The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Thread Tools Display Modes
Old 06-18-2007, 12:35 AM   #1
DodgeCummins's CarPC Specs
DodgeCummins's Avatar
Vehicle: 96 Dodge Ram 2500 Cummins Diesel (turned up)
My Photos: (20)
Hardware Review: Soundstream Rearview Camera
I bought this one right after I bought the other one I reviewed...thinking that this one would be better.
I bought this off ebay, prices range from $95 plus shipping (ebay), to $319 (woofersetc.com). I am reviewing it because of a large lack of rearview camera reviews here...this will allow the shopper to see what features he should look for in a camera etc.
Soundstream VLP-1C
* Ultra mini sized rear view car camera with top of the line image quality
* water, fog, and dust resistant
* One chip package
* Wide angle lens - 150 Degrees
* Installs on any license plate (Universal)
* Damage and scratch resistant
* Back-Light compensation circuit automatically adjusts camera to the light (only found in high end models)
* Views up to 70 feet in back of you
* Compatible with all car monitors
* Easy to install
* 1/3" CCD 1 LUX Low Light Color Camera
* Multiple Camera Angle
* Din Connector & RCA Outputs
* Reversed Image
My impressions...
In daytime it gives a much crisper view...and a bit wider angle than my other one.
However at night it is not as good as the other one.
The big drawback for me is the electronics to run the camera are in an non-weatherproof box with small wires to the camera. This unit is designed to be installed into a trunk or hatchback...not the back end of a pickup. The camera itself is waterproof.
The way you install it is drill a hole for the camera mount to slide through (don't need to use their plastic frame), bolt it in place with a rubber washer to seal the hole, then plug it all in.
It comes with about 20' of cable that houses the electrical power and video signal...you can power the camera from either end of the cable. (front of vehicle or back)
(note the white mark on the camera indicates top)
Day shot. (note these are taken at exactly the same time as the other license plate camera I reviewed)
Night view (here is where the camera suffers a bit)
Like I said, these screen captures and the ones for the other camera were taken at the same time with the same lighting...and me pushing the trash can in the night view.
Oh, and I don't need this camera, so I am putting it up for sale...cost me $100...make an offer if interested.
current projects
DodgeCummins is offline   Reply With Quote
Sponsored Links
Old 06-18-2007, 09:40 AM   #2
My Photos: (0)
Thanks for that helpful review, from what I can tell the picture is not clear I may be the camera shot? may be
question here, can you do a screenshot on windows instead of taking a picture with a camera?
thanks
Octavio is offline   Reply With Quote
Old 06-18-2007, 09:47 AM   #3
Cheekz185's CarPC Specs
Vehicle: 2002 Mitsubishi Galant
My Photos: (0)
hey thanks for the reviews... I bought an MP3Car backup camera but I cannont install it for technical reasons. SO i am leaning towards buying a license plate backup camera. Has any1 tried this one:
http://cgi.ebay.com/License-Plate-Re...QQcmdZViewItem
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 06-18-2007, 12:38 PM   #4
My Photos: (0)
That's to much ... you could find better thing here check it out
http://www.sonicelectronix.com/cat_i...w-cameras.html
Old 06-22-2007, 08:19 AM   #5
My Photos: (20)
For all the recent review pictures, two for this camera, and the last two for the other camera, I used my digital camcorder to capture an image directly off the camera.
A photo of the display can be seen in the other review.
So no, the camera does not get any better than that.
current projects
Old 10-23-2007, 08:10 AM   #6
My Photos: (0)
I know I'm late in posting (don't get on here much) but I just wanted to thank you for your time and efforts in creating this review. It is very helpful when considering a purchase and helps to keep the rest of us from having to go through the search and experiment phase. FOr me that is worth a LOT.
Thanks again - for BOTH reviews.
Truck PC about 90% done.....Most of the work lies in mounting the LCD (as usual).
'04 Chevy 2500HD 2.4g P4 ATX, Display = 10.4 inch Samsung TFT/LCD
Live on the edge, but first, learn good balance.
rex6000 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Hardware Review: ElmScan 5 ODB-II scanner with StreetDeck RedGTiVR6 The Review Palace 16 08-03-2008 07:13 PM
EASY rearview camera support (w/ a little help) Custommx3 MediaCar 120 01-21-2005 05:40 PM
Multiple Hardware Questions (camera, DVD...) GMCVOY General Hardware Discussion 0 07-25-2004 02:45 AM
Is non-IR rearview camera visible at night with reverse lights on? hd54321 General Hardware Discussion 6 07-23-2004 03:21 PM
Building a digital camera from flatbed scanner hardware magnetik Off Topic 4 05-06-2002 02:21 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
