Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 03-30-2007, 05:48 PM   #1
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
question about the "onresume" command
I can say that i have tryed everything I found after serching for "onresume" (which is pretty straight forward) but nothing seems to work!
Here is the code of my ExecTBL... programs is in C:\ so is not a path problem:
/, This (OPTIONAL) file contains translation commands.
/, RR will accept the commands defined on the LEFT
/, and execute them as expressed on the RIGHT
/, you can use this to create or redefine any command
/, (or to add functionality to any syandard command).
/, The Format of this file is (by choice):
/, "<COMMAND>","<EXEC COMMAND>"
/, "<COMMAND>","<EXEC COMMAND>",filename.skin
/, Examples:
/, "AUDIO","LOAD;audio_player.skin;Audio Player"
/, "RESTARTSONG","SEEKTO;00:00",audio_player.skin
/, Extas:
/, XM, FM and MM can be used instead of a skin file
/, to be translated when XM, FM or MM is turned ON.
/, PLAY, PAUSE and STOP can be used instead of skin
/, file name so it executes commands based on MP3 or
/, Video playback status.
"QUIT","SendMsg;RRCDRip;showplugin||bye"
"BYE","QUIT"
/, Set Bellow the Path to the CDRip plugin (if used)
"CDRIP","PLUGIN;RRCDRip;C:\VBStuff\Road Runner\CDRip\CDRip.exe"
/, You can add commands to execute before suspend
/, and after resume, using the codes bellow:
"ONSUSPEND",""
"ONRESUME","RUN;C:\test.bat"
"ONLINE",""
"OFFLINE",""
"ONFILECLICK",""
"ONDIRCLICK",""
"ONPLCLICK",""
"ONDLCLICK",""
"ONPBCLICK",""
"ONPLSELCLICK",""
"ONDLSELCLICK",""
"ONSONGSTART",""
"ONSKINSTART",""
/, For MediaCar Compatibility only:
"AUDIONEXT","RRNEXT"
"AUDIOPREV","RRPREV"
Also, I'm running version 11.12.06 and if it helps this is my RR.ini
Thanks in advance for any input.
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 03-30-2007, 07:11 PM   #2
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
try "RUN;C:\Windows\notepad.exe" and see if it works, if .bat is not associated properly on your machine you may need to do something like 'cmd /c run.bat'.. I'd just double check the path and maybe try RUNW instead of just RUN
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 03-30-2007, 07:47 PM   #3
Para Laura
Yes notepad works just fine...well basically I have made a .bat file (also tryed with a autoit exe to call the .bat file) and it doesn't work checked the path and tryed runw and nothing works.
All I want is to execute rasdial.exe so I don't have to push any button to be connect it to the net after hibernation.
Thanatos.
Nissan Aux-in MOD
Old 03-31-2007, 01:08 AM   #4
guino's Avatar
that's weird I mean, if notepad works, any other command should also work.. you should even be able to run rasdial directly.. to be honest, chances are that the command IS indeed working but rasdial is bailing out on you for some reason.. try adding a delay to it using "WAIT" or adding a delay to your autoit/bat script.
Old 03-31-2007, 05:22 AM   #5
Para Laura
After trying everything I just made a button to run the .bat file and it works (really weird than it doesn't on onresume) I will try the delay tomorrow morning... Also I'm using scripts cus I don't want the little command prompt splash when it is benn execute)
Thanks.
Thanatos.
Nissan Aux-in MOD
Old 03-31-2007, 07:20 AM   #6
wfs1's Avatar
wfs1 is on a distinguished road
Where is the ExecTBL file located? In RR or Skin directory?
wfs1 is offline   Reply With Quote
Old 03-31-2007, 10:28 AM   #8
MGD
MGD's Avatar
MGD is on a distinguished road
If you runnimg the new Beta you can use the topmost command and you will not see the Cmd Window.
SETTOPMOST;RR;True||RUN;C:\Test.bat||WAIT;5||SETTO PMOST;RR:FALSE
MGD is offline   Reply With Quote
Old 03-31-2007, 12:13 PM   #9
Para Laura
Quote: Originally Posted by Enforcer View Post
both.
FU doesn't have a ExecTBL file, I just have the one in RR root folder.
Thanatos.
So it will be something like this:
"ONRESUME", "SETTOPMOST;RR;True||RUN;C:\Test.bat||WAIT;5||SETTO PMOST;RR:FALSE"
Thanks for the tip.
Thanatos.
Nissan Aux-in MOD
Old 03-31-2007, 03:10 PM   #10
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Thanatos.
It can have though
you can have one in the skin folder as well. Mine does as does LSXVoid and JohnWPB's. And I believe chucks skin has a humongous one
Enforcer is offline   Reply With Quote
Old 03-31-2007, 03:18 PM   #11
Chuck's Avatar
Chuck is on a distinguished road
Almost did not fit here
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 04-01-2007, 03:22 AM   #12
Para Laura
It can have though
I know that, believe me I seen them inside the skin folder... I was just affirming that the skin that I was using doesn't have one
also don't flame me for been a RR n00b
Thanatos.
Nissan Aux-in MOD
Old 04-01-2007, 07:03 AM   #13
wfs1's Avatar
I should have said in "which" ExecTBL file is the "test.bat located. I also have two. I was trying to see when/where "test.bat file was being called.
Now, when I set up a rasdial batch file, I put the .bat file in the "root" directory of my C drive.
Also, is your Communication device an USB?
If so, go into device manager and check the settings for it in both the power management section of the USB controllers "for allow device to be turned off" and sometimes in the network or modem connections for device power saving or "allow wakeup".
If you have multiple USB devices and do a "wakeup" not all USB devices re-initialize the same or in a timely manner.
Old 04-01-2007, 09:40 AM   #14
Confusion Master
Enforcer's Avatar
Thanatos.
As if?
Damn N00bs.
Old 04-01-2007, 01:00 PM   #15
Para Laura
No you didn't!!!
Thanatos.
Nissan Aux-in MOD
Any in-dash monitor with built in FM Radio QUESTION. ??? 74Camaro LCD/Display 2 05-02-2006 06:15 PM
Command to Switch Skins Cruizer FreeDrive 7 10-01-2005 06:02 PM
Question regarding Devcon & GPS hibernation Sonicxtacy02 GPS 1 08-15-2005 01:12 PM
Paint And Polish Question gboy Fabrication 8 08-13-2005 08:22 PM
FM Card Question.... Superbike1k Car Audio 1 05-16-2005 10:03 AM
