The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 01-07-2007, 01:42 PM   #1
atlttz's Avatar
Vehicle: 1994/Nissan/TwinTurboZ
My Photos: (0)
Power????!!!!!!!?????
Dell offers auto adapter for laptops....will that work to power if I hardwire it in(not just plugging into cig lighter)to the remote wire on my amp (if that is the best way)? One is made by Lind and the other by Duracell. They are 90 and 130 watts respectivly and I am not sure which to choose. I have an Inspiron 8500 that will be a permanent install. It has the centrino processer and I did not find a wattage calculator for this particular one(although there were others for Intel). Also, any ideas around powering off??? I found and purchased from one of the members of this site something that allows the laptop to come on with the car, but I need something to turn it off. I have seen the hibernate option but am not sure how comfortable I am with that since I may not be in the car a few days at a time. There is a lot in here and I have spent some time looking but can not find specific answers. Any help is appreciated if only to answer parts of this lengthy post. Thanks
atlttz is offline   Reply With Quote
Sponsored Links
Old 01-09-2007, 09:56 PM   #2
browncf's Avatar
Vehicle: 2006/Porsche/Cayman S
My Photos: (0)
I would go with the 130 watts, that should be plenty to power the laptop and a few extras. Don't see a problem with using hibernate on the laptop since the power draw while hibernating is very small. If you know you're going to be away from the car for a while, you could always unplug the laptop or take it out of the car.
browncf is offline   Reply With Quote
Old 01-09-2007, 10:36 PM   #3
Zeroaviation's CarPC Specs
Zeroaviation's Avatar
Vehicle: 98 Ford Mustnag
My Photos: (0)
This is how my first carputer setup was, i used a 90watt duracell DC-DC, worked fine untill i decided to put a FULL computer in there
Im a pilot.
I have become a cross control stall.
Zeroaviation is offline   Reply With Quote
Old 01-10-2007, 12:41 AM   #4
My Photos: (0)
Look for a program call ShutControl v1.02, there might be a newer ver. I used it on my laptop. You call set it to shutdown,restart,hibernate and standby. Great program.
soloxp is offline   Reply With Quote
Old 03-04-2007, 02:41 PM   #5
atlttz's Avatar
My Photos: (0)
The duracell 130 watt "brick" works perfect, you just have to make sure you wire to a 12v acc/switch wire or it will not charge the battery/turn on the computer. Using my amp remote wire did not work as it did not put out a full 12v.
Old 03-04-2007, 03:37 PM   #6
Takes it in the Rear
kevinlekiller's CarPC Specs
kevinlekiller's Avatar
My Photos: (0)
Dont plug it directly to the remote wire on the amp , that wire doesn't carry enough current. Get a relay , grab the power from the battery or something and the switch wire from the acc wire from the head unit.
kevinlekiller is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Power supply Problem xGROMx Power Supplies 8 03-16-2007 01:19 PM
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 23 09-01-2006 01:18 AM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 12:08 AM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 09:29 PM
Opus power supply issue dmazyn Power Supplies 2 10-15-2003 06:32 PM
Sponsored Links
Ad Management by RedTyger
