The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Thread Tools Display Modes
Old 04-27-2006, 10:28 AM   #1
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
Hardware Review: Car2PC Alpine MBUS review
Device: DashPC.org - jbor Car2PC adapter (Alpine MBUS old-version)
HU: Darn old Alpine TDM-7534S.
CarPC: my Supra install.
Player: Winamp2.x, winamp5.x, and RoadRunner with Winamp2.x
Rating: 1 = worst, 10 = best.
Build quality: 9
I didn't open the box to see how it look inside, but the box looks pro. Cable to M-BUS 8-pin seem to be cheap. 3.5mm stereo plug/cable and USB cable are just typical cable you can buy off the shell. I will give a 10 if the MBUS cable is of better quality like Alpine factory cable.
Sound quality: 9
The only problem is when no sound coming from the PC, there is NOISE in the system. The noise is like a clock ticking. Once music is playing, it's crystal clear like it was connect to CDC.
Functionality: 9
I would give 10 if it ressponse faster to the button press. The problem could be the driver or because my install is darn slow.
(Disk selection button 1-6): 10
Work as expected on both 2.x and 5.x. With default RoadRunner implementation/commands, only couple command response to the button. For example 5 is set for GPS but it doesn't switch. Whereas Video (2)/DVD(6) switch just fine. iG is my GPS app and config to run on GPS command (external_GPS.skin). However it did response to the Up-Down Disk selection on the remote (weird isn't?). So the problem could be RoadRunner implementation or the button on the HU is ****up (no the botton works fine on radio and tape). It's a 10+ years new radio, mine you?
PlayList: 10
Song selection with in playing work perfect on Winamp. RoadRunner response a little slow, but works fine. I have to do some modification (remap the botton) to the RoadRunner command for NEXT and PREVIOUS command. There is a BIG limitation to the number of song you have in a playlist. Yes it only 99 songs MAX. I am sure this is a limitation of the Alpine M-BUS. I heard people have problem with 99 song max on Alpine-Ipod too. Here is how the limitation is. If you have 110 songs in the playlist and you are at song 99, the next song show is 00 on the HU, but 100 on winamp/RR (101 on Winamp/RR => 01 on HU). Now if you hit NEXT on the HU, you are going back to song 01, 02, 03 .... If you hit PREV, you are going back to song 02, 01, 99. Now that screw. I don't think this is anything the device (car2PC) and do to change that, this is something you guys should expect when you have BIG playlist.
- Does this device (car2PC) worth money: I pay 48 bucks shipped and it worth every peny. My HU doesn't have an option for AUX input. I have been using tape adapter for the pass 2 years and the sound quality is the same or better than this adapter. One of the reason is that while using tape adapter, I have no noise if nothing is playing from the carPC.
- DashPC customer support: I don't have any problem yet so I don't know. You guys all know how jbor response to your questions in this forum right? .
- Is it recommended: Yes, definitely. I am waiting for the Alpine Ai-Net version for my Matrix install. Althought some of you guys are going HU-Less carPC installation, but if you still have an HU that car2PC is compartible, you should get one. It make controlling carPC much easier especially the HU is RC ready. I do have Ir RC for my carPC setup to use the same remote as the HU, but it doesn't work as good as Remote->HU->CarPC (because of the Ir I built and Girder Plugin that run at highest priority cause a short pause when switch song).
Overall rating: I give it a 10 as it works the way it was design for and first of it kind .
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Sponsored Links
Old 04-28-2006, 04:33 AM   #2
My Photos: (0)
Oh lovely , Im so jealous
Kusadasi Marmaris
Sonny is offline   Reply With Quote
Old 05-04-2006, 03:03 PM   #3
jbors's Avatar
Vehicle: VW Golf GL 2000
My Photos: (0)
I'd like to reply to those things you mentioned to clarify.
1. Noise during PC absense is known. We will address that in a new design.
2. Slow response. Unfortunatelly MBus is slow by itself. Usually it takes about 0.8 sec to get button press to the PC. All other protocols are much faster...
3. Song number limitation. It will be addressed in the software. MBus is very limited in this regard. One problem here though that some MBus units cannot understand track 00, so you may see 01 for 100 and 101, 200 and 201 etc.
4. RoadRunner plugin. I'll work with Guino as it seems like the software issue.
Thanks for the feedback. Appreciate it.
Car2PC adapter. Car pc integration with ease
Car mediacenter
jbors is offline   Reply With Quote
Old 05-05-2006, 05:48 PM   #4
redbullah's Avatar
Vehicle: 1999 BMW e39 525td
My Photos: (0)
i have had the same problem with my ibus adaptor. Turn the pc volume low and use car amp to increase your sound level. btw would you send me the .ini file you made. i've been working on that switching between gps, mp3, divx, etc function. thanks
ibus error
GTA skin
redbullah is offline   Reply With Quote
Old 05-10-2006, 01:58 AM   #5
My Photos: (0)
Hi,
Can you send me the ini file?
kockemail@gmail.com
thanks and Regards
kocke is offline   Reply With Quote
Old 05-10-2006, 09:19 AM   #6
MySQL Error
MatrixPC's Avatar
My Photos: (0)
I didn't make much change on ExecTBL.ini file in RoadRunner. Basically I use the default setting with little mod.
but here it goes
Code:
/, Car2PC Interface Support "HUSTART","RESUME" "HUSTOP","PAUSE" "NT ","NEXT" "PT ","PREV2" "PA ","PLAY" "FF 1","STARTFFWD" "FF 0","STOPFFWD" "FR 1","STARTFRWD" "FR 0","STOPFRWD" "DS 001","MENU" "DS 002","AUDIO" "DS 003","VIDEO" "DS 004","LOAD_PICVIEWER" "DS 005","PHONE" "DS 006","GPS" "MX 1","SHUFFLE" "MX 0","SHUFFLE" "RP 1","REPEAT" "RP 0","REPEAT"
Note: LOAD_PICVIEWER is a custom command defind couple line before this portion of the command.
Old 06-02-2006, 06:39 AM   #7
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
Nice review, actually, I finally got around installing and testing this same car2pc adapter myself .. so I got to see what works and what doesn't work (as intended).. so you can expect RR to have some improvements in regards to the car2pc adapter very soon (cause I want to use it hahaha). I'm afraid the current speed is as fast as it'll get -- hardware limitations.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Alpine more mods RR Skins 302 04-10-2008 05:34 AM
can a carputer replace a high end av dedicated system? turbocad6 Car Audio 85 07-09-2007 04:44 AM
FS: Alpine Amps, Subs, 6.5" Monitors coachreed Classified Archive 0 04-03-2005 01:13 PM
Integrate mp3 player w/ Alpine FM modulator ? L0C0 General Hardware Discussion 0 03-04-2004 12:45 AM
Alpine / PC Challenges all around... acitrano General Hardware Discussion 5 11-10-2000 07:45 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
