The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Thread Tools Display Modes
Old 03-02-2008, 10:09 AM   #16
ptk
ptk's CarPC Specs
Vehicle: 2006/VW/GTi
My Photos: (0)
actually I use this particular antenna. I use it with 54G Wlan, GPS and UTMS all at the same time. No issue. they are discreet antenna elements at different frequency range
this is my car pc. the 3 SMA at the left hand side are connector to the said antenna
CarPC Ver 3 near completion.
ptk is offline   Reply With Quote
Sponsored Links
Old 03-08-2008, 07:04 AM   #17
My Photos: (0)
would someone mind explaining to me how one might go about wiring this antenna (the one in the mp3 store) It appears it only has one cable to go to a receiver? I'm confused. Thanks in advance!
P.S. Does anyone have any stats on how this antenna compares on the wifi end of things?
My Work Log
nsgrossman is offline   Reply With Quote
Old 03-08-2008, 09:39 AM   #18
ptk
ptk's CarPC Specs
My Photos: (0)
nsgrossman:
there are 3 coaxial cables. not 1.
what kind of stats are u looking for? as in the dB? 0dB
it also depends on your WLAN card's output and if it supplies the bias voltage.
kao
Code:
Mechanical construction details: Dimensions (W x H x D) 81 x 45 x 42 mm (without rod) Weight 255 g Housing material PA6 Rod section 1 Rod length 50 mm Rod inclination 74° Installation Environmental conditions Temperature range -40° - +80° C Protection class IP66 (acc. IEC 60529) GPS Frequency range 1.57542 GHz +-1.023 MHz, (L1-band) Return loss > 12 dB Impendance 50 Ohm Current consumption max. 30 mA Gain typ. 2 dBic Amplification 24 dB +-4 dB Noise figure < 2.5 dB Voltage supply 3 - 5 VDC (remote fed) Cable type RG 174 Cable length 3000 mm Connector FME female CELLULAR Frequency range AMPS: 824 - 894 MHz GSM 900: 880 - 960 MHz GSM 1800: 1710 - 1880 MHz GSM 1900: 1850 - 1990 MHz UMTS: 1900- 2170 MHz Impedance 50 Ohm Load capacity max. 8 W pulsed acc. GSM standard Return loss > 12 dB Decoupling > 40 dB Rod wave 1/4 Rod gain 0 dB Cable type RG 174 Cable length 3000 mm Connector FME female WLAN Frequency range Bluetooth: 2400 - 2484 MHz IEEE Std. 802.11b: 2412 - 2484 MHz Impedance 50 Ohm Load capacity max. 1 W (acc. IEEE 802.11b) Return loss > 12 dB Gain 0 dB Cable type RG 174 Cable length 3000 mm Connector FME female
Old 03-08-2008, 09:40 AM   #19
ptk
ptk's CarPC Specs
My Photos: (0)
Old 03-08-2008, 09:57 AM   #20
My Photos: (0)
ptk thanks for the response. as far as stats I meant more along the lines of a test by a user. This antenna compared to a similar one made only for wlan, which one is easier to set up/wire, and which one works better/farther. Once again, thanks for the response!
Nate
My Work Log
Sponsored Links
Old 03-14-2008, 11:26 AM   #21
Blaz3's Avatar
Vehicle: .:: 97 Acura CL ::.
My Photos: (0)
any url's for that antenna ptk?
Blaz3 [|||||||||-] 88%
Blaz3 is offline   Reply With Quote
Old 03-14-2008, 06:07 PM   #22
Injector's CarPC Specs
My Photos: (1)
man do people even read anymore??
GO to the Mp3Car store.
Scion CarPC
Injector is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Tall Wifi Antenna EBFoxbat Wireless Communications 18 11-22-2005 06:43 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
