The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Thread Tools Display Modes
Old 05-22-2006, 08:49 AM   #31
The Vauxhall Vectra Project
ccsnet's CarPC Specs
ccsnet's Avatar
Vehicle: Vauxhall Vectra C SRI XPack Auto - v5 ( Via 12000 based ) Sygic & With FreeICE
My Photos: (0)
For any one intrested you can see some more install pics here. For my part I took the 'Steel me' badge off ( takes a little bit of presure form behind as its only stuck on ) and sprayed it with a matching dash paint. Looks very good.
Also I agree that with most of whats been said and I have been wondering if Mauris reverse swich would work with this unit... just looking for some one to build and send me one.
Terran
ccsnet is offline   Reply With Quote
Sponsored Links
Old 11-02-2006, 12:40 AM   #32
walky_talky20's CarPC Specs
Vehicle: 1986/Toyota/Celica
My Photos: (0)
Quote:
3) When opening the screen... popping it out is fine, nice strong spring, however, turning it up requires a lot more force than I would like to apply. When it pops out is is pretty much locked in a downward facing position and you have to unlock/unclick it. Another thing that makes this akward is that there is no good place to pull it up from. I find myself pulling on the 'frame' surrounding the lcd, i could see this causing breakage in the future. Maybe it will loosen up in time and turning it up will not require so much force.
I also noticed this issue with my 700H, and found a solution:
There are 2 "clips" on either side of the pivot point on the car side of the hinge. This is a little hard to explain. Anyway, on each of these clips there is a small philips screw. I removed both of these. The screws are also holding some kind of dust shield that prevents dust from getting inside the screen's "cubby" in the dash. I removed both of the clips and then replaced the screws to hold the dust shield.
Now, the monitor springs out and clicks, but no longer "snaps" before being able to flip up or down. It flips up and down with very little effort. I can now flip out or stow the screen with one hand. I haven't noticed any side effects to removing the clips yet. I thought perhaps it would "jiggle" while inside the dash, but so far it seems just as sturdy as it was.
Peace.
** Denotes an "in car" post
In-Car posts made from passenger seat - be safe,Don't Post and Drive.
walky_talky20 is offline   Reply With Quote
Old 01-04-2007, 11:24 PM   #33
Gurukarma's CarPC Specs
Vehicle: 2006 Scion XB
My Photos: (0)
Problems with DWW-700 - temperature
I ordered mine from ebay. The first unit worked fine for abou 3 weeks then I'd start getting a white screen when I would turn it on. About 20% of the time it would turn on correctly. I sent it back for another one. The new one came in and worked for about 4 weeks then it started getting a white screen. Now I have noticed that if the temp drops below 70F it gets a white screen or does not turn on. I have to blow my heater on it for about 5-15 minutes then it turns on.
Does anyone else have problems like this? Know of a fix?
-GK
Gurukarma is offline   Reply With Quote
Old 01-06-2007, 01:55 PM   #34
ccsnet's Avatar
My Photos: (0)
-GK
I guess if its cold then the LCD may have probs - the same goes for most LCD devices ( this is assuming 70F is low lol )
Terran
Old 01-09-2007, 01:24 AM   #35
jkiang's CarPC Specs
Vehicle: 06 Subaru Outback
My Photos: (0)
Oh goodness it's an hairy arm!...
jkiang is offline   Reply With Quote
Old 01-09-2007, 07:38 PM   #36
My Photos: (0)
i had mine in the car for 2min before it went up in smoke, literally (yes it was conected properly)
ordered from digitalww.com, sent it back 3-3.5 weeks ago now, hopefully i get a reply to my emails as to whats going on, and i get another one back
zc911 is offline   Reply With Quote
Old 03-04-2007, 04:36 PM   #37
ixoxoli's Avatar
My Photos: (0)
700H - rattle
everything is installed and running fine. the only problem i am having is the annoying rattle while the screen is out and driving in the city. hiway is alright since there arent too many bumps but i live in NYC and roads are horrible. so while driving around, the screen shakes and rattles, do you guys have this problem, is there anything that can be done to get the rattle out. put some padding somewhere or something?
ixoxoli is offline   Reply With Quote
Old 03-05-2007, 02:05 AM   #38
My Photos: (0)
I noticed that too, but thought it was just my old rattley car that was just plain too rattley. I usually just turn it a bit to the left or right, until one of the top corners contacts the dashboard. You may be able to take it apart and find somewhere to stick some kind of bushing in somewhere, I haven't taken mine apart. If you find a good solution, be sure and post it.
Old 03-05-2007, 04:12 AM   #39
ccsnet's Avatar
My Photos: (0)
I think its a common problem that.... but for the price....
That been said - just turn the music up - you dont notice it
Terran
Old 03-05-2007, 08:10 AM   #40
Vehicle: 2005 Saab 9-2X Linear
My Photos: (0)
Cold temps + 700H = white screen
-GK
I have the same problem, although mine seems to have issues below 40F. With the cold spell we have had in the northeast, I haven't even tried turning it on most days. Like you though, I discovered heat does the trick if given some time to work.
Is it really 70F fo you though?? I am hoping that was a typo for your sake. If not, is it too late to maye exchange it?
Some people are like Slinkies........
They serve no apparent purpose in life other than to occasionally bring joy to ones heart when they are pushed down a flight of stairs.
CT_Driver is offline   Reply With Quote
Sponsored Links
Old 03-06-2007, 10:12 AM   #41
ixoxoli's Avatar
My Photos: (0)
the thing is, i think its more of the problem of the screen shaking inside the plastic housing, not the unit itself shaking. my screen is already installed and i dont want to take it all apart and stuff. but i am thinking that sooner or later i might take it out cause its getting really annoying.
Old 03-13-2007, 06:36 PM   #42
My Photos: (0)
DWW-700H - Mac support?
Have any mac users out there tried this? Is it possible to get touchscreen drivers for this monitor on a mac?
Chronus72488 is offline   Reply With Quote
Old 03-23-2007, 11:16 PM   #43
slvrsol's Avatar
My Photos: (0)
looks like a great product for the price. This or xenarc..hmm.. decisions, decisions...
slvrsol is offline   Reply With Quote
Old 03-25-2007, 05:02 PM   #44
ccsnet's Avatar
My Photos: (0)
Just a word of note - not 100% but I thing I started getting recent touch screen probs when I changed my M2 from 5/45 Sec off to 30/2hrs off - ( if thats right ) - any way put it back today just to see what happernes.
If so its some thing to do with it been powered up on the USB port still that stops it been seen.
Logged her for others to see
Terran
PS Has any one tried the new TS drivers from Eglax - does this fix the hibernate issue at all ? Not tried as I did not want to fiddle
Sponsored Links
vB code is On
Trackbacks are Off
Where to buy in-dash non-motorized housing dubwise LCD/Display 22 12-16-2005 12:00 PM
Touch screen driver for 700H NickFury LCD/Display 8 11-18-2005 02:03 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 06:26 PM
Real Drivesoft Impressions ddn General MP3Car Discussion 3 03-10-2005 05:43 PM
Got my Mac mini this morning! - Read my first impressions... gork MacCar 20 02-06-2005 11:12 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
