The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Thread Tools Display Modes
Old 04-10-2008, 07:18 AM   #76
My Photos: (0)
Please write them in a raw starting from the best sounding. Explain the good and the bad of each one you tested!
dbDRAG is offline   Reply With Quote
Sponsored Links
Old 04-10-2008, 08:15 AM   #77
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
Quote: Originally Posted by NapalmV5 View Post
i can safely say that 40% wav/mas = higher db than @ 100% wav/mas stock caps
What type of load are you driving? Headphones or is this going into an amp? If it's driving headphones I might understand this possible rise in output since it is a harder load to drive vs an amp that has a typical 10Kohm input impedance. The PSU voltage does not change so really you are still capped by the PSU rail voltages going to the opamps in the buffer circuit.
RE picking opamps:
http://www.dself.dsl.pipex.com/ampins/webbop/opamp.htm
durwood is offline   Reply With Quote
Old 04-10-2008, 08:24 PM   #78
My Photos: (0)
sorry im no opamp reviewer.. the only opamp reviewers should be the artists/the ones making the music, everybody else is just stating their subjective opinions
sound is very subjective.. heck even video..
there is no good/bad about the highend opamps.. the differences are more subtle
it also depends a lot on your sound system/gear
NapalmV5 is offline   Reply With Quote
Old 04-10-2008, 08:30 PM   #79
My Photos: (0)
RE picking opamps:
if headphone i wouldve stated
no amp/receiver/etc.. just wires between the sound card and 7x powered subwoofers - 1 front left/1 center/1 front right/1 rear left/1 rear right/2 main
believe it or not my modded MX300 beats the crap outta stock prodigy
2x 2200uf paralleled power filter
Old 04-22-2008, 04:47 PM   #80
My Photos: (0)
since CE22 & CE39 are @ 5V.. ive replaced the 2x black gate 4700uf 16V caps to 2200uf 6.3V BG NX for increased capacitance & improved sq
too bad the prodigy doesnt have an LFE.. this would be the badest sound card around
Sponsored Links
Old 04-30-2008, 01:08 PM   #81
My Photos: (0)
Just bought a brown dog adapter and fitted 2x lm4562!!!!
Nice sound...BUT the opamps are REALLY REALLY HOT!
I put back the single
Old 05-02-2008, 11:51 AM   #82
Car Audio Moderator
durwood's Avatar
My Photos: (0)
I do believe there is LFE on the prodigy but honestly I have not used it as a surround sound card so I'm not 100%.
The pure fact that is has Directwire allowing you to use VST plugins makes it a killer card.
Forget traditional 5.1, go the VST route and enjoy the benefits of ambiophonic and ambiosonic processing through VST. Once you go that route, little electronic extra "SQ" gains to improve accuracy is far-outweighted by the acoustics factor. I know, I was once there but I have realized the real problems are limited by acoustics and no longer electronics, especially the problems/limitations with conventional 2 channel stereo and even commercial 5.1.
Sponsored Links
vB code is On
Trackbacks are Off
Hardware Review: Provision 8" 16:9 VGA Touchscreen lightman The Review Palace 18 05-21-2007 04:45 PM
Hardware Review : Dynamix 805 8" 4:3 TouchScreen Review (Pics : 56K Friendly) Ruffy The Review Palace 14 04-13-2007 01:23 PM
Hardware Review: SB Audigy2 NX External USB Sound Card hari-bhari The Review Palace 3 12-13-2006 03:55 PM
Hardware Review: Overdue M2ATX review elstev0 The Review Palace 0 09-03-2006 09:10 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
