The MP3car.com Store
Thread Tools Display Modes
Old 02-28-2007, 07:43 AM   #1
Smartstradamus's CarPC Specs
Vehicle: bmw 1 series
My Photos: (2)
m2atx from cartft
I recived my voom with an m2 atx supply pre-built from cartft.
When i opened it up to check everything was correct,i noticed they had put the white on J1 and red on J3.
I presumed the red should be always live and white should be igniton on.
And the manual backsup my presumption.
So J1 should be red and J3 should be white.
I contacted cartft and they replied saying they have wired it correct and white is J1 and red is J3.
Should i just connect the white to the battery and red to ignition?
I would have just switched them on the board but they are really stiff and i cant be bothered.
Smartstradamus is offline   Reply With Quote
Sponsored Links
Old 02-28-2007, 07:58 AM   #2
DavC's CarPC Specs
Vehicle: Vauxhall Vectra
My Photos: (0)
J1 goes to perminant live.
J3 goes to ignition live.
the cable colours you use for making these connections are your choice.
DavC is offline   Reply With Quote
Old 02-28-2007, 08:17 AM   #3
My Photos: (2)
cheers davc,
I just wanted confirmation as red as live is a standard for me.
Old 02-28-2007, 08:58 AM   #4
DavC's CarPC Specs
My Photos: (0)
yes i'd have imagined the colours to be the other way round too, and personally i'd have probably swapped them round without much of a thought as it would make more sense to me, and i'd be far less likely to wire them up the wrong way round a week later after a long days work when i wasnt thinking properly and a bit tired...
just dont fall into the trap of always thinking red is 12v live, or that black is always ground.
as far as computers are concerned, most often red = 5v live
as far as a lot of factory car wiring is concerned, black = live, and brown is ground...
Old 05-17-2007, 04:04 AM   #5
vrslider's CarPC Specs
vrslider's Avatar
My Photos: (10)
how thick must the ground cable be ? I want to use a 6 mm wire is that enough?
vrslider is offline   Reply With Quote
Old 05-17-2007, 04:21 AM   #6
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
The ground cable should be at least as thick as the power (constant +12v) cable.
Here is a handy dandy chart: http://www.powerstream.com/Wire_Size.htm
And those size diameters are for the copper itself, not copper and insolation. FOr instance I have 4awg wire which is about 5mm thick on the copper side, and about 1cm thick total.
For the M2, 10awg to 8awg is the standard size. Thicker is always better. I used a bigger cable because I like the option of upgrading. One day I might want a DS-ATX, so instead of having to switch out the power supply and rerun a thicker cable, I just will have to switch the ps and be done with it.
And in case you havent picked it up yet, the lower the number for awg, the thicker the cable.
4awg is thicker than 8awg which is thicker than 20awg.
And make sure you are running your power cable to the battery. If you dont you will be sorry.
Old 05-17-2007, 09:07 AM   #7
vrslider's Avatar
My Photos: (10)
Hi thanks for your quick answer, if you check my pics you can see the power connector cable i am using, its a very thick one seperate from the rest of the car power, can i just ask you one more question.
Can i use the 12 v + GND from the orginal radio to power my xenarc 700 TSV ?
Old 05-17-2007, 01:34 PM   #8
2k1Toaster's Avatar
My Photos: (1)
Yes it should be sufficient to power your xenarc. And the xenarc has internal voltage regulation, so it is a firect connect!
And what pictures? I just see the M2=ATX layout diagram...
Old 05-17-2007, 05:05 PM   #9
vrslider's Avatar
My Photos: (10)
check my profile ..iv e got 10 pictures in my profile now..
Sponsored Links
vB code is On
Trackbacks are Off
Mp3Car's Transflective vs. CarTFT TMR ovsims LCD/Display 25 01-05-2008 10:16 PM
Hardware Review: Overdue M2ATX review elstev0 The Review Palace 0 09-03-2006 09:10 AM
m2atx and modern mobo? CMOS General Hardware Discussion 5 06-04-2006 11:01 PM
pc wont power off with m2atx jammy-dodger Newbie 8 03-17-2006 01:01 PM
Anyone in the USA purchase from CarTFT? lightman General MP3Car Discussion 9 06-11-2004 03:56 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
