Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Old 10-21-2006, 12:08 AM   #1
ddarind is an unknown quantity at this point
Hardware Review: Mp3Car 8" 16:9 VGA/Composite Monitor with Touchscreen
What it is/does: Touchscreen Monitor
Reviewed by: Darin
Manufacturer : Mp3Car ? They had someone make it for them.
Model: Optiplex Mp3Car 8" 16:9
Specs:
Display Size: 8" Diagonal
Aspect Ratio: 16:9
Number of Pixels: 1,152,000
Supported Resolution: 640x480~1600x1200
Native Resolution: 800x480
Brightness: 400cd/m2
Back Light: Built-in CCFT
Video Inputs:1x VGA and 2x RCA(Composite)
Video Input System: PAL/NTSC Auto Switched
Power Source:+12V Regulated (Do not Connect Straight to the battery)
(not sure what they are refering to here. As far as I can tell it is nothing more then a cig lit plug.)
Power Consumption: 10W Max
Operation Temperature: 0C to 50C (32F to 122F)
Monitor Dimensions:W: 220mm(8.67in) x H: 125mm (5.32in) x D: 29mm (1.15in)
Price: $260.00
Rating: 9/10
Manufacturer website: www.mp3car.com
Purchased at: www.mp3car.com
Pros: Great Price, Big picture, Great Brightness
I had a different brand before, that was a flip out. I wanted to go with something I could make look more stock. The picture is wonderful, easy to read. I have only had it in my car for a full day. But the Sun was out and it was very readable. Sure it washed out some in direct light, but much better then what I had before.
Cons: None yet, other then the 2 week wait. They are out off stock again.
Pictures:
ddarind is offline   Reply With Quote
Old 10-21-2006, 11:57 AM   #2
LYHTSPD is on a distinguished road
Good review. I do have a couple of questions on the cables though. What is the single orange/red wire? The red and white RCAs are for audio in, and the yellow is a video in... but what are the black and blue RCAs and what is the black plug with the ferrite bead on it for?
LYHTSPD is offline   Reply With Quote
Old 10-21-2006, 04:38 PM   #3
Yellow Video 1
Red Audio 1
White Audio 2 (That is what it says on it, but I would say they are left and right for audio 1.)
Black RCA Video 2
Blue RCA Video 3
What is the black plug with the ferrite bead on it for? That is the DC Plug for DC 12V
There is also a USB plug there.
The Org wire? It is not listed in the manual. I would assume that it would be an Ill. wire and would dim the unit when the car lights are on. I will have to contact mp3car to find out.
More pictures of it installed, in the future. I am working on a post for "Show off your project" of my full system. Still have some work to finish.
Old 10-23-2006, 05:26 PM   #4
bobbyboy987 is an unknown quantity at this point
what does that "mirror" button do?
bobbyboy987 is offline   Reply With Quote
Old 10-23-2006, 09:32 PM   #5
The manual does not have that button listed. I would assume that it will flip the image. This would be used for a backup cam. I do not have a video sig hooked up to it (or I would test it) and the mirror button does nothing on VGA source.
Old 10-23-2006, 09:43 PM   #6
FLAC is for flaccid
parksgm's Avatar
parksgm will become famous soon enough
The packaging and included materials (remote, touchscreen driver CD, cigarette lighter plug, etc.) look identical to the accessories included with the MP3car.com SP7 screen, so I'd bet it's from whoever manafactures that screen.
The mirror button on the remote does nothing on my SP7 screen either...and the cig. plug is nothing more than a plug on my screen...no internal circuitry.
FYI for the OP: most (all, really) of the LCD screens are sourced from overseas. It's even rumored that many of the LCD screens are actually pulled from Japanese arcade/casino machines...the manafacturer then produces a plastic case and the circuitry to run them, and then packages them and resells them. In any case, MP3car.com is NOT the manafacturer, but just a reseller.
Could you take some pics in the daylight (preferably one with the sun directly on the part of the screen and the rest of the screen in the shade), and post them here?
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Old 10-24-2006, 10:27 AM   #7
fatejd is on a distinguished road
Looks like a Xenarc to me...
Carputer Progress:
Re-do fabrication of screen [DONE]
Upgrade screen and PC [70%]
Wood faceplate for computer in glovebox [0%]
fatejd is offline   Reply With Quote
Old 10-25-2006, 12:15 PM   #8
I will try to get a picture of the screen with Sunlight. But this time of the year, there are less sun and it is at a different angle then in the summer.
Old 02-09-2007, 01:54 AM   #9
rembo666 is an unknown quantity at this point
How did you mount it in the dash? Did you use a stereo installation kit, cut it, or just "glued" it behind the dash. I also have a Ford Focus and I'd like to mount this thing in my car.
rembo666 is offline   Reply With Quote
Old 06-19-2007, 09:33 AM   #10
mohamedali21 is an unknown quantity at this point
hey, i have this monitor in my car and it works great. the orange wire alone except the rca is a switch for back up camera. I use that wire to connect to the reverse light wire so putting the car in reverse it will switch to my backup camera. works great.
mohamedali21 is offline   Reply With Quote
Mp3Car 8" 16:9 VGA\Composite Monitor with Touchscreen joego LCD/Display 1 07-20-2006 10:52 PM
Double-din is closest to 16:9. Should I go with 8" 16:9? Which? justintime LCD/Display 5 04-27-2005 11:02 PM
Need 8" 16:9 touchscreen mladen LCD/Display 2 02-23-2005 08:27 AM
