The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 04-27-2007, 01:10 AM   #1
GuMiSZu's Avatar
Vehicle: 94/Toyota/Corolla 1.6GLI
My Photos: (0)
Cool Silabs and ADS compatible USBRadio.dll ...
Hi!
Here is an version that can use ADS instantFM and Silabs FM too.
It detects the tuner no setup needed.
Can anybody try it with Silabs FM tuner?
It works with my ADS tuner but i can't try with Silabs.
(Thanks For Steffen for HELP)
This is an 2 in 1 dll
Englishlessness :(
GuMiSZu is offline   Reply With Quote
Sponsored Links
Old 04-27-2007, 06:07 AM   #2
GizmoQ's CarPC Specs
GizmoQ's Avatar
Vehicle: Several
My Photos: (78)
Quote: Originally Posted by GuMiSZu View Post
Hi!
Works good. Still need an RDS filter or something, but tune+/-, freq+/-, alternate station, coverage, signal, PS, PTY, Date and Time, etc working fine.
HARDWARE: Fujitsu Stylistic 4121w/ WiFi & mini dock, Sierra Wireless Aircard 550, EXP PCMCIA Portable DVD-RW, Silabs FM, WinTV USB w/-26dB diversity antenna, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 USB joystick, BluSoleil USB Bluetooth
GizmoQ is offline   Reply With Quote
Old 04-27-2007, 06:16 AM   #3
GuMiSZu's Avatar
My Photos: (0)
RDS filter or something: What do you mean?
what is rds filter?
maybe i try to make it...
Englishlessness :(
Old 04-27-2007, 07:51 AM   #4
Vehicle: 2005 Ford Ranger
My Photos: (0)
I have a silabs radio..... the dll works with it ... however the RDS information is still having problems.... there are stray characters in the text....example....lite$rok@ at 105K.... which is mostly correct.... you are doing a great job.... if this last problem can be worked out this will be a great addtion to rr..
Senile is offline   Reply With Quote
Old 04-27-2007, 08:56 AM   #5
The Vauxhall Vectra Project
ccsnet's CarPC Specs
ccsnet's Avatar
Vehicle: Vauxhall Vectra C SRI XPack Auto - v5 ( Via 12000 based ) Sygic & With FreeICE
My Photos: (0)
While your looking.... does this version support auto tuning to the strongest signal ? I know CDR was going to have a look but if your programing at the mo....
I think the radio text thing was giving duff chars as well as the RDS info.
Terran
PS TA TP EON next please [begmodeon]
ccsnet is offline   Reply With Quote
Old 05-08-2007, 06:37 AM   #6
Vehicle: BMW 525i E34
My Photos: (1)
is there an overview of the functions/procedures in this? so the dll can be used for other frontends to implement the silabs radio?
mischka76 is offline   Reply With Quote
Old 05-13-2007, 07:01 PM   #7
My Photos: (0)
Yes this would be very nice or is there any way to get the actual source?!
I'll take a look into the rr source for implementing the dll into a meedio-plugin but such an overview would be fine.
NICE WORK!!!
FlashIT is offline   Reply With Quote
Old 05-14-2007, 12:40 PM   #8
My Photos: (0)
After some testing with C# importing the dll i am getting strange return values after ScanStation/SeekStation :-(
return - key - station
5330123133904036 - 040 - 91.3MHz
5330123133906636 - 066 - 93.9MHz
5330123133915636 - 156 - 102.9MHz
5330123133919636 - 196 - 106.9MHz
so i reason this long for 104.4 and YES it works:
5330123133917136 - 171 - 104.4MHz
After initialisation the dll returns for example
5329384399531724 which seems to be the same like above-mentioned
5330123133906636 because after next seekup the
5330123133915636 follows and then after seekDown again the
5330123133906636 is set and sounds same like this 5329384399531724!
another conclusion after some calculation:
5329384399540724 sould also be same like 5330123133915636 ?!?! -> tried: yes it is... hmm...
But what do these longs mean, because i also can tune for example to 91300 getting every time such a representative long value as "GetCurrentStation()"
It would be more useful getting the right frequencies
Any ideas?
I also found out that this dll returns only "" for GetRDS() :-( Is there anyone who gets RDS-Data with ADS?!
Old 05-16-2007, 11:22 PM   #9
Iceman_jkh's CarPC Specs
My Photos: (1)
subscribed
Iceman_jkh is offline   Reply With Quote
Old 05-16-2007, 11:31 PM   #10
EL CAMINO's CarPC Specs
EL CAMINO's Avatar
Vehicle: 1981 chevy el camino
My Photos: (0)
i have an ads tuner and the rds data is coming in, there is some problems with the data not showing right.
EL CAMINO is offline   Reply With Quote
Sponsored Links
Old 05-17-2007, 04:55 AM   #11
My Photos: (0)
RR or Radiator or exactly this dll-function "GetRDSData()" in an own written program ?!
RR seems to give me the RDS data also (with much waste in it) but looking into the sourcecode it seems to use a function named "VB_GetRDSData()" and i am not sure if this is the same function :-/ and i dont know how to use it in C#
I get an error saying i cannot use this writeprotected item...
Old 06-18-2007, 01:35 PM   #12
307SW_NLD's CarPC Specs
307SW_NLD's Avatar
Vehicle: 2003/KIA/Sorento 2.5 CRDI
My Photos: (0)
Is it possible to expose a VB_SetVolume function as well. If I mute the radio I can still hear noise comming from the radio (probably the D/A converter still working). I noticed that it disapprears using the Silabs sample application when lowering the volume.
My car: 2003 KIA Sorento 2.5 CRDI AUT
Hardware: EPIA SP13000, 60Gb 2.5"HDD, M1-ATX, Lilliput 7", RADIO SiLABS, K8055 BOARD
Software: Road Runner, FreeDrive, PowerDVD, WinXP SP1
See: Velleman K8055 Plugin for Road Runner
Progress: [XXXXXXXXXX] 50 % DONE
307SW_NLD is offline   Reply With Quote
Old 06-24-2007, 08:00 PM   #13
My Photos: (0)
subscribed
atvracer is offline   Reply With Quote
Old 07-04-2007, 06:07 AM   #14
ato
My Photos: (0)
What commands can I use from this dll? Is there any function list and description avable?
ato is offline   Reply With Quote
Old 07-04-2007, 07:09 AM   #15
My Photos: (0)
Sourcecode? Link
For an ADS/Silabs USBRadio.dll you have to edit some files...
"FMRadioDevice.h"
//Device data
#define silabs_FMRADIO_VID 0x10C4
#define silabs_FMRADIO_PID 0x818A
#define adstech_FMRADIO_VID 0x06e1
#define adstech_FMRADIO_PID 0xa155
"FMRadioDevice.cpp"
int CFMRadioDevice::GetAudioDeviceIndex()
//If FM Radio is found, open the radio immediately, this is our device
if (!strcmp(waveInputCapabilities.szPname, "FM Radio") || !strcmp(waveInputCapabilities.szPname, "ADS InstantFM Music"))
"FMRadioDevice.cpp"
bool CFMRadioDevice::OpenFMRadioData()
//Check that the VID and PID match
if ((hidDeviceAttributes.VendorID == silabs_FMRADIO_VID) && (hidDeviceAttributes.ProductID == silabs_FMRADIO_PID) || (hidDeviceAttributes.VendorID == adstech_FMRADIO_VID) && (hidDeviceAttributes.ProductID == adstech_FMRADIO_PID))
Ciao
Steffen
wzpc is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
ADS InstantFM integrated to RR GuMiSZu Road Runner 37 06-28-2008 11:17 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
