Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Old 07-28-2008, 04:41 AM   #106
Jistari's Avatar
Jistari is an unknown quantity at this point
Well its been a few days. Put the key in, start the car, pc starts, things work. Life is good.
Good luck chamberlain, you must have got a good one
PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
Jistari is offline   Reply With Quote
Old 07-29-2008, 12:35 PM   #107
sneakfreak864 is an unknown quantity at this point
you spend a lot of time in your car, gotta long commute or you just like driving?
sneakfreak864 is offline   Reply With Quote
Old 07-29-2008, 01:09 PM   #108
Chamberlin's Avatar
Chamberlin is an unknown quantity at this point
yea I guess so! but remember, I had to buy 4 of them in the process! I still have an extra backup board too, hopefully I will never have to use it...(or should I say, 'deal' with it)
cheers,
-C
Chamberlin is offline   Reply With Quote
Old 07-29-2008, 01:27 PM   #109
lol i think i spend about 30-60 min in my car a day max
Old 07-29-2008, 03:09 PM   #110
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
LOL, same here, although my CarPC is set up to almost live in for days.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 07-29-2008, 04:01 PM   #111
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Anyone able to post up their operating temperatures for this board?
Using SpeedFan, I'm getting the following:
HDO: 47c
Temp1: 60c
Core0: 35c
Core1: 35c
It's also randomly shutting off on me....I'm not 100% certain on this, but it seems like once Temp1 reaches 60c and is there for a while, the system just shuts down.
Going into the system reports, I'm not seeing any errors.
This is the second mobo to do this to me as well....both the same motherboard, just different versions.
Anyone else have issues like this?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 07-29-2008, 04:08 PM   #112
Chamberlin's Avatar
Haven't put speedfan on this computer yet, but even here in 110+ AZ heat I haven't had any shutdowns...occasionally I will stick my hand in the glovebox to see how things are cooking, but I am always pleasantly surprised to find my fan arrangement is doing its job and keeping things under control. I did also install a Jetway CPU fan (Obviously, I had some extras!) on the other major heat sink (north bridge?) FYI. It has connectors for three fans, so why not use them. My third fan is a large one mounted to the back of the glove box which draws in air from the floor to the compartment. How is your MB installed?
Old 07-29-2008, 04:26 PM   #113
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
I deliver food. 4 to 5 hours a night worth of driving. Also my university is about 40 minutes away. So the CarPC is a neccessity.
Old 08-06-2008, 01:15 AM   #114
Jistari's Avatar
Sorry about hitting such an old post, but, just thought Id let anyone know who found this on search that all of the problems I had disappeared when I switched to another MB (wound up pulling the Jetway outlined by the OP and put in an MSI fuzzy gm1).
If you are having problems with this particular Jetway board, and want to compare notes, search on my name and you will see what was affecting me.
Glad to say that with the MB swap, it all went away, PSU works, nav works, display works.
Old 09-03-2008, 10:39 PM   #115
JackB's Avatar
JackB is an unknown quantity at this point
Just wanted to chime in... I bought one of these things months ago and I just pulled my system to switch over and I'm getting the exact same thing. Oh well... Looks like the Fuzzy is getting another customer.
JackB is offline   Reply With Quote
Old 01-13-2009, 03:18 AM   #116
VorTechs's Avatar
VorTechs is an unknown quantity at this point
I know this is an old thread (but post when I bought and was using my JF92) but I've started having the same problem. The exception here though is that my motherboard worked fine on the bench for months and months. When it was finally time to install in the Car, wired it up... it seemed to boot twice (no VGA output but the BIOS beep could be heard) and since then... nothing.
Can't get it to boot at all. It powers up, and down fine (shorting the power switch pins) but other than that.. nothing.
KimmyBean> Stu, you know that cybersex we had?
KimmyBean> I'm pregnant!
VorTechs is offline   Reply With Quote
Old 01-13-2009, 03:39 AM   #117
VorTechs's Avatar
I got it working! *phew*
It was a combination of 2 things to get it working:
1) Clear CMOS, remove the processor, remove the RAM and power up. Re-plug in the processor and RAM and power up.
This gave me a BIOS beep as before... but no VGA.... so then:
2) Leaving a power supply connected to the motherboard but switched OFF, cleared the CMOS
...rebooted and now it's all working again!
I wonder if it's all down to the CMOS process not being right, and the mobo needing the PSU connected for some bizarre reason!
Old 01-13-2009, 10:08 PM   #118
Chamberlin's Avatar
I just think this board has a bad time initializing video through the BIOS/CMOS.... Fortunately mine has been working A-1 top shape since my last good report here... too bad Jetway couldn't nail down this seemingly minor but disastrous flaw.
Old 01-18-2009, 07:35 AM   #119
gth
gth is an unknown quantity at this point
Specs once promised 4GB RAM?
It's definitely not re-assuring to read about all these problems *after* buying one of these. I've already gone through my own pain points in order to get this PITA to boot up (and I thought I'd done enough research *facepalm*).
Anyway, I'm curious if anyone else was led to believe this motherboard was capable of supporting 4GB RAM? There were several pages around that stated it (all of which seem to have changed now), and Jetway themselves have tried to 'up-sell' me recently on a new revision that 'will' support 4GB, but are not admitting to either myself or my local reseller that they ever promised 4GB support.
Lastly, has anyone received a slightly left-field revision of the motherboad labelled J9F2-KHDE-LF on the board itself? There's also a marking indicating REV 2.0 just near it. I don't get any Google results at all for this specific revision, although all the other types show up just fine (e.g. J9F2-KHDE-PB, J9F2-KHDE3, as well as the various EXTREME versions).
Anyway, definitely appreciate all the experience and effort shown - some of you have incredible levels of patience when it comes to faulty equipment, that's for sure.
gth is offline   Reply With Quote
Old 01-18-2009, 11:46 PM   #120
2k1Toaster's Avatar
4Gb of RAM is capable from the chipset, the motherboard doesnt support it. That could be what you are seeing there.
Jetway mobo's kamikaze2112 General Hardware Discussion 5 04-04-2008 11:05 AM
Jetway J9F2 Reboots / BSOD HyperZulu General Hardware Discussion 5 01-31-2008 10:20 AM
Core 2 Duo Confusion... Socket M/Socket P/Socket 479m for Jetway J9F2??? 2k1Toaster General Hardware Discussion 5 01-21-2008 01:32 PM
Fix for M2-ATX and Jetway! andrewb Power Supplies 22 09-16-2007 06:28 PM
Jetway AMD Geode NX1750 vs Commell LV-668 Orbserver General Hardware Discussion 1 10-13-2006 11:18 AM
