04-22-2008, 07:59 PM
#16
Voltage out is 12 steady and 4.95 on the molex which powers my hub. My USB problems are even on the mainboard, so can that be a PSU problem too?
04-23-2008, 09:59 AM
#17
Well, just to update about chris at mo-co-so.com. I finally got in touch with him which had to be through a phone call, but he was understanding of my problems. I asked to swap the Jetway MB for an intel celeron instead even though the celeron is much cheaper than the jetway. I had enough of the problems with jetway and decided to cut my losses before I wasted too much more of my time. He said he can do it no problem and we can figure out something for the difference. Lucky for my I am local and can stop by this afternoon. Besides the lost emails, Their customer service has been pretty outstanding so far if you get them on the phone. Perhaps they are just growing a little too quick and its hard for them to keep up with emails? Regardless, at least they are standing by their products.
04-23-2008, 04:23 PM
#18
Vehicle: 2007 Scion Tc
Quote: Originally Posted by jjakes24
I am still having a ton of trouble with my USB ports on this system. I have the bluetooth and wireless internally installed. I then have the 2 main USB ports and two others installed. I try connecting my DVD drive directly through a 10ft cable and my touchscreen through a powered hub which is directly connected to the PC through a 15ft active USB. All seems fine for a little while until the touchscreen stops working and then I can't read from the DVD drive anymore.
I have a mo-co-so puter. Same as Dans, and I've had similar probelms. First of don't power your touch screen through the bus powered USB hub. It has a tendency to stop working, there are many posts on this. I've had similar problems with the DVD drive. I tried the active USB cable and a couple others. I found that the short cables worked, but the long ones didn't. I went out to best buy and bought a 10' gold plated geek squad cable, and it works fine. I don't know how much better that cable is than the others, it's kind of pricey. But it's been working now for 4 months.
On another subject, has anyone installed additional case fans on one of these? I have mine in a concealed space and it got damn hot today, up around 180 F according to the bios temp. reading. Would love to know how you did it if you did.
99% complete. MP3car.com Bluetooth Dongle where are you????
04-23-2008, 07:15 PM
#19
^Im guessing its your cpu temp thats running that high? I have the same mocoso case, but I am running a low power epia m10k system. Cpu temp is about 40C during the winter, which is not bad considering that the ventilation on this case isnt the best. Dont know what the temp will be when summer hits. The problem with this case seems to be that the air is blown across only the hard drive and power supply, but the cpu fan and the rest of the motherboard is sitting in stale air.
Unless you take off the two side panels, there really isnt anywhere to add fans. You would have to drill a fan hole into the case, preferably on the top of the case (I think you might have to mount the fan externally, there is no room). I couldnt find any hole saw adapters for my drill large enough for a 80mm fan, so Ive put off putting a fan on my case.
04-23-2008, 08:10 PM
#20
Vehicle: 2004 Nissan 350Z
I use the 2 onboard USB ports for Soundblaster live 24 (DVD originally) and Touchscreen. The 2 header usb ports power XM and GPS. The other 2 header (I added another) usb ports are a 7 port hub, (iMon Ultrabay, something I can't talk about, single external cable, and DVD now since I built it into the imon and it doesn't do as well) and the OBDII. Internally, the usb ports are bluetooth and wireless. THEN there is a PCMCIA 4 port USB hub (powered by the PS2 connection), it powers the EVDO (2 ports), Andrea USB mic, and one port open for jump drives.
As for the temp, I drilled a huge hole directly over the CPU (about 2" diameter), covered the case in fiber screen (yeah, home depot porch screen), and then attached a 2" fan that runs off the ignition. Temp isn't a problem and the computer is in the glovebox.
Hope that helps!
"Do not walk behind me, for I may not lead.
Do not walk ahead of me, for I may not follow.
Do not walk beside me either.
Just pretty much leave me the hell alone."
--unknown--
04-23-2008, 09:10 PM
#21
Thanks for the suggestions I might do a little of both depending on the results I get. It was like 80 degrees outside temperature today. It was the CPU that got that hot 180 range. The puter even froze at one point. It's located in my hatchback inside a covered Styrofoam tray (came with car) under a particle board flap in all black interior. The case was mighty hot to the touch today, so i'll have to do something quick. Summer is right around the corner. Dan I see your in Texas. I'm guessing the weather there is just as hot if not hotter. What temp. readings are you getting with the additional fan. I've been looking at some case fans, and I think I'd like to hook them up to the battery on a switch. I see most case fans are three wires. Did you connect the two wires to the positive and the one to the negative for yours wired to the ignition? Thanks again.
04-23-2008, 09:32 PM
#22
I run 3 busses under the panel in the glove compartment. 1 Buss is Ignition 12 volts, the other is 12V constant, and the third is ground that goes directly to the frame. So the fan uses 12V ignition and pretty much frame ground. Temps run around 120-130 with the door held open by the EVDO device (the antennae folds out and I hang it on the top of the door). Really not much difference to the computer with the door open or closed, but when it's closed, I wouldn't put a snickers in there. lol (There is a BIG difference in the temperature of the compartment). I have 4 other small fans I was going to put on one side of the compartment to blow the heat into the adjoining compartment (subwoofer), but haven't seen a real need yet.
Edit: Be careful following those directions. I am pretty sure that my XM Radio engine noise is caused by that fan and not the engine. I have been kinda busy and haven't verified that (it can be easily unplugged). I'll check tomorrow and report back.
--unknown--
04-23-2008, 09:48 PM
#23
But you can toast your bagel on your way to work. Thanks for the heads up. I think I'll give it a shot this weekend. I think this is the first time I'm hoping it doesn't hit 80 here anytime soon.
04-24-2008, 10:00 AM
#24
Touchscreen was not going through a bus powered hub, but instead a powered one. Doesn't matter anyway, I already gave up on the board. Thanks for the info anyway.
04-24-2008, 10:03 AM
#25
I know it's tough when things don't work. I've been there. But one of the reasons I wrote the review was more because of customer service, not the computer itself. Heck, anyone can build something and it not work. It really depends on what happens next that defines a company.
Chris will take care of you (or I'll delete all my posts Chris!). lol
He's a good guy. Just take a few breaths and start over.
--unknown--
04-24-2008, 10:43 AM
#26
Engine whine is magically gone, so never mind. lol
--unknown--
04-24-2008, 01:06 PM
#27
Yeah, he already has taken care of everything. Thought I mentioned this but I met up with him yesterday and he is replacing the motherboard with the 1.2 celeron as I type this. I couldn't ask for any more in ways of customer service. I just told him I was fed up with jetway and just wanted to go with a different brand and he was completely understanding about it. I never blammed mobile computing solutions for my problems, rather jetway. I just wanted to make sure people know about the problems with jetway's c7's.
04-24-2008, 01:21 PM
#28
You did mention it. I'm just slow on my responses. Lol
05-11-2008, 09:59 AM
#29
My cpu just hit 70c+ after 3 hrs driving on a road trip. The trunk where my case is located was stuffed with luggage (so poor ventilation).
So now I am thinking about mounting an 80mm fan to the surface of the case. But I think the hole saw would just make a big mess from the heatsink-ish extrusions from the case. Maybe I will just end up improvising some type of cardboard ducting so that the cpu fan draws cool air directly from the outside rather than circulating the same inside stale air.
Anyone have any pics of fans added to their case?
05-11-2008, 08:39 PM
#30
I got this turbine fan from newegg, about 5 bucks I think. I cut a hole in the plate on the side near the PS. I have it blowing air into the case. I'm debating rotating the fan that came with the case 180 degrees to provide an exhaust. The hole was a ***** to cut, and I glued it on with gorilla glue which has been rock solid so far.
As you can see in the image the CPU is in a storage compartment in the trunk, I've added another fan to the flap to bring cooler air into the compartment.
I also am debating using that one as an exhaust, but it dosen't look nearly as cool upside down as it does right side up. I think the objective is to keep air flowing across the PS and chip, which I am curently not doing. Just blowing a bunch of air in. So far I've topped out at about 114 F (45 C) process, maybe 100 F (37 C) system on about a 2hour trip with 75 F outside temp.
If it gets much hotter I will turn around the case fan that came with, flip the one in the flap, and cut another hole in the flap to provide air to the turbine.
Hope this helps, There are a couple ideas further up the post as well....
| Thread Tools |
| Display Modes |
Linear Mode
