Quote: Originally Posted by zootjeff
Quote: Originally Posted by MatrixPC
Tested again this morning.
Drove 35 min from home to work. Pulled in the parking lot and shut the car off. Walked around and double check the PSU's LED if blinking or not. Yup it was blinking. Hit the "User Switch" button, nada. Hit again couple times, and nada.
Well this is why we have the beta test. Actually the documentation is wrong. It works just fine it is just the wrong pin!!!!!
USER_SW should be on D, SL_SEN should be on E!!! I'll update this drawing soon.
Now if you guys using this "USER_SW" option, double check the documentation/usermanual
again. After making change per Jeff's new instruction, it works like a charm.
ACC off, Press button to short USER_SW, PC goes shutdown/hibernate, PC off, couple seconds (2 or 3) later, power off.
