The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 11-13-2006, 09:19 PM   #1
Vehicle: 2005 RX-8
My Photos: (2)
Angry DSATX serial diagnostics spits out garbage
I tried out the DSATX for the first time today. At first my motherboard wouldn't turn out. Turns out I need to switch the polarity of the motherboard on cable. So I am right now using a switch to short the pins.
I connected the DSATX to my desktop PC to change the default shutdown timer. The diagnostics output was ok at this time.
I then started to install windows. About half way through the installation, the power supply just turned off. I tried to turn it back on but the LED on the DSATX wouldnt even come on. I hooked the serial cable back up to it, and now all I get when i start the DSATX is garbage. Sometimes I get the regular output and I'm able to input commands. But then the garbage starts up again.
I bought the DSATX a few months ago but I only got around to using it today.
Any ideas what could be wrong? I read about firmware issues on the first batch, but I thought that was all fixed on the later boards. If I remember correctly, the firmware version of my unit was 0109 (got it from the diagnostics). My board revision according to the sticker on the back is D842606.
zenfe is offline   Reply With Quote
Sponsored Links
Old 11-14-2006, 11:21 AM   #2
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
PM Jeff, maybe you have to send it back to him for firmware upgrade.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 11-14-2006, 01:50 PM   #3
Vehicle: 2005 RX-8
My Photos: (2)
Well I unplugged the brainstem from the DSATX and everything seems to work fine. I planned on keeping the brainstem plugged in at all times, and whenever I need to use the diagnostics, I would plug in the serial cable before turning on the computer.
I'm going to check out the brainstem later on when I have more time, to see if anything is wrong with it.
Old 11-14-2006, 01:55 PM   #4
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Per zootjeff, you shouldn't connect/disconnect the brainstem when the DSATX as +12v, ideally.
At the very least, you shouldn't connect/disconnect it while the PC is running. It will do unpleasant things.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 11-14-2006, 02:21 PM   #5
Vehicle: 2005 RX-8
My Photos: (2)
I had read that already. What I was experiencing was happening while simply having the brainstem attached and serial cable detached.
I'm going to extend the brainstem connector later on because I want the brainstem to be accessible from the back of my carpc case. I'll test the brainstem then. Hopefully everything will work out. But right now the DSATX is running ok without the brainstem attached.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
My DSATX 220w experience tj!2k4 Power Supplies 8 11-16-2006 08:47 PM
Serial Adapter for DSATX now at Mp3Car Store zootjeff Power Supplies 5 04-24-2006 12:18 AM
Ordered Mp3Car DSATX does it come with the serial interface? shauns Newbie 1 03-26-2006 10:29 PM
Serial adapter for dsatx djXternal Power Supplies 4 02-07-2006 10:01 AM
Via Mini-ITX Epia 5000 serial port not working vash General Hardware Discussion 2 08-13-2002 08:48 PM
Sponsored Links
Ad Management by RedTyger
