Quote: Originally Posted by
ThunderStick
THis should work fine. The only concern I would have is leaving it in standby mode. Doing this will definitely drain your battery more than you want it to. I would suggest a second battery that is isolated after ignition is off thus preventing your main battery from draining and allowing your car to start.
You can tell P2140 to shut down the Computer , then the Power supply at a set voltage. ( mine 11.2 ) . that way you can never drain your battery dead. And still start the car.
P2140 default is ON & set at 11.8 when you buy it.
one other thing to remember is that if P2140.
can not produce 12 Volts prime and 12v sec. power outputs
You Can only produce 12v on sec. output when you have higher then 12v on you Prime output.
You can always just buy a small 12Volt power supply for just your screen.
It sounds like you have the Laptop & screen running off one power supply.
