Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Old 03-14-2007, 12:58 AM   #16
polonez is an unknown quantity at this point
So how has this screen been treating you? Im thinking of getting one in either this or the dynamix version. My main concern was the metal casing as it will be molded into my dash... This review has made me a little excited since you say the backing is metal but the front bezel (most important) is plastic... Is this the same with the dynamix? or is the dynamx all metal (aluminium)??
How is it in the sun? lots of glare?
Let me know! Thanks
polonez is offline   Reply With Quote
Old 03-15-2007, 04:09 AM   #17
AcuraTLFan
The backing is metal but the front bezel is plastic, i don't have the dynamix, but by the pictures it seems like they are the same. I think with all screens, there is glare...I can't give you a comparsion. With iguidance and the sun you can see the screen very well, but you can make out the outline of the roads and the surrounding.
For ~$200USD, you can't go wrong with this 8in widescreen touchscreen monitor. I've very happy with it. It seems that the guy on ebay no longer sells it, but i found this link
http://www.americanthunderaudio.com/...spx?id=1512300
AcuraTLFan is offline   Reply With Quote
Old 03-15-2007, 06:50 AM   #18
KingofCorona is an unknown quantity at this point
The dynamix version is exactly the same thing as the TView. Metal backing and plastic front. $225 on eBay. It is also auto power on.
05 Acura TL
CarPC 99.99% Done
KingofCorona is offline   Reply With Quote
Old 03-15-2007, 07:18 AM   #19
vqstatesman is an unknown quantity at this point
hey acuratlfan, the 6th pic you have posted of the panel out of its outer casing. just wondering if the small thin bezel around it its plastic, if i get this model im thinking of mounting it on/in my dash with that inner bezel displayed.
Gosh carputer shopping would be so much easier if i could walk into a shop with these screens on display and pick them up look at them and place them against my dash.
you guys in the USA have it so much easier to buy everything ! GGRRRRR
that shop http://www.americanthunderaudio.com/...spx?id=1512300 only delivers to USA not Australia. God damn second rate technologically impaired country.
does anyone know if this one http://cgi.ebay.com.au/Dynamix-8-TFT...QQcmdZViewItem
which im assuming is the newer model which has auto on is the only Dynamix 8" with auto on. And the real question when gutted does the screen have its own small bezel like in pic number 6 of aucuratlfan's picture lineup.
vqstatesman is offline   Reply With Quote
Old 03-16-2007, 09:44 PM   #20
AcuraTLFan
idon't know if these are the measurements you want. the bezel is plastic
Old 03-16-2007, 10:04 PM   #21
AcuraTLFan
This auction is for a regular screen 4:3 not widescreen 16:9 as the one I have
Old 03-17-2007, 07:42 AM   #22
thanks for the pics mate, i was sorta after the measurements of the screen itself when taken out of the casing but those help heaps, now i just gotta find one and pay for it.
Old 03-24-2007, 12:13 AM   #23
slvrsol's Avatar
slvrsol is an unknown quantity at this point
Looks great.. might have to think about getting one of these myself
slvrsol is offline   Reply With Quote
Old 03-25-2007, 08:42 AM   #24
DodgeCummins's Avatar
DodgeCummins
It is possible the Dynamix 8" and this one are the same...(the drivers are the same, and the remote/mounting hardware is the same as my dynamix monitor)
However, my 7" only uses a single cable from the monitor to a multi pin connector...then a 6' cable to the plugs (3 rca, 1 VGA, 1 USB, power plug...and reverse switch wire.) Very clean smart setup.
Clearly on those pictures, the Touchscreen is an add on and uses a separate cable.
current projects
DodgeCummins is offline   Reply With Quote
Old 03-25-2007, 12:43 PM   #25
AcuraTLFan
I'm pretty sure that they are the same unit. The only difference is that mine is the older version without the Auto-On feature.
Yes, the block of wire is a cleaner setup...but some people have ghosting/interference issues with the block design. As for the touchscreen...most units follow the same design; it's a separate USB controller...depending on manufacturer they may have same or different wire harnesses
Old 01-03-2008, 05:44 PM   #26
BobbyTMS is an unknown quantity at this point
Tview DVD722FMTV
I am in need of the contact info for TView. I have a DVD722FMTV unit that will not work sometimes. I thank any and all that can assist with this matter.
Bobby
BobbyTMS is offline   Reply With Quote
Old 01-30-2008, 03:01 PM   #27
cirrussport is an unknown quantity at this point
DO you have the viewable measurements of the screen and the measurements of the outside of the actual lcd module without the casing?
cirrussport is offline   Reply With Quote
Kiosk LCD and touch Screen Help RatonCrispiN LCD/Display 7 03-25-2007 10:18 PM
WTB a LCD screen touch or no touch dont m kyle_geo_freak Classified Archive 0 12-06-2005 09:25 PM
EBAY: Sharp 15" LCD With COntroller & SAW Touch Screen + More. dsptech Classified Archive 0 12-03-2005 02:15 AM
Double-Din touch screen LCD? senseless228 LCD/Display 16 05-05-2005 08:20 AM
10" vga lcd touch screen going for 350 us Mp3_Truck Classified Archive 1 06-16-2001 12:48 AM
