Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Old 07-03-2006, 04:17 PM   #1
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Hardware Review:Audigy ZS 2 PCMCIA
My requirements:
  • First and foremost, I needed optic out (tos-link, not the digital RCA)
  • Since I'm not using a case, I have no where to secure a PCI card to, and with the location of my computer, I don't have the height for one anyways
  • This left me with PCMCIA
  • High quality
My list was short, especially since I'm using the optical out on this unit.
I needed this optical out because I was planning on running from the sound card to the Alpine PXA-H701 processor brain as an optical signal. This would help to eliminate any possibility of induced noise by running an analog signal from the computer.
While reading the specification on the Sound Blaster web site:
Linky
I was a bit confused as to how they were claiming an optical signal was possible from this card that only had 1/8" phono outputs.
I called up customer support and was told that the signal was in fact optic, it was just put into a 1/8" phono (headphone) jack because that was a format that was more widely needed. They told me that I would just need to get a 1/8" phono to Tos-link adapter and I would be running that little beam of light in no time.
So I went to Radio Shack and purchased the device for a whopping $2.95. I've since searched their web site but have been unable to find it any more unfortunately.
Here are some options using Froogle:
Link
So far the card has been outstanding. It does everything perfectly. I do not use any of the Audigy software as I have no need for it, so I cannot vouch for any of it. All of my processing is being done by the Alpine processor.
In my quest for extreme Sound Quality, I learned about Bit Perfect and Kernel Streaming. I was reading up a bit in the HTPC forums about how to go about achieving this when I found that the ZS cards are actually capable (most SB cards are not). While with most cards you have to download a few programs and play with the buffers, with this card all you have to do is click in a box and you're set to go from the hard ware side of things. No need to run some of the bulky, confusing buffering software that the other cards required. Big +1 there for the card.
So far I have had no issues with this card, drivers installed without issue and the card was up an running within minutes.
Highly recommended.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 07-04-2006, 10:29 AM   #2
coach is on a distinguished road
I am jumping in only to say the same thing. I have the Phoenix R5.1MT amp and run from my PC to that amp and I used the Audigy as well. I had it for my laptop but got a new machine and no longer needed it. So, it went into the carpc. It is an awesome device and works great. The sound quality is just awesome. I have MII10000 with 512MB and a 100GB drive, running Audigy PCMCIA to the Phoenix amp and that runs out to an Xtant X603 powering a set of Dynaudio components, clarion center channel speaker, JL 12W6V2 sub and it is just great.
PS - Your Alpine PXA-H701 processor required an Alpine Control Unit/HU correct? Just wondering.
PSS - Never Mind I found it. You need one of the selected Alpine HU or the RUX-C701 Control Box.
Brent
1999 Nissan SE-L - turbo toy
1993 Nissan NX - Turbo Racer
Standalone fuel management (AEM EMS) on both
carPC
coach is offline   Reply With Quote
Old 08-25-2006, 06:04 AM   #3
Mailman is on a distinguished road
Anyone has an experience using Linux (preferably Ubuntu or Gentoo)?
Mailman is offline   Reply With Quote
Old 12-14-2006, 02:57 AM   #4
sivart321 is on a distinguished road
I am curious how you have this card interfaced with the PC? Is it a laptop with a pcmcia slot? Or do you have some sort of adapter?
sivart321 is offline   Reply With Quote
Old 12-14-2006, 08:39 AM   #5
_
the MII12000 has a PCMCIA slot built onto it...there are other mobos that have that as well.
Jan Bennett
Old 12-17-2006, 12:39 PM   #6
kawie95 is an unknown quantity at this point
Awsome, I am just learning about notebook audio. I was wondering if someone could give me some direction.
I saw this card on Newegg for like $90, paving a better way than 3.5mm audio. I was looking for a s/pdif output to use with a RCA converter (SIIG CE-CTC012 Converts S/PDIF signals from Toslink optical to RCA coaxial - Retail ) HERE for $20 on Newegg, but it might lack quality (temporary solution at best if my headunit's RCA isn't good enough for optic sound). My Headunit is a cheep 7" lcd w/ RCA inputs and S-video, as well as a external CD player plug (Specs posted here).
I am in the process of hooking up my really good gaming labtop up to my car, and I was thinking this notebook audiocard hooked up to some sort of audiobox, then from there to the headunit. Is that the best idea? What kinda of "box" do I need to change optic to rca?
This project is one of those "upgrade along the way" type things, and I don't like wearing out my 3.5mm audio plug like I did on my Toshiba. I want good, crisp, digital audio on my stock speakers . From there I can upgrade to some sort of amplifier, speakers, wires, etc. But first I would like a solid media center platform to work with.
Thanks,
-Eric Schrader
kawie95 is offline   Reply With Quote
Old 12-27-2006, 12:30 AM   #7
miwise's Avatar
miwise is an unknown quantity at this point
You'll need a signal processor. You can find them on ebay under signal processors in the consumer electronics area (car audio of course)
Lexus SC400/Factory Amps/Sub
HP/AMD 1.1 Ghz Mobile/Upgrade Imminent
512 RAM-DVD/7" Touchscreen
WinXP-Shelled to Roadrunner for now
Progress:
Software: Still trying to decide
Hardware: 95% done. . .need GPS
Installation: 90% done. . .clean up phase
miwise is offline   Reply With Quote
Old 12-27-2006, 12:14 PM   #8
Ebay link
Theres 14 and some are expensive. What do I need to go from this audio card, to the signal processor, out to RCA Front LR and RCA Rear LR? These have sub outputs and stuff which is nice but I don't have a sub (not enough room).
Thanks a lot man
Old 12-27-2006, 12:28 PM   #9
kwchan's Avatar
Location: Singapore - Smallest country in Southeast Asia
kwchan is an unknown quantity at this point
is it overkill to use an Audigy ZS 2 card when you can actually get SPDIF -> optical adapter at around $20? most motherboard already has build-in SPDIF out
i dont think there will be much different in terms of sound quality, as it is the H701 that do all the processing
kwchan is offline   Reply With Quote
Old 12-27-2006, 12:33 PM   #10
_
all digital is not created equal.
not to mention, the Audigy has the capability of running bit perfect. Not all onboard audio chipsets have that ability.
Jan Bennett
Old 12-28-2006, 10:42 AM   #11
My labtop doesn't have S/PDIF I also run Windows XP MCE.
Old 02-06-2007, 11:32 AM   #12
hari-bhari can only hope to improve
I'd like to add that this thing is no good at coming out of hibernation. Sometimes the sound comes out completely corrupt and sometimes its silent for a few seconds and then ok, and sometimes its corrupted for a few seconds and then its ok. I can't disable and enable using devcon cuz there's no HWID.
hari-bhari is offline   Reply With Quote
Update my first hardware (Serial Voltmeter).Add two new functions mauri Road Runner 43 10-31-2006 12:00 PM
PCMCIA Audigy 2 ZS Notebook ($65 shipped) DiNASTY Classified Archive 1 05-23-2006 04:57 AM
pcmcia hard drive RootBreaker General MP3Car Discussion 4 08-15-2005 05:26 PM
PCMCIA Sound Blaster Audigy 2 ZS krustydawg General Hardware Discussion 0 06-04-2005 07:23 AM
PCMCIA slot expansion naquada General Hardware Discussion 3 12-30-2004 07:35 PM
