Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 04-04-2007, 02:27 PM   #16
Chuck's Avatar
Chuck is on a distinguished road
I have the HQCT and not very happy with it.
How does the Silabs compare in your opinion CdRsKuLL?
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 04-04-2007, 02:41 PM   #17
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
http://www.mp3car.com/vbulletin/1042444-post97.html
CDR's exact words were:
http://www.mp3car.com/vbulletin/1042297-post2.html
Though I'll warn you the HQCT is still the only one with AM.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 04-04-2007, 02:46 PM   #18
Cheekz185 will become famous soon enough
Quote: Originally Posted by CdRsKuLL View Post
all you need to do is solder a car socket or whatever you want to call it in place of the little wire fly lead.. on splitting the case (just pulls apart) unsolder the wire aerial and solder the center of the car aerial in its place, right next to this is a bigger hole, solder the ground of the car aerial to this.. then snip the plastic bits that went through this hole from each side of the casing and zip tie it all together.. jobs done.. I've just been out again for a lttle drive.. just so I can listen to the radio.. how sad is that.. lol but ts been soooo long since Ive had a proper radio in the car of this quality.. it also has ts own volume slider and mute, so its easy to set the volume of it to tie into your system.
CdR
When u say "Car socket" do you mean the car's antenna?
And what about the cars aerial? what are you referring to?
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 04-04-2007, 02:52 PM   #19
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
Right, spent 5 mins transfering the code over.. I think I have it all.. but might of missed something
I have enclosed the edited file from the current source.. so if you havent changed anything then you should just be able to drop it in :-)
Chuck.. Yeah I am really impressed with this little baby, the fact that you just plug it in, no extra power / line in cables are needed is great for a start.. because it pipes sound down the usb cable, means theres no reason why you cant have the radio up front where your aerial connector is rather than running the aerial cable to the back...
The Antenna in the uk is called the aerial here.. the socket that I refer to I think also also called a motorola female plug.. I will take a picture later for you...
CdR
CdRsKuLL is offline   Reply With Quote
Old 04-04-2007, 03:01 PM   #20
Chuck's Avatar
Looks like someone will come out with AM/FM soon.
http://www.silabs.com/tgwWebApp/publ...t/en/index.htm
2001 S10 ZR2
Old 04-04-2007, 03:30 PM   #21
Raw Wave
Gobby is on a distinguished road
OK, so who will let me order one and have it proxy delivered and forward on to me??
Gobby is offline   Reply With Quote
Old 04-04-2007, 03:34 PM   #22
FreeDrive Creator
CdRsKuLL's Avatar
me..u know I will :-) MSN me
Old 04-04-2007, 03:54 PM   #23
Raw Wave
You'll keep it! rofl
Old 04-04-2007, 04:22 PM   #24
FreeDrive Creator
CdRsKuLL's Avatar
ok can confirm Guino, that ModRadiator I posted above works with the silabs.. Although i compiled it on your currently released version all 2mb of it.. lol but its working great, mutes ok.. tunes ok :-) very pleased will be great as a temp measure until you work your magic :-)
CdR
Old 04-04-2007, 05:31 PM   #25
guino's Avatar
CdR
Did you actually try the BETA I made and posted on the other Thread http://www.mp3car.com/vbulletin/1042444-post97.html ? It should have even RDS text and the Stereo indicator working.
Old 04-04-2007, 05:32 PM   #26
FreeDrive Creator
CdRsKuLL's Avatar
ok ok.. I passed you the wrong dll.. and I have also played with the code..
It starts / stops the radio and mutes it..
It tunes to the freq
and tuneup / tunedown / fineup / finedown work... I am working on the RDStext and Seek at the moment..
for now here are the amended files..
CdR
Old 04-05-2007, 12:44 PM   #27
Beezer's Avatar
Beezer is an unknown quantity at this point
Looking forward to Guino integrating this into the beta RoadRunner
Beezer is offline   Reply With Quote
Old 04-05-2007, 01:37 PM   #28
FreeDrive Creator
CdRsKuLL's Avatar
its done m8, download the beta above hes amended the file.. I will also be adding rds station / text and signal next week to it.. also changing FU to suit
CdR
Old 04-05-2007, 01:45 PM   #29
Beezer's Avatar
Wonderful! Now to solder an antenna connector onto my silabs radio
So, does this tune stations better than HQCT?
Old 04-05-2007, 02:28 PM   #30
tipo82 is an unknown quantity at this point
Hi, i'm italian, i tested the beta version of road runner with my silabs 4701 usb but in the RDS label i only see "F" and "T" chars blinking...
Can you help me? Some suggestions?
thanks, Giovanni
tipo82 is offline   Reply With Quote
HU Quality AM/FM RDS/RBDS Radio with Features rando Hardware Development 772 12-04-2008 01:11 PM
RoadRunner uses, futures and configuration marsk8er Road Runner 4 08-14-2006 04:46 AM
CarPC with stock radio integration jnye6625 Car Audio 13 12-01-2005 12:40 AM
using my system as a radio as well can i do this madkad Road Runner 7 08-20-2005 04:18 PM
FM radio Question thepogcbr900rr General Hardware Discussion 5 05-09-2004 07:27 PM
