it to be powered. I am looking to hardwire it in. Here is what I don’t want to do.
Total cost $35. Unfortunately, I’ll have all that unsightly cabling running everywhere. What I want to do is hardwire it into the car’s system, being able to power both the laptop and a 7” lilliput touch screen.
From all the searching I’ve seen, I have to buy either the above solution, or buy a CarNetix DC/DC powersupply ($$) that somehow I wire into the laptop and the touchscreen.
Is there no simpler way of hardwireing the laptop into the car’s power system? I am not looking to spend 90 dollars to connect.
I was also considering going the $35 dollar route, splicing open the wires, extending, and running to the trunk if nessesary.
Laptop – 19v @ 3.16A
Comments? Suggestions?
KptKill is offline   Reply With Quote
Sponsored Links
Old 11-13-2006, 06:59 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
You can hardwire the laptop's car adapter. Just cut off the cigarette lighter plug, strip some wires and have at it.
Wire up the Lilliput the same way.
The only concern I have about what you propose in your diagram is that the cigarette lighter might not be able to support the power draw of both the laptop and the lilliput. I can't say for certain.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 11-13-2006, 12:22 PM   #3
My Photos: (0)
Should be fine all running from the cig lighter. Your laptop will draw a little over 5 amps and your lilliput will likely draw under 1. I have yet to see a cig lighter that doesn't have at least a 10 amp fuse.
comet28024 is offline   Reply With Quote
Old 11-13-2006, 01:12 PM   #4
csnowman00's Avatar
Vehicle: 1996 Jeep Grand Cherokee
My Photos: (0)
So even though the laptop calls for 19v, it will still run? Would voltage spikes and fluxes from the starter, sound system affect the laptop?
Current Progress:
[▓▓▓▓▓▓▓---]80%
Final Assembly
Ramline P3 PC
10.4 inch Touchscreen
Windows XP Embedded
Road Runner
http://www.carlschiel.com
http://www.modthetv.com
Electrical Engineer
csnowman00 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Power help for new laptop CarPC jwaters Laptops, Tablets, UPMCs, etc. 13 01-06-2007 01:15 PM
Power button won't work when laptop lid is closed scotty562 Laptops, Tablets, UPMCs, etc. 4 09-22-2006 10:25 PM
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 23 09-01-2006 01:18 AM
Power laptop from headunit? LordSnow Newbie 12 04-07-2005 09:25 PM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 12:13 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
