Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Product Suggestions for the Mp3Car Store
Old 07-08-2009, 02:22 PM   #1
thekl0wn's Avatar
thekl0wn is on a distinguished road
Fabrication Items...
I've noticed in the fabrication section, there are some common items that people are always asking about, and no cheap solution is currently available.
The first item that comes to mind are simply USB slots... Getting small slots cut into a piece of ABS/PE/PP/ACR is simple for a laser/CNC. However, not everyone has access to this. However, if a simple USB plate were offered, most have the skill to either weld in flush or modify it as a separate bezel.
Planning [----X-----] 40%
Programming [-X-------] 20%
Parts [-----X----] 50%
Install [X--------] 5%
See Me In A Pink Skirt
thekl0wn is offline   Reply With Quote
Old 07-08-2009, 02:43 PM   #2
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
Good idea!
I purposely bought all my connectors with faceplates on them with the intentions of cutting out chunks and welding them into my plastic bezel to avoid cutting my own holes.
Somebody should design a one-off piece of plastic with a bunch of holes in it, like a big sheet. Run a few hundred of those and let people buy them and cut out what they need!
It could have a bunch of USB holes, some audio connector holes, ethernet, VGA, whatever shapes people might need.
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 07-08-2009, 02:49 PM   #3
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
i've got the USB cig lighter replacement from mp3car and that works well for me. I've also in the past bought PCI usb hubs and unscrewed the binding post so that you have 4 ports easily mountable.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 07-08-2009, 04:17 PM   #4
trader007 can only hope to improve
this is a very easy way to go. i have 2 port brackets in a box from old motherboards ive bought... if i didnt have the capability to custom fit my own stuff they would make a very easy way to add some usb ports say inside a glovebox or ashtray...
trader007 is online now   Reply With Quote
Old 08-13-2009, 05:25 AM   #5
Vengaemilio is an unknown quantity at this point
good!! thanks
Vengaemilio is offline   Reply With Quote
Mp3Car Community Innovations - Best of Dash Fabrication - 10/03/08 Heather Mp3Car Blog Talk 4 10-08-2008 11:57 AM
Fabrication advice HNaga Fabrication 2 08-17-2008 05:52 AM
Deville DTS, Monitor Fabrication, -Nexson (Pics) Nexson Fabrication 27 07-16-2008 09:31 PM
Custom Fabrication Work? mattdisaster Fabrication 21 02-01-2005 12:37 PM
