Old 03-20-2007, 04:55 AM   #1
rxh81's Avatar
rxh81 is an unknown quantity at this point
Stupid M2 ATX !!
Hello everybody!
Just want to share my experience regarding M2 ATX.
I'm a little bit annoyed about its intelligence!!
It doesn't recognize if the PC is on or not.
That means, when the PC is on before I start the ignition, the M2 shuts down the PC
Or if I prevent the shut down after switching of the ignition (with Streeddeck), the M2 thinks the PC is off, turns the amps of and also shut down, if I switch the ignition on again - that's shaming!
Shouldn't it be easy for the M2 to check the on/off status of the PC by the "power on" line (pin 14) of the ATX connector?? and react appropriate...??
If it responded adequate I wouldn't need an additional power switch (ON-AUTO-OFF) like somebody have.
What are your thoughts??
Roland
rxh81 is offline   Reply With Quote
Old 03-20-2007, 05:10 AM   #2
djmickyg's Avatar
djmickyg is on a distinguished road
yeah it as anoying.. if i manually shut the pc down when i leave the car when i turn the ignition back on it doesnt turn off cus it thinks it's still on..
djmickyg is offline   Reply With Quote
Old 03-20-2007, 09:48 AM   #3
choier1983 is an unknown quantity at this point
Quote: Originally Posted by rxh81 View Post
Hello everybody!
Roland
hey i think i feel what your are talking about !! but if you try to connect the on/off wire to ACC of the car ! it may help !
choier1983 is offline   Reply With Quote
Old 03-20-2007, 09:54 AM   #4
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Hello everybody!
Roland
I don't have that problem. How old are your M2's? Maybe a firmare upgrade for it is in order? I can turn the PC on/off manually whenever I want and the M2 does grab the on state from pin 14. So if it is off when the car shuts off, it stays off. Then when the car goes on, it comes back on. If it is on when the car goes off, it shuts it off.
Seems like something is actually wrong with the M2, or maybe that is just using an older version of the PIC software, so it is not as intelligent as the new ones!
You need that for any "intelligence" at all for the M2. Without it, it is in dumb mode.
Old 03-20-2007, 02:57 PM   #5
rxh81's Avatar
Thank you for your answer!!
I tested it all again, and it seems that I was a little overhasty.
When I turn the pc off while ignition is on, and then also turn ignition off -nothing happens, so everything works right in this case!
But following situation doesn't work right:
- PC and ignition is on
- I turn the ignition off
- Streetdeck countdown appears
- I cancel the countdown and keep the pc alive
Now the M2 is irritated and thinks the pc is off and swithes the amps off.
Then when I switch the ignition on again it doesn't recognize that the pc is still running, sends the pulse and the pc wants to shut down.
I think the M2 is not prepared for a software like SD, where you can prevent the shut down.
But the most important is that I can switch off the pc while driving and it stays off when I kill the engine.
Does anybody have the same issues???
cheers, Roland
Old 03-20-2007, 03:01 PM   #6
2k1Toaster's Avatar
cheers, Roland
The SD shutdown thing is only if you are using the streetdeck prebuilt computers. It will not work no matter what on an ordinary SDC.
Old 03-20-2007, 06:20 PM   #7
MrJamieR's Avatar
MrJamieR is an unknown quantity at this point
So does this mean that the M2 ATX isn't stupid and the thread need renaming?
Carputer Haiku (thanks Ian Hughes)
Serious error.
All shortcuts have disappeared.
Screen. Mind. Both are blank.
MrJamieR is offline   Reply With Quote
Old 03-20-2007, 06:32 PM   #8
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Thread should be renamed, M2 got a bad rap on this one..undeserved!
treetop777 is offline   Reply With Quote
Old 03-21-2007, 12:04 PM   #9
rxh81's Avatar
It's not as bad as first quoted, but in my opinion it should not power the pc of, if I turn on the ignition.
It seems (I haven't tested this way) that following works right:
ign and pc off
pc on
ign on -> pc stays on
but not:
ign and pc on
ign off and pc prevented to shut down
ign on -> pc shuts down
It's not that bad, because I can prevent the shut down a second time.
A small blemish.
I don't want to have an extra "on-auto-off" switch.
All controlled with ignition.
But I want to be able to say the pc to stay alive after ign off.
But if I do so the M2 turn off the amps, so I have to control the amps with the 12V from the PC. Hopefully this works satisfying.
Also I managed it to crash the M2 with this procedure on time and had to disconnect it from power.
Old 03-21-2007, 01:04 PM   #10
2k1Toaster's Avatar
ign and pc off
pc on
but not:
ign and pc on
A small blemish.
Aaaaaaaarg!!!! You CANNOT "PREVENT THE COMPUTER FROM SHUTTING DOWN". This is for the proprietary SD hardware. Your issue is with your bloated software, not with the M2. There is no way to prevent the shutdown and expect the M2 to know that because it sends it pulse like it should and assumes the PC is off. Then it waits until the hardoff timer is triggered and pulls the plug. If you want this functionality buy a G4 when it comes out...
</rant>
Old 03-21-2007, 01:27 PM   #11
rxh81's Avatar
</rant>
I can prevent the shut down in Windows with many programs (not only bloated SD), but you are absolutely right, I cannot expect the M2 to be prepared for this situation !!!
Although I think it's not nessesary to turn the pc on, when it is still on!
whatever, you can not have everything...
Old 03-21-2007, 01:56 PM   #12
2k1Toaster's Avatar
Yes you can prevent it software wise, but there is no communication between the M2 and the hardware, so therefore you cannot stably do it with what you have.
The M2 is the el cheapo unit of the CarPC world and everyone knows it. It works brilliant when you use it as it is supposed to be used.
Jokes thread Cris Off Topic 223 05-03-2007 12:24 AM
Wtb :: M2 Atx Dc/dc Psu !!! CoupeE46 Classified Archive 0 01-28-2007 04:06 PM
M2 ATX - EN15000 - USB - Problems! BulleDK Power Supplies 16 12-28-2006 04:29 PM
Problem m2 atx and 3.5" hard drive Mitski's Rider Power Supplies 2 10-05-2006 12:52 PM
M2 ATX Manual lanman1 Power Supplies 2 08-16-2006 02:28 PM
