01-22-2006, 03:21 PM
#16
Vehicle: 99 Trans Am
Does anyone make a turn OFF delay? I want to turn off the amps, but have an x-over stay on a bit longer before turning off to avoid a noise.
03-10-2006, 07:50 AM
#18
Does anyone make it? I was looking for a built device.
03-10-2006, 12:29 PM
#19
Fusion Brain Creator
yeah, I could make you one
03-11-2006, 09:23 PM
#20
Has trouble reading.
Vehicle: 1991/diamante/mitsubishi
works halfway.
I cant say this device is worth every penny for me...
The n66a only works for me when I crank the engine, BUT when I put the key on just "acc" position the pop is still there and the a66n delay doesnt kick in for some reason.
Still havent figured out this problem.
10-18-2006, 03:00 PM
#21
Vehicle: 94 3000GT
I know this thread is old but....
I had the same problem with that device, only in reverse.....
when I don't crank the engine I have a delay....when I do crank the engine, no delay at all. I contacted David and he suggested I put a 1000mfd 13VDC capcitor in parallel with the input line and ground. When I cranked the engine for the first time after installing the cap I didn't have a delay, but since then it seems to work.
In hindsight I wish I would have built my own delay...alot cheaper and probably would have worked better. Here's a good one:
http://555-timer.clarkson-uk.com/operation/frames3.html
10-19-2006, 11:28 AM
#23
Vehicle: 94 3000GT
Thanks...I may give that a try.
First I am going to try and wire in a Pulse trigger relay and see how that does.
I still can't get that David Navone piece of crap to work....
I thought it was working with the cap soldered in, but it only works properly for a couple of hours until the cap discahrges....
so if my car is not running for a couple of hours and I start it up, the amp turns on immediately.
I wouldn't reccomend that product to anyone.
Biggest waste of money (and time) yet!
10-19-2006, 09:20 PM
#24
Vehicle: 2005 Ford Mustang GT
my amps aren't turned on until windows is up and thats the only time i want my music to work..... so it totally works and its free....
10-20-2006, 05:41 PM
#25
Vehicle: 94 3000GT
Thanks.... I may try that solution yet.
The main reason I was posting in this thread was to let people know not to buy that David Navone Turn on delay.
It's a total waste of money! Some people on here have had luck with it,
but IMHO it's a POS
There are much better ways to accomplish what that device is supposed to do!
11-03-2006, 04:42 AM
#26
Vehicle: 02 Mitsubishi Magna VR-X
I bought this item a while back and works like a charm no problems at all installing and functionally.
Mitsubishi Magna VR-X - Whitsundays, Australia
Continued Worklog... Upgrades in progress:
*15.4" WXGA LED backlight touchscreen upgrade
*Custom fiberglass dash bezel
*768 X 1024 Narrow RR Skin
http://bigs.omfg.net.au/
11-25-2006, 09:32 PM
#27
Good review. I will prolly be getting this just because I don't do that soldering stuff xD. 24 aint bad. What is +/- $8 bucks in a 1000$ computer
11-26-2006, 11:31 AM
#28
link dont work
01-08-2007, 07:29 PM
#29
Vehicle: 1995 Volvo 850 T5
Quote: Originally Posted by DJiK
What IC is this item based on, the 555?
Most likely. Way too expensive for what it is. I built mine for free from parts I had in the garage.
95 Volvo 850 T5 • Konis • ECU @ 17psi • 5+20% Tint • Orange Ambient-Light + LED Dash Lights • DigiMotive Dimmer • Custom LED Brake Lights • 2.5" BOSCH HID Projector Retrofit
Carpc: [▓▓▓▓▓▓▓] 99% Cleanup.
| Thread Tools |
| Display Modes |
Linear Mode
