Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Old 01-10-2008, 06:51 PM   #1
SD beats everything. So there.
danielkh's Avatar
danielkh is an unknown quantity at this point
Hardware Review: nVIDIA GeForce FX5500 256MB PCI Video Card FX 5500 V29
FrontEnd: StreetDeck
Computer: Listed in profile
Video: nVIDIA GeForce FX5500 256MB PCI Video Card FX 5500 V29
EBay: $40
______________________________________
My company switched phone carriers which allowed me to go from PCMCIA card to USB EVDO. By doing that, I was able to remove the PCMCIA daughterboard and BAM!! Room for a video card!
If there is any way for you to put this card in your carputer, it is more than worth it! EVERYTHING is so much faster. Navigation screens load faster, screen changes are great, even the visualizations in the background of StreetDeck run flawlessly.
I did have to modify my case, even having to break out the dremel, but it was well worth the effort.
If you are at all tired of slow responses in your FrontEnd software, this is the answer! The reason I went with this particular card was price vs. ability. A Geforce card for $40 with 256mb is hard to pass up.
danielkh is offline   Reply With Quote
Old 02-07-2008, 11:40 AM   #2
Autockr989 is an unknown quantity at this point
EBay: $40
Do you have any issues with crashing? I find my system crashes which i'm assuming this is because the cpu is bogged down at 100%. I was going to just drop this MOBO, but if the new graphics card will resolve my issues then i can hold off. Any input? Also, what codec packs do you use? Also, I've been reading that this card requires 250Watts. how are you powering off a M2-atx 160w?
Autockr989 is offline   Reply With Quote
Old 02-07-2008, 06:58 PM   #3
danielkh's Avatar
What front end? 1.1.1.0 streetdeck crashes constantly, but 1.0.9.8 is extremely stable and no crashing. Check your ram. I had crashing originally, but found the ram was bad. Turn on full test in bios.
My opinion is my own.
Old 02-27-2008, 12:09 PM   #4
Ineffigy is on a distinguished road
Here's a nice list of video cards and their tested power consumption. Unfortunatly, the GeForce 5500 FX is too old for the list.
http://www.codinghorror.com/blog/archives/000662.html
Ineffigy is offline   Reply With Quote
Old 10-19-2008, 04:26 PM   #5
muncher is an unknown quantity at this point
problem with fx5500
Ho. I cant seem to get the fx5500 working on my 7inch wharfdale. whatresolution do i set the tv (svideo) to for the screen to work?
Thanx in advance
muncher is offline   Reply With Quote
Old 02-24-2009, 03:45 PM   #6
coach is on a distinguished road
800x600 or 640x480
Now, GO GET A VGA monitor!
Brent
1999 Nissan SE-L - turbo toy
1993 Nissan NX - Turbo Racer
Standalone fuel management (AEM EMS) on both
carPC
coach is offline   Reply With Quote
Old 10-05-2009, 08:53 PM   #7
diggla is an unknown quantity at this point
i bought a video card that needs 250 watts, but only running the m2-atx. how did you get your card to work?
diggla is offline   Reply With Quote
Old 10-06-2009, 02:20 PM   #8
Which video card did you pickup that requires 250 watts?
Software Developed:
DS-ATX Controller Interface
Laptop Shutdown Controller
Considered Projects:
TPMS Interface
Bluetooth Handsfree Interface (WIDCOMM/BROADCOMM)
Old 10-06-2009, 04:19 PM   #9
PNY PCI graphics gforce 5200
Old 10-06-2009, 06:37 PM   #10
That card comsumes between 10~15 watts of power. You should be fine as long as you don't overload any of your rails. There's a guide on here somewhere that can help you with making sure you have enough power.
Software Developed:
TPMS Interface
Old 10-06-2009, 07:21 PM   #11
hmmm, i'll have to check and see why it wouldnt work then. Had video on the onboard vga
Old 10-07-2009, 10:39 AM   #12
Please describe what occurs before it fails. No Post No Beep, Doesn't display in Windows, etc, etc. It'll help determine if this is a power issue or not.
Personally, I have a 220 watt startup/shutdown controller using an 8200 video card and it runs just fine. The card may be just seated inproperly or the motherboard might have a special port on it for P.O.S. systems. Alot of the industrial motherboards have them and you have to tell it to use AGP/PCIE instead.
EDIT:
Software Developed:
TPMS Interface
Looking for Low Power Consumption PCI Video Card Geese LCD/Display 4 11-10-2004 08:54 AM
PCI Video card not working TX5 General Hardware Discussion 9 10-10-2004 11:56 PM
Good PCI Video Card for 800x480 veetid Software & Software Development 11 06-14-2004 01:48 PM
need PCI nvidia video card with Conexant TV chip Onyx General Hardware Discussion 2 11-12-2003 04:14 PM
EPIA hardware decoding gone with PCI video card? tbdombrosky General Hardware Discussion 5 03-27-2003 05:46 AM
