03-21-2007, 11:33 PM
#1
Well, He asked for it.
Vehicle: 1988 Jeep Cherokee 4X4, 2005 VW GTI 1.8T - SOLD
Athalon XP 3000+ and M2-ATX
I currently have a Via MII 10000 ruing street deck but am thinking about upgrading to my shuttle mobo with a Athalon XP 3000+ and a 1u server heat sink.
Will the M2-ATX be able to power a Athalon XP 3000+? Would under clocking it help?
2005 VW GTI MKIV - SOLD
03-22-2007, 04:35 AM
#2
Vehicle: 2002 Mux'd 206 peugeot
Bang ! Athlon XP3000+ is rated at 45A @ fsb=333 & 41.4 A @fsb=400
good luck using a M2
Buy a geode NX 1750 cpu instead.
Now Galileo is real. Muhahahahaha :p
03-22-2007, 06:19 AM
#3
Neither darque nor pervert
Vehicle: 2003 Toyota Tacoma X-Cab
Theoretically, is will work, however you're going to have very little power left over on the 12v rail for other devices.
If you run the system with a laptop HDD, I'm pretty certain it would work.
My Worklog
03-22-2007, 06:30 AM
#4
You're probably batter off using the opus 250 or the 320.
05 Acura TL
CarPC 99.99% Done
03-22-2007, 07:00 AM
#5
I run an AthlonXP mobile 2400+ on a Shuttle FN41 with a 1u heatsink. IT's powered by a DSATX and runs just fine, with lots or pwer to spare. Granted, I'm running a mobile processor.
I would try to latch onto an AthlonXP mobile CPU, assuming you can find one. They use less power, which is what you want in the car. They also generate less heat, which is another benefit in the car.
I agree with KingofCoronoa that a higher-rated PSU would be a good idea. I think the 320w Opus is probably overkill. The 220w DSATX or the Opus 250w would most likely serve you well. Just go easy on the video if the Shuttle doesn't have it onboard.
My Worklog
03-22-2007, 10:58 AM
#6
I think its the same board you have the dual vga...
right now i have the via, laptop hdd, lilliput, gps, amp turn on, powered by it.
I'm going to power it up when in the house and see what options i have for under clocking it.
03-22-2007, 11:43 AM
#7
I also have a old system with a 900mhz Duron cpu do you think that would be a better option? i bet even though its slower then my current system it would be faster...
03-22-2007, 11:56 AM
#8
MySQL Error
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
The Athlon 3000+ will EAT the M2-ATX alive with smoking flavor.
You will be better off with the DSATX or the 250 Opus.
My Matrix setup on the DSATX barely make it on the 5V rails.
03-22-2007, 06:54 PM
#9
looks like im just gona get a Jetway AMD Geode 1.4 GHz 533FSB Mini-ITX Motherboard since i can use the PCMCIA board on it...
03-22-2007, 10:43 PM
#10
I'm running a Sempron 3300 with an ASUS K8V-VM off an M2-ATX, with a samsung 2.5" 80gb, and have had not a single problem. I believe the Sempron probably uses less power than the old Athlon XP though.
This CPU/MB combo was DIRT cheap here, $130AUD brand new.
| Thread Tools |
| Display Modes |
Linear Mode
