The MP3car.com Store
Thread Tools Display Modes
Old 03-20-2007, 10:59 AM   #1
My Photos: (0)
Setup Question for CarPC Power
Hello all,
I have a new (Old Machine) Dell Desktop I want to use for my CarPC in place of a Laptop I am using. I have the Daskwerks (http://www.dashwerks.com/dw_dssc.php) Startup/Shutdown controller, which I have no issues installing and getting to work. My Main question is the best way to power the Desktop PC. I have a car power inverter that I was going to hack up and use to power the PC with. I did notice that when I plug my laptop in, I get a ground loop that causes a nice hum. I am curious if anyone else is using this method to power their CarPC, and if so, do you suffer this issue. I also wonder if grounding it to the car frame, or using the negative terminal off the batter will help eliminate the ground loop, and stop that hum. I am a little short on cash, otherwise, I would just buy the proper power supply... (Which I will, once I make settlement on my new house).
Thanks for your advice/suggestions.
Cheers,
Rob
robsch is offline   Reply With Quote
Sponsored Links
Old 03-22-2007, 07:30 PM   #2
billmee's Avatar
Vehicle: 2002/VW/Jetta Wagon TDI
My Photos: (4)
Rob,
Your inverter is probably not passing any ground to the pc, mine doesn't.
If you open the inverter and look at the ground connection it is probably just a floating piece of metal. If this is the case you could connect the grounding pin of your ac cable to the chassis of the car. This worked for me.
billmee is offline   Reply With Quote
Old 03-23-2007, 08:47 AM   #3
My Photos: (0)
I checked it out this morning, and you are correct. No more Hum! Thanks dude!
Cheers
__________________________________
The NEW Design : 90%
The NEW Install : 2%
The Aspirin : Alot!
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Power Supplies Explained (Part 1) Bugbyte The FAQ Emporium 14 06-10-2007 07:45 AM
Newb question about power from a Molex dsballer2000 Power Supplies 7 06-24-2006 11:32 PM
PW80 power question Moneyfink Power Supplies 3 06-30-2005 07:15 AM
Power question... tangeray Newbie 9 06-10-2005 06:52 PM
Controlling your power setup remotely auto_robotics Power Supplies 7 10-08-2004 07:05 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
