Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Old 10-10-2006, 09:53 PM   #1
DodgeCummins's Avatar
DodgeCummins
Hardware Review: Dynamix 7" 706 WS TS VGA
No pictures...yet
Hardware Review: Dynamix 706, 7" Widescreen Touchscreen VGA monitor
What it is/does: LCD monitor
Reviewed by: DodgeCummins
Manufacturer : Dynamix
Model: 706
Specs:
* Display 7" screen TFT-LCD (Auto Power On)
* Backlight Built in CCFT
* Resolution 640*480
* High Resolution 1600 x 1200
* Supported Resolution 640 x 480 ~ 1600 x 1200
* Physical Resolution 800 (H) x 480 (V)
* Dot Resolution 2400 x 480 = 1,152,000 (dots)
* Supported Voltage 11V DC ~ 24V DC
* Brightness Rating 400cd/m²
* Contrast Radio 150
* Video Input System NTSC/PAL Auto switching
* Power Source DC 12V ± 10%
* Operation Temperature 20° C to +78° C
* Color Figuration Stripe
* Dot Pitch 0.107 (H) * 0.732 (V)
* View angle L/R/T/B 55/55/10/30
* New Auto Reversing Input
Price: $182 off ebay...$279 at website.
Rating: 9/10
Manufacturer website: http://dynamixcomputers.com/7_dynamix_ultra_bright.html
Purchased at: ebay
Pros: Very bright, works exactly as you'd expect
Cons: Owner/installation manual truly is crap...and I actually wish I could lower the brightness a bit more at night.
Pictures: none yet...but the web site has them.
I needed a screen that would fit in the hole in the dash I already had, and allow room for me to adjust the tilt etc. for best viewing angle/least glare.
That is why I picked this one over the larger ones.
It works great out of the box, plug it in and go. It displays whatever resolution happens to be plugged in...it simply rescales the image. But I use Powerstrip to output the native 800x480.
I have only been using the monitor in my truck for a few days, but so far there are zero surprises. The touchscreen obviously is more accurate with a pointing device or fingernail, but a finger works fine also.
The software installed without a problem on win2k, and it includes a little utility that you can select from the tool tray that gives you a right click option, small and quick. There are different levels of calibration available, but I only did the 4 point...and just for fun, it was already accurate enough.
For power I have it plugged into my computer powersupply (opus 120). The box included a wall wart, and a lighter socket plug. It will auto turn on/off with VGA signal.
In addition there are 2 (I think only two...I had better go look) Composite inputs...and like the other screens, there is a wire to connect to the reverse light circuit, that will select the reverse camera when you back up. (I haven't tested that yet)
Running the LSXVOID skin on Roadrunner, and with Iguidance showing the night screen...AND the brightness turned all the way down...I is just barely dark enough at night.
With that setting it is also bright enough for daylight...and there are 3 preset brightnesses above that (selectable by remote control).
For mounting, I am using the gimbal it came with on a custom mount to my dash.
I mentioned earlier on that it will automatically scale the display. If you change your video card settings, and don't like how the picture is set up (centered etc) then off the OSD menu, just select AUTO and it will re-adjust the image to better center it within the display.
Image quality is very nice, very good off angle viewing, nice color, good text detail (using standard font sizes).
Overall this screen more than meets my expectations, and is so much better looking than my old screen I have no second thoughts at all.
current projects
DodgeCummins is offline   Reply With Quote
Old 11-16-2006, 04:22 PM   #2
striker008 is an unknown quantity at this point
Auto on
How does the auto power on and auto power off work?
striker008 is offline   Reply With Quote
Old 02-17-2007, 10:06 AM   #3
DodgeCummins
If the monitor senses a VGA input, it will power on...no input then it powers off.
In addition, if you supply power to the reverse trigger, it will pull up that input.
For example, you wire that trigger to your reverse lights, and your backup camera is wired the same, the display will auto switch to the back up camera.
I haven't done that yet...but when I do, I will put a switch to turn on the camera...rather than the reverse lights.
BTW, 4 months later it still works the same...I have never recalibrated the display.
current projects
Old 03-18-2007, 07:27 PM   #4
MobiTekLink's Avatar
MobiTekLink is on a distinguished road
Have you had any issues since you got it??? Im planning on buying one.
08 Lincoln Navigator www.mobiteklink.com
MobiTekLink is offline   Reply With Quote
Old 03-20-2007, 11:17 PM   #5
scottgs's Avatar
scottgs is on a distinguished road
I'm curious what your old display was. I'm trying to find a brighter alternative to the Xenarc 700TSV. It's just not very bright. I keep going back and looking at those megabuck transreflective displays.
Thanks for taking the time to post your review.
Garret
scottgs is offline   Reply With Quote
Old 03-21-2007, 12:26 AM   #6
dontpntpool's Avatar
dontpntpool has a little shameless behaviour in the past
Please post pics of it apart ktnx
dontpntpool is offline   Reply With Quote
Old 03-24-2007, 10:41 PM   #7
DodgeCummins
My previous display was the LCD from the Fujistu Stylistic 1200 pad computer...that I extended the lcd wires to...painful work.
The avitar is of the old screen...taken at night.
The new screen is bright in the daytime.
If I have the brightness turned all the way down (which it is all the time) and the sun at exactly the worst angle...then it becomes hard to see.
I have seen those conditions once.
It does get down to just above zero here in north Texas every once in a while...screen worked fine the entire time...including the touchscreen...could even use the stitching part of my gloves on it.
I have had zero issues with it. I have not calibrated the touchscreen or anything else.
However...on a moonless night...on a quiet highway...I actually turn the screen off...it is a bit too bright then.
I have not taken it apart...nor am I planning to.
current projects
Old 04-13-2007, 02:35 PM   #8
bangumandoo is an unknown quantity at this point
i have an 816 coming in the mail and i can assume most if not everything is the same. iw as wondering if i could order a vga spliter. male to dual female and that might make it auto switch?
bangumandoo is offline   Reply With Quote
Old 04-21-2007, 11:06 AM   #9
TurboTronix's Avatar
TurboTronix is on a distinguished road
Wheres the best place to get these screens?
Don't be a pilot between drivers, just a faster driver in a plane!!
TurboTronix is offline   Reply With Quote
Old 04-22-2007, 03:03 AM   #10
sivart321 is on a distinguished road
Quote: Originally Posted by DodgeCummins View Post
No
Have you verified that the monitor is actually displaying at 800 x 480? I have the original 706 and have always had the same issues as all of the xenarc and lilliput users have where the computer will ouput 800 x 480 just fine but the monitor doesnt accept it and defaults to a different res. Any help?
sivart321 is offline   Reply With Quote
Old 04-25-2007, 11:14 AM   #11
DodgeCummins
Like I said, it will scale to whatever my video card shows...but the best looking display is when my video card is set to 800x480.
You will have to tell me how to 'verify' the dislay on the screen.
current projects
Old 06-13-2007, 10:54 PM   #12
jgdynamics is an unknown quantity at this point
vbeen trying to find this item on ebay, with no luck
jgdynamics is offline   Reply With Quote
Old 06-14-2007, 03:12 AM   #13
http://dynamixcomputers.com/7_dynamix_ultra_bright.html I guess its pretty pricey there?
Old 06-15-2007, 12:21 AM   #14
JDizzle's Avatar
JDizzle is an unknown quantity at this point
Same monitor as this CarTFT screen?
http://www.cartft.com/catalog/il/527
If it is, we know it's a Hitachi panel.
JDizzle is offline   Reply With Quote
Old 07-21-2007, 06:38 PM   #15
timatl is an unknown quantity at this point
Great review!
Could you post the dimensions of the monitor with casing?
Thx
Tim
timatl is offline   Reply With Quote
Hardware Review: Provision 8" 16:9 VGA Touchscreen lightman The Review Palace 19 06-15-2009 09:02 AM
Is Dynamix 706 the brightest screen (compared to Xenarc)? davem LCD/Display 6 06-23-2006 07:32 PM
WTB: Dynamix 706 7" VGA Touchscreen DaPCWiz Classified Archive 2 02-10-2006 03:10 PM
