Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 04-16-2007, 03:16 AM   #76
Griff1's Avatar
Yeah but what if we had 2,could it be done?
P4 2.8 HT, 1GB Ram, 200Gb 3.5 HD, M4-ATX,2 x Silabs USB, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RoadRunner, iGo8,Custom Freedom 2.1
Griff1 is offline   Reply With Quote
Old 04-16-2007, 03:26 AM   #77
FreeDrive Creator
CdRsKuLL's Avatar
Hi m8, in theory yeah sure. I think this is what RRMobile was thinking of doing. One device would work as it is now and the second one would scan the rest to see if the signal strength was more or less on other channels if it was say +5 more then it would tell the 1st dongle to swap channels.. this however would cause a break in your listening, so you would need to swap the dongle being used to listen over so you wouldnt get this break. Still this would be easy in coding.. I am going to have a look at the rds text sometime to see if they supply a checksum or something just to see if I can improve on it, but I have no plans on coding up a dual tuner type thing at the moment, just got too many things going on at the moment for one more.
CdR
www.extremeoc.co.uk me building a murcielago kitcar ! - check it out !
www.cellsecurity.co.uk are my new employer ! - yeah I got a job !
CdRsKuLL is offline   Reply With Quote
Old 04-16-2007, 04:33 AM   #78
The Vauxhall Vectra Project
ccsnet's Avatar
I think I have to buy two of these things......
Terran
ccsnet is offline   Reply With Quote
Old 04-16-2007, 12:46 PM   #79
307SW_NLD's Avatar
Thats not entirely true.
EON sends information about other frequencies as well. If there is a TA at another station in the same network, the tuner can switch to this frequency for the duration of the TA.
Futhermore, TA allows you to listen to MP3's and get interupted (MP3 paused) when TA is active.
I have been implementing this in my HQCT RR extension plugin at its working very well. Same thing for NEWS broadcasts. You can also set a predefined volume (as the standard headunits do as well) for the TA and NEWS.
Still waiting for my silabs to compare them with my HQCT.
My car: 2003 KIA Sorento 2.5 CRDI AUT
Hardware: EPIA SP13000, 60Gb 2.5"HDD, M1-ATX, Lilliput 7", RADIO SiLABS, K8055 BOARD
Software: Road Runner, FreeDrive, PowerDVD, WinXP SP1
See: Velleman K8055 Plugin for Road Runner
Progress: [XXXXXXXXXX] 50 % DONE
307SW_NLD is offline   Reply With Quote
Old 04-16-2007, 10:52 PM   #80
Backorder
silabs FM on backorder
Dave323Ci is offline   Reply With Quote
Old 04-18-2007, 05:46 AM   #81
ccsnet's Avatar
Any updates any one ? BTW - They have 100 on back order - 7-10 days as I post.
Terran
Old 04-18-2007, 05:56 AM   #82
GizmoQ's Avatar
Has anyone else noticed that with the Silabs Radio when you first run Radio, RR starts on station #2, but the RR screen is highlighting the first channel and the labels are all pulled from the first channel. As soon as I select any other channel, all works good. But when I exit radio and return, its playing channel #2 again, but highlighting the last station I was listening to. Again selecting any other channel returns everything to normal. Look like Radio.ini is being updated, just not used.
Edit: I just tried the stand-alone Silabs radio program and thats where the startup issue is originating. It seems the Silabs hardware remembers the last station used by the standalone program and thats where it starts everytime its started. I would assume the RR integration could be updated to issue a change station command everytime its initiated based on Radio.ini and that would fix the problem.
HARDWARE: Fujitsu Stylistic 4121w/ WiFi & mini dock, Sierra Wireless Aircard 550, EXP PCMCIA Portable DVD-RW, Silabs FM, WinTV USB w/-26dB diversity antenna, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 USB joystick, BluSoleil USB Bluetooth
GizmoQ is offline   Reply With Quote
Old 04-18-2007, 06:24 AM   #83
Mr.Fabio's Avatar
I have the same issue.
The same also resuming from hibernate...
Mr.Fabio
_______________________
Travla C134
Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Hermes
RoadRunner - PC Navigator 7.1 - FreeFone
Mr.Fabio is offline   Reply With Quote
Old 04-18-2007, 06:34 AM   #84
FreeDrive Creator
CdRsKuLL's Avatar
I will have a look and fix it when I get chance.. sorry
Old 04-18-2007, 07:34 AM   #85
RDS text
I have no problem with silabs radio working in rr..... however the RDS text/name produce stray letters and info..... from what I have read it is in the dll ....is the problem in my configuration or in the dll lll some help would be great
Senile is offline   Reply With Quote
Old 04-18-2007, 07:54 AM   #86
GuMiSZu's Avatar
Silabs HW data
Could anybody send me the hw.txt in Roadrunner dir, who has Silabs USB FM
I try to change the USBradio.dll to my ADS intant fm tuner..
THX
GuMiSZu is offline   Reply With Quote
Old 04-19-2007, 05:23 AM   #87
Cant wait till they bring out the AM/FM version of this (hopefully with improved reception).
Does anyone here think its worth talking to their tech department to suggest any necessary PCB changes to the USB unit for car usage? I think they would be quite happy to talk to us, and possibly implement minor changes to allow better in-car usage. They will certainly get a LOT of business out of this community if the result is a 'plug-n-play' product .
Possible improvements I believe could come from:
* Impedance matching (to suit/incorporate car antenna)
* Ability to connect aftermarket antenna connector
* Increasing the sensitivity from 1mV to 2mV (I think most car radios' sensitivity is >=2mV).
Iceman_jkh is offline   Reply With Quote
Old 04-19-2007, 05:37 AM   #88
henkbliek's Avatar
Not worth; this board is just an evaluation and not intended for 'end user' applications. Also the 'lot of business' is perhaps in the 100's, not quite big if you consider that these devices are targatted at mobile phone and PDA implementations...
white bream
working on a trilogy: CARGO - UNIGO - MERGO
CARGO = the Car Computer
Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
henkbliek is offline   Reply With Quote
Old 04-19-2007, 11:14 AM   #89
Griff1's Avatar
I was just about to say roughly the same thing.
The thing with reference designs is that there made to show whats possible,nothing more.
With that said anyone selling to the end user (adstech for instance) might be interested in producing the am/fm model (or changes) if they think there's a market.
Old 04-20-2007, 07:36 AM   #90
Very interesting... since I'm planing on buying one of these babies instead of the RadioShark...
one small question about the RR integration, will it pause whatever I'm doing and switch to the radio if there's a TA message "on air"... Since I drive a lot for my work that's one big thing I'm missing from my old radio...
[edit]
Just read though the posts again, a bit better this time
so since this also supports EON it should work with TA using only 1 reciever, I really hope so since I dont have the cash to buy 2 of these!
Swedish site for CarPC's
http://www.bilpc.info
Naesstrom is offline   Reply With Quote
RoadRunner uses, futures and configuration marsk8er Road Runner 4 08-14-2006 03:46 AM
HU Quality AM/FM RDS/RBDS Radio with Features rando Hardware Development 771 02-10-2006 09:20 PM
CarPC with stock radio integration jnye6625 Car Audio 13 11-30-2005 11:40 PM
using my system as a radio as well can i do this madkad Road Runner 7 08-20-2005 03:18 PM
FM radio Question thepogcbr900rr General Hardware Discussion 5 05-09-2004 06:27 PM
