Go Back   MP3Car.com > Mp3Car Technical > The Review Palace
Old 02-06-2007, 07:11 PM   #1
Thumbs up Hardware Review: CompuTrack VGA/RCA Selectable Switchbox
Hardware Review: VGA/RCA Selectable Switchbox
What it is/does: Switches between VGA (passthrough) and RCA input (autoscan NTCS/PAL) at the flick of a switch/relay/reverse light. This unit does NOT toggle between modes - it hard switches. This means you will never be in the wrong mode accidentally .
Reviewed by: Iceman_jkh
Manufacturer: CompuTrack
Model: CSB-02
Specs: Requires 12V (<500mA). Output: SVGA/XGA @ 60Hz
Price: I'm not sure - mine was a sample. Please contact: roy.patterson3@computrackllc.com for pricing and further information. He was VERY helpful to me, so I'm sure he can help you out.
Rating: 10/10
Manufacturer website: www.computrackllc.com
Purchased via email: roy.patterson3@computrackllc.com
Pros: Allows me to use a reverse camera (autoswitching) with an LCD with only a VGA input. There is no lag on the image being displayed to the LCD. Compact size. It can also be used with a Sony type reverse camera connection (but not at the same time as RCA).
Cons: None that I have found yet.
Pictures: To be included later.
Dimensions: Approximately 150x100x25mm (6" x 4" x 1")
I happen to run 800x600 on my LCD (as that is the LCD's native res. - and it looks beautiful :P), however, for all you folks who run odd (non 4:3) resolutions I believe this box will still work perfectly. The reason I say this is that the VGA mode is pure passthrough. I havent tested (but Ive been told) that the incoming VGA signal is fed directly to the output (unchanged), and only the RCA signal is up-converted/rescanned in order to output it to VGA.
The effect of this up-converting will be to display the reverse camera image to your LCD with minor (if any) warping. In my opinion this is hardly an issue if you compare it to the fact that not only can you quickly switch to reverse camera automatically, but that you can now actually see what is behind you.
Cheers
Ice
Iceman_jkh is offline   Reply With Quote
Advertisement Sponsored links
Old 02-21-2007, 07:42 AM   #2
No comments/questions?
Has anyone thought about/bought one of these?
Has anyone contacted Roy?
Old 03-12-2007, 02:53 PM   #3
MobiTekLink's Avatar
I really dont understand the website, I dont know what they sell or its use. SOrry but maybe Im stupid.
2004 GMC Yukon Denali
www.myspace.com/mobitekny
http://www.flickr.com/photos/bustadreamz
MobiTekLink is offline   Reply With Quote
Old 03-12-2007, 08:25 PM   #4
They sell (rear) vision systems for caravans and 4WDs amongst other things. Unfortunately their website doesnt show this particular product (or many others).
Hopefully they will show something soon. I havent installed it yet, but in testing it appeared to be a really good product.
Old 03-15-2007, 11:13 PM   #5
Sounds like something the MP3car.com store should team up with and sell...
sebberry is offline   Reply With Quote
Old 11-06-2007, 03:56 PM   #6
kuo
kuo's Avatar
i saw your post here http://www.mp3car.com/vbulletin/lcd-...tom-kit-2.html and i give two hoots. i emailed the guy to see how much he wants for his auto switching unit. i have the xenarc with the autoswitching on av2 with my camera hooked up to a relay tripped by my reverse lights but sometimes it doesn't work properly and when it does, there is a 2 second delay.
my car: 2003 g35 coupe
wife's car: 2004 honda accord coupe
company car: 2006 chevy avalanche
worklog
http://kuo.freakstylehosting.com/car.html
kuo is offline   Reply With Quote
Old 11-06-2007, 04:14 PM   #7
I havent had the item give me a single false switch in the months Ive been using it
Its really fast too - about 1 second or less.
You must have the unit powered all the time or it takes a while to startup and then switch (perhaps 1-3seconds). If that doesnt bother you, then I guess you could leave it in the switched state and only turn it on when you wanted the reverse camera signal. (It acts as a passthrough when OFF).
I have it (switchbox) always powered, but not in 'switched' mode. When I switch to reverse, I also use that signal to power the reverse camera. Thats probably why it takes a little longer (1sec) to switch - cause the camera is 'powering up' and doesnt provide a signal to lock to straight away.
Hardware Review: Dynamix 7" 706 WS TS VGA DodgeCummins The Review Palace 18 08-01-2007 12:22 AM
Hardware Review: Provision 8" 16:9 VGA Touchscreen lightman The Review Palace 18 05-21-2007 04:45 PM
Hardware Review : Dynamix 805 8" 4:3 TouchScreen Review (Pics : 56K Friendly) Ruffy The Review Palace 14 04-13-2007 01:23 PM
Hardware Review: Overdue M2ATX review elstev0 The Review Palace 0 09-03-2006 09:10 AM
Hardware Review: Car2PC Alpine MBUS review MatrixPC The Review Palace 6 06-02-2006 06:39 AM
