Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Old 07-09-2007, 02:41 AM   #1
Dingo509's Avatar
Dingo509 is on a distinguished road
Thumbs up Hardware Review: Mobile Computing Solutions Mini-ITX case
What it is/does: Holds the parts needed to make a computer?
Reviewed by: Dingo
Manufacturer: Mobile Computing Solutions Please read Manufacturer comment below
Model: Black Aluminum Mini ITX Car PC Case
Specs:
Dimensions: 10" x 9.25" x 3.125"/254mm x 235mm x 80mm
Weight: 1 kg/2.2 lbs
Color: Black with light grey logo
Hard Drive Support: 1 x 2.5 inch
DVD/CD Drive Support: None
PCI Expansion Slots: None
Power Supply: 80 watt 12Vdc to dc Listed as a 80w but mine shipped with a 120w
Case Ventilation: 1 40 x 40 x 10mm fan
Mounting Position: Universal
Compatible with both the M1/M2-ATX power supplies
Price: $69.95
Rating: 9/10 See other notes
Manufacturer website: www.mo-co-so.com
Purchased at: Ebay.com
Pros: I think the best thing about this case is the height. It comes in alittle over 3". this gives more room for airflow inside the case and more room for cables. Otherwise it's very close in footprint to the Zoom case. I haven't tried yet but i think you could get a HQCT and a OEM GPS module both inside this case. Of course that would restrict the airflow. Another think i really like is the mounting of the components, they are all mounted a single sheet of aluminum that then slides into the case. And this case allows for that board to be inserted either rightside up or upside down. It ships with three end plates; One sealed end, and 2 open ends. One for either way you want to mount the Board. See pictures at bottom. Comes with a 120w power supply.
Cons: The size may be an issue for some. The case is not extremely heavy built. but let's face it it's not a stair step, it's a computer case. the power supply i thought was a nice touch, but in the end it's not going to work, main reason? it does not have a Startup/Shutdown controller integrated. Would work great for bench testing though. And possibly as a 5 volt PS for a USB hub?
Other notes: My main concern initially and the reason for the 9 out of 10 rating, is this unit's lack of cooling fans/options. As you can see in the pics it has one 40mm fan and the exhaust port is directly acrossed the case from the fan inlet. This is at the same end as the I/O connectors. This leaves the processor sitting in what i feel is stagnant air, apparently this works though as they sell complete carputers with this setup. But i wanted more, so....
due to the smooth sealed endplate construction, I think i will be able to mount a couple 60MM (or larger?) fans. This will require you to cut and modify the end plate, but come on, if your putting a computer in a car, what's a few holes. In my application (Offroad vehicle in heavy dust/dirt) i felt that this was the best option, as this way i can install 2 or 3 fans with filters to the otherwise sealed end, thus creating a "possitive pressure" inside the case. This will allow the inlet/exhaust ports to now both be outlets, and the positive pressure should also help to impead the amount of dust coming in around the connections. The fans will have to be mounted externally, but will also aid in cooling the HD. I will post pics of this in my build log, once i do it.
Manufacturer comment: I have dealt with alot of different companies while i managed a offroad store, over 250 total. and almost everyone of them i had to contact at one point or another regarding a warranty or defective item. So after dealing with all them i thought customer service was a lost art.
I was wrong Chris at MCS has been in almost constant contact with me since this case arrived. The first power supply was dead. and with being a newbie to the carputer scene, there was a few things that didn't make sense to me. Chris has been able to answer every question i have had, and usually emails back within 12 hours. yes, 12 HOURS, no more waiting for weeks for a response. He has also taken calls from me after hours when he sounds to be at home. And after discussing the dead power supply and my requirements he suggested a M2-ATX and offered me a deal i couldn't refuse.
Final thoughts: Very good case for the price. Case has lots of potential for modding. Shipped power supply usability questionable. Customer service 12/10 unbelievable!
Pictures:
Dingo
Progress: 3.6% Finished (still learning the basics) total parts.... 3. Total invested so far.... $145
91 Jeep cherokee 8" custom lift, 3/4 ton running gear 36" swampers, GPS, Onboard air, Onboard Shower
Dingo509 is offline   Reply With Quote
Advertisement Sponsored links
Old 07-09-2007, 10:51 PM   #2
mrbean_phillip is on a distinguished road
Nice review, thanx - I am keen on getting one of these for my Commell LV-677 mini-itx board, nice compact footprint.
On the plus side, it looks like a small Amp, so thieves probably won't be to interested.
Keep us posted on your project, looks like it's going to be a good one
edit: After taking a peek at the shipping options, I guess I'll have to pass. $124- US for expedited shipping to Australia is just to much to make it a worthwhile solution
mrbean_phillip is offline   Reply With Quote
Old 11-21-2007, 09:58 PM   #3
deeznudts's Avatar
deeznudts is an unknown quantity at this point
Great review! Thanks for helping me to make a decision. Whats an onboard shower? Sounds luxurious.
deeznudts is offline   Reply With Quote
Old 11-21-2007, 10:07 PM   #4
Dingo509's Avatar
Very luxurious, at least when your camping. What it does is pump water out of a lake, stream, bucket or whatever, heats it up using the engine heat, and pumps it out the side. so as long as you have a water source and the engine stays running, you have unlimited hot water.
Before you order check out the new Gen2 case. last time i checked it wasn't listed on the website, but is in the ebay auctions. It has a molex power plug and an a pair of USB plugins in the case. I'll be talking to chris soon to see about upgrading mine.
Dingo
Old 11-22-2007, 10:36 PM   #5
Kosti is on a distinguished road
Actually I think there's a 3rd gen available ?
http://cgi.ebay.com.au/3rd-Gen-Black...QQcmdZViewItem
Parts list - in AUD$
Lilliput 629 $270 | Hitachi 5400RPM 80G $92 | PIO DVR-K05 slot $95 | AYAY SIR Quad port GPS $160 | DSATX 220W PSU $205 | Mechatroniks Bezel $186 | Kino-9453 MB $380 | A-Data DDR2 667 2Gig $140 | 2 X CCD Cameras $180 | HQCT -e $140 |
Kosti is offline   Reply With Quote
Old 11-22-2007, 10:38 PM   #6
Dingo509's Avatar
Yeah that one! I new it was a newer version, just forget the number. Good catch.
Dingo
Old 11-22-2007, 10:50 PM   #7
deeznudts's Avatar
Thanks for the heads up. Thats actually the one I just bought. Can't wait to start assembling this system.
Old 11-23-2007, 06:35 PM   #8
make sure you take heaps of pix
Old 12-05-2007, 07:57 PM   #9
RS3RS's Avatar
RS3RS is on a distinguished road
Hmm... That's pretty cool, I've got to say! Thanks for the review
My blog on supercars and stuff
RS3RS is offline   Reply With Quote
Old 12-05-2007, 09:22 PM   #10
Dingo509's Avatar
I ordered a few more parts from Chris at Mo-Co-So.com and also ordered the endplate and wiring for the new 3rd gen case. If you have the old Case call and him and ask about the newer end plate. It's worth it.
Some features of the new endplate design include a 6 pin Molex connector. I can only see myself using 4 of the 6. Power, Ground, Ignition, and amp turn on. The 5&6th wires are Probably for 12v and 5v out. Which is a good idea, but the most common thing that is powered from 12v is the monitor so Chris also included a 12V power/ground cable that mounts with a coaxial plug on the case. This plugs into the included 13' power cable to plug directly into the monitor.
So with these changes to the endplate and the bigger cooling vents, and larger 50MM fan in the new case design, This case now is even better and worth a look.
Dingo
Old 12-06-2007, 08:25 AM   #11
Mini Sumo is an unknown quantity at this point
I've had this case for over 6 months and just love it ! And I agree Chris is a stand-up guy and will resolve and help any issues you have.
Dingo :-) Nice Cherokee ! Do you belong to a Jeep club out there ?
I use to belong to Blue Mountain Jeep Alliance here in Reading, Pa .. But with the price of gas I sold all my jeeps :-(
Had a '99 Wrangler, 35" MTR's, d30 front with ARB, Superior d35 rear with ARB, Kilby on board air with a compressor I pulled from a AMC Eagle and lots of other cool mods. WIth that I had a '01 Dodge 2500 Diesel with 19' Trailer to tow it around on, and a '01 Jeep Liberty on 32" MTR's. I miss my Jeeps and all the fun wheeling :-)
Now I'm down to just my '05 Precision Cycle works Detroit Chopper, '02 HD Sportster and my Toyota Yaris.
Check out BMJA.org if you want to check out a cool jeep site. They are the largest Jeep club on the east coast.
Mini Sumo Was Here
Mini Sumo is offline   Reply With Quote
WTB mini ITX CASE and DC -DC PSU Darkstar757 Classified Archive 2 09-04-2006 03:38 AM
Mini itx case Cris General Hardware Discussion 36 06-29-2004 07:12 PM
cheapest mini itx case? aoLhaTer General Hardware Discussion 15 05-14-2003 05:28 PM
found a car adapter for mini itx case! e36mp3 General Hardware Discussion 7 08-04-2002 05:06 PM
