Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Old 01-22-2006, 03:21 PM   #16
Does anyone make a turn OFF delay? I want to turn off the amps, but have an x-over stay on a bit longer before turning off to avoid a noise.
JasonWW is offline   Reply With Quote
Old 03-10-2006, 07:05 AM   #17
slightly old thread, but is this what you wanted ?
http://ourworld.compuserve.com/homep...tm#relay_i.gif
The Capacitor should keep the relay closed for a delay after the remote signal stops
Mazda 323 with XBOX based SQ system
Running Xbox Media Center
Dogo is offline   Reply With Quote
Old 03-10-2006, 07:50 AM   #18
Does anyone make it? I was looking for a built device.
Old 03-10-2006, 12:29 PM   #19
Fusion Brain Creator
yeah, I could make you one
greenman100 is offline   Reply With Quote
Old 03-11-2006, 09:23 PM   #20
Has trouble reading.
sanbas's Avatar
works halfway.
I cant say this device is worth every penny for me...
The n66a only works for me when I crank the engine, BUT when I put the key on just "acc" position the pop is still there and the a66n delay doesnt kick in for some reason.
Still havent figured out this problem.
sanbas is offline   Reply With Quote
Old 10-18-2006, 03:00 PM   #21
DCS
I know this thread is old but....
I had the same problem with that device, only in reverse.....
when I don't crank the engine I have a delay....when I do crank the engine, no delay at all. I contacted David and he suggested I put a 1000mfd 13VDC capcitor in parallel with the input line and ground. When I cranked the engine for the first time after installing the cap I didn't have a delay, but since then it seems to work.
In hindsight I wish I would have built my own delay...alot cheaper and probably would have worked better. Here's a good one:
http://555-timer.clarkson-uk.com/operation/frames3.html
DCS is offline   Reply With Quote
Old 10-18-2006, 08:04 PM   #22
mbkowns's Avatar
screw all that.. just use the amp-service
http://www.mp3car.com/vbulletin/show...ws+service+dtr
works perfect everytime never her poping.....
2005 Ford Mustang GT <- - - UPDATED PICTURES
2003 KAWASAKI Z1000 - CUSTOM MODZ
MBK (AIM = IllMBKllI)
mbkowns is offline   Reply With Quote
Old 10-19-2006, 11:28 AM   #23
DCS
Thanks...I may give that a try.
First I am going to try and wire in a Pulse trigger relay and see how that does.
I still can't get that David Navone piece of crap to work....
I thought it was working with the cap soldered in, but it only works properly for a couple of hours until the cap discahrges....
so if my car is not running for a couple of hours and I start it up, the amp turns on immediately.
I wouldn't reccomend that product to anyone.
Biggest waste of money (and time) yet!
Old 10-19-2006, 09:20 PM   #24
mbkowns's Avatar
my amps aren't turned on until windows is up and thats the only time i want my music to work..... so it totally works and its free....
Old 10-20-2006, 05:41 PM   #25
DCS
Thanks.... I may try that solution yet.
The main reason I was posting in this thread was to let people know not to buy that David Navone Turn on delay.
It's a total waste of money! Some people on here have had luck with it,
but IMHO it's a POS
There are much better ways to accomplish what that device is supposed to do!
Old 11-03-2006, 04:42 AM   #26
BiGGy's Avatar
I bought this item a while back and works like a charm no problems at all installing and functionally.
Mitsubishi Magna VR-X - Whitsundays, Australia
Continued Worklog... Upgrades in progress:
*15.4" WXGA LED backlight touchscreen upgrade
*Custom fiberglass dash bezel
*768 X 1024 Narrow RR Skin
http://bigs.omfg.net.au/
BiGGy is offline   Reply With Quote
Old 11-25-2006, 09:32 PM   #27
Good review. I will prolly be getting this just because I don't do that soldering stuff xD. 24 aint bad. What is +/- $8 bucks in a 1000$ computer
vtdawg404 is offline   Reply With Quote
Old 11-26-2006, 11:31 AM   #28
link dont work
Old 01-08-2007, 07:29 PM   #29
LiquidKernel's Avatar
Quote: Originally Posted by DJiK View Post
What IC is this item based on, the 555?
Most likely. Way too expensive for what it is. I built mine for free from parts I had in the garage.
95 Volvo 850 T5 • Konis • ECU @ 17psi • 5+20% Tint • Orange Ambient-Light + LED Dash Lights • DigiMotive Dimmer • Custom LED Brake Lights • 2.5" BOSCH HID Projector Retrofit
Carpc: [▓▓▓▓▓▓▓] 99% Cleanup.
LiquidKernel is offline   Reply With Quote
Turn-on amp POP Stoppers Gene Car Audio 46 12-10-2006 09:52 PM
Amp wont turn on, just keeps blinking, help! pyros Car Audio 24 10-21-2004 09:21 AM
Can Opus 90W remote turn on AMP and LCD > Gibbon Power Supplies 2 10-16-2004 08:57 AM
Opus remote trigger. Amp turn on live2themaxuk General Hardware Discussion 5 09-08-2004 03:37 PM
amp turn on jasmar General Hardware Discussion 2 07-21-2000 08:51 AM
