Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Old 06-28-2006, 08:54 AM   #1
Tim Lake's Avatar
Tim Lake is on a distinguished road
Post Hardware Review: K500
Well I decided to go for the CarTFT K500 and now I've had it a few weeks, thought I'd bash out a quick review.
Firstly, these aren't cheap but the question is, are they worth it?!
Let me start with the connections. The wiring loom that comes with this needs connecting manually, not difficult if you are handy with electrics and have the (essential for CarPC work) soldering iron and multi-meter.
The biggest drawback on these is that they only have speaker level outputs, and no rca pre-outs. If, like most people, you are running your speakers from amps this creates a bit of a problem getting a decent sound from the radio. I found the easiest way was to use an active crossover which takes both high and low level inputs and connect the computer to the low and the K500 to the high.
The sound is still not great from the radio and the signal isn't as good as my old Sony HU (with the exact same aerial input).
As for the screen itself, this is great. The touch interface works perfectly and the picture is clear and sharp and remarkably resistant to glare. It also allows you to adjust the viewing angle, but only horizontally. It 'remembers' the angle too so next time you open it, it'll be the same.
The unit has connections for parking brake and reversing too so if you have a reversing camera you can hook this up so it automatically switches to the camera when you throw the car into reverse.
The unit looks fairly bland when it's closed but I like that as it makes it less appealing to your opportunist thief. It also needs a bit of modifying and brute force to get it to sit properly flush in your dash.
All in all, I'd say this unit is great as an in-dash touch-screen but if you want quality radio, you'd be better off going for a computer based solution until they at least get some RCA pre-outs onto this.
If anyone has any questions about the K500 I'll try to help.
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Bluetooth, 802.11g, GPS
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
NLited XP with Road Runner and MapMonkey
Tim Lake is offline   Reply With Quote
Advertisement Sponsored links
Old 06-28-2006, 10:45 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Moved to the Review Palace.
Good writeup!
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 07-20-2006, 08:23 AM   #3
KoBolD is on a distinguished road
I've just bought one and going to fix it as soon as possible and let you guys know
KoBolD is offline   Reply With Quote
Old 07-21-2006, 06:12 AM   #4
Installed it yesterday but it's not easy. The manual a quite small and not clear. I had to solder some wires but didn't know wich wires so I had to test it. I connected the ACCON wire to the memory 12V and the 2 yellow to the 12V and the 2black to the Ground. I don't know if this is right but it works. When I let the radio autosearch for a channel it doesn't find anything. When I set the channel manual it works great but I don't get the name of the channel in my screen.
Is there a way to get the autosearch working?
Is there a way to get the channel name on the display (RDS)?
Old 05-28-2008, 07:02 AM   #5
drummerian is an unknown quantity at this point
anyone have a manual for this monitor? cheers!
drummerian is offline   Reply With Quote
Old 05-29-2008, 04:04 AM   #6
can anyone tell me what the 'park' and 'remote' wires do? cheers
Hardware Review: Car2PC Alpine MBUS review MatrixPC The Review Palace 6 06-02-2006 07:39 AM
DWW-750J Motorized Screen-Full Review techy101 The Review Palace 18 06-27-2005 06:20 PM
IBASE MB860 review jpelzer General Hardware Discussion 1 10-25-2004 09:46 PM
New review site in beta testing CdRsKuLL Newbie 7 04-15-2004 05:58 AM
ITPS Power Sequence review saito The Review Palace 8 12-18-2003 10:26 AM
