The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Search this Thread Display Modes
Old 04-06-2007, 01:32 AM   #1
xpluis's CarPC Specs
xpluis's Avatar
Vehicle: Dodge Neon
My Photos: (4)
How do Mapmonkey autostart on RR start
Ok i search and search but..... i dont know how i can auto start mapmonkey when Road Runner start in ExecTBL.ini only have options for hibernation, resume etc..... but i need that road runner start mapmonkey when it start for fist time.
xpluis is offline   Reply With Quote
Sponsored Links
Old 04-06-2007, 01:54 AM   #2
wizz's CarPC Specs
wizz's Avatar
Vehicle: 03 Focus Zetec
My Photos: (0)
It needs to be set up in RRConfig. These are my settings, they represent the default path for MapMonkey. Make sure you can run MM successfully in stand alone mode first :-
PS: If you have got this far and want MM to load immediately. Use startcommand=(MM) in rr.ini to load the App(?) of your choice.
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
wizz is offline   Reply With Quote
Old 04-06-2007, 09:05 PM   #3
xpluis's Avatar
Vehicle: Dodge Neon
My Photos: (4)
Good idea, but the comand is worg the command is:
startcommand=Runq;C:\destinatorApps\Map Monkey\MapMonkey.exe
With Run or runq or runqw or runw....
I try runq for start mapmonkey in background, but mapmonkey start always in first plane............ some idea to fix it?
Old 04-06-2007, 10:54 PM   #4
Iceman_jkh's CarPC Specs
My Photos: (1)
Heres something I did to get RR to open a program but minimized/background.
Theres probably other ways.. but this works for me.
Steps:
1. Create a shortcut to Mapmonkey (put it on the desktop for this example)
2. Open the shortcut properties, and set RUN to MINIMIZED.
- If clicked, this will open MM, but minimize it to the task bar - (try it)
3. Make a batch file in windows (called Mapmonkey.bat)
4. Edit the batch file so that it runs the shortcut you made. (EG: "C:\Documents and Settings\CARPC\Desktop\Mappmonkey.lnk" .. no quotes)
4. use "startcommand=Runq;C:\Documents and Settings\CARPC\Desktop\Mappmonkey.bat"
This will run the batch file (in hidden mode). After the batch file has executed - MM loaded to the task bar - the batch thread dies, basically hiding any trace of its existance. You end up with MM on the taskbar and RR on the main focus.
Hope that made sense.
Ice
PS> You can use this technique for loading (but minimized) any apps you like.. just create shortcuts for each of them. Set RUN to MINIMIZED for each shortcut.. and then put each shortcut on its own line in MapMonkey.bat (perhaps call it LOADER.bat if you load multiple files) and make sure to change the filename in STARTCOMMAND to match whatever you call the batch file.
Iceman_jkh is offline   Reply With Quote
Old 04-07-2007, 04:13 AM   #5
My Photos: (0)
May I suggest to use Garonav? It's a littel bit better!
veldom is offline   Reply With Quote
Old 04-08-2007, 12:52 AM   #6
xpluis's Avatar
Vehicle: Dodge Neon
My Photos: (4)
Garonav?????? ok downloading......... i hope garonav have full integration with RR. Share actual street, actual speed etc same Mapmonkey.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Failed Hiding of Start Bar, Minimize Errors DaRacerz RR Bug Tracker 4 11-04-2005 04:36 PM
RR doesn't start Phoco on initial load.. DutchBurner Road Runner 16 11-04-2005 01:17 PM
RR Interchange - Update RR via a USB Media Stick Gobby Road Runner 60 10-04-2005 04:48 PM
IE in RR bug accentsound RR Bug Tracker 2 07-10-2005 01:21 PM
Autolaunch Mapmonkey weekendowel Road Runner 2 06-19-2005 07:53 AM
Sponsored Links
Ad Management by RedTyger
