Old 01-19-2007, 08:06 PM   #1
Thefdog is on a distinguished road
16v power supply for laptops
Greetings all and thanks for any input,
I am planning on installing a laptop in a docking station that requires a 16v input. I assume that running a 19v Carnetix 1900 is risky due to the over-voltage. Is there a similar risk running a 12v Carnetix 1290 to the docking station?
I understand that I can use a generic dc-dc adaptor for the laptop that provides the proper voltage, but would prefer to have the benefit of a startup/shutdown controller, as well as having a clean 12v line that can be used to feed my monitor. Any suggestions are appreciated.
Cheers
Thefdog is offline   Reply With Quote
Old 01-19-2007, 08:55 PM   #2
billmee's Avatar
billmee is on a distinguished road
You could still use the carnetix to power a 12 to 16 v dc to dc.
I wonder if the laptop would run with only 12 volts.
I suspect the 16 volts is need for charging it's battery.
My old 386 laptop is this way.
billmee is offline   Reply With Quote
Old 01-20-2007, 07:22 AM   #3
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
That's bad advice.
What I would think is use a Carnetix P1290 to provide 12v power to a car adapter that powers the laptop. You could still use the startup/shutdown features of the carnetix that way.
As far as the docking station, I'd check to see the required input voltage it requires. Frankly, I think a docking station is the ideal solution, although they're harder & harder to find these days.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 01-20-2007, 03:15 PM   #4
billmee's Avatar
Quote: Originally Posted by DarquePervert View Post
That's bad advice.
What is?
Old 01-20-2007, 04:40 PM   #5
Raw Wave
Chris31 will become famous soon enough
Quote: Originally Posted by billmee View Post
What is?
Dont mind him.
Chris31 is offline   Reply With Quote
Old 01-20-2007, 04:59 PM   #6
Raw Wave
That's bad advice.
You called that bad advice but isnt that the same thing you said above?
Why you want to use "car battery > carnetix > PSU > Laptop" ?
It be far more efficient to go directly by using the car-laptop PSU alone.
He did say docking station needs 16V, docking station usually use the same voltage as the laptop, just requires higher current to cope with the other peripherals attached to it.
Old 01-20-2007, 05:07 PM   #7
Raw Wave
Cheers
If you want to use the carnetix, you may be able to modify it so that it spit out 16V instead. A typical PSU requires a feedback and usually is made out of 2 resistors thats connected directly to the PSU output and the voltage control. If you ask the carnetix guy they might be able to change these 2 resistor values such that it outputs 16V for your docking station. If thats how the carnetix work and you know which of these 2 resistors to change then its easy to do.
As for the 12V for the monitor, dont know, maybe just get a 12V regs?
Plenty of option out there, depends how you want it done, how much you want to spend.
Old 01-20-2007, 05:27 PM   #8
MikeH is on a distinguished road
Please take a look at this thread...
http://www.mp3car.com/vbulletin/show...75&postcount=3
MikeH
MikeH is offline   Reply With Quote
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
REVIEW::220 Watt DC-DC Power Supply: DSATX seabeggar69 Power Supplies 4 03-20-2006 05:53 PM
Shuttle G5 1100h and Opus Power Supply Caelric Power Supplies 9 11-16-2005 05:13 PM
Power Supply Options? Optikal Power Supplies 9 06-26-2004 06:46 AM
AT power supply questions JustAGuy General Hardware Discussion 4 07-26-2000 05:35 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
