The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 05-12-2007, 11:55 AM   #1
Vinster03XR's CarPC Specs
Vinster03XR's Avatar
Vehicle: 03 Toyota Matrix XR
My Photos: (0)
RR, iGuidance v3, USB GPS and XPort question
I'm using the software listed in the title....
On boot up everything is dandy and I couldn't ask for better..
but comming up from hybernate, the USB GPS (Holux) doesn't come back right away... it eventually does..and XPort looses connection and doesn't re-establish the connection at all...
Does RR really need to see the GPS??? If I only run iGuidance I have no issue.. it picks up after about 30-40 secs...
Thanks for any help
Vin
Carputer works... but will never be complete....
Vinster03XR is offline   Reply With Quote
Sponsored Links
Old 05-12-2007, 06:37 PM   #2
lbridges's CarPC Specs
Vehicle: 2002 Toyota/MR-2
My Photos: (8)
RR only needs to see the GPS if you want to use one of the add-ons, like a speedo.
I run a very simple system using the same stuff you list except I don't use XPort since I don't use GPS for anything other than iGuidance.
lbridges is offline   Reply With Quote
Old 05-13-2007, 08:44 AM   #3
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
When you open the XPort control window, do you see the indicator to the left of the input port stay on or stay off, or does it go on and off every 20 seconds or so? If the GPS is not available for 30 to 40 seconds, you should see it stay on after about 3 or 4 times.
XPort 1.24 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 05-13-2007, 09:27 AM   #4
My Photos: (0)
I have a check box that says Enable Service... which is checked...
On boot up I'll see the Data scroll in the status bar when it's working.... after comming from hybernate though nothing will scroll.... I have to close everything and start it up from scratch...
Old 05-13-2007, 09:52 AM   #5
Curiosity's Avatar
My Photos: (3)
You should try version 1.10 and see if that helps. It has different timings and detection for inactivity.
Old 05-13-2007, 11:23 AM   #6
treetop777's CarPC Specs
treetop777's Avatar
Vehicle: 1981 Ford F-100
My Photos: (0)
Also, i was looking at this thread http://www.mp3car.com/vbulletin/soft...bernation.html
Close to the end, they talk about something called "devcon"; maybe it will give you some ideas.
treetop777 is offline   Reply With Quote
Old 05-13-2007, 03:08 PM   #7
Curiosity's Avatar
My Photos: (3)
I wouldn't expect DevCon or the built-in graphical DevCon to help since it's working without XPort. I would know more if I knew the state of the input port indicator, but it's probably just the driver isn't synchronized with the data coming in and has to be reopened again.
Sponsored Links
vB code is On
Trackbacks are Off
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 55 06-08-2008 08:54 PM
RR - iGuidance 3.0 embedding – Solutions Consolidated. EricE GPS 12 03-21-2007 10:34 AM
iguidance GPS com port shannara22 Road Runner 7 12-04-2006 09:53 AM
GPS problem with RR running as shell ajamils Road Runner 8 11-09-2006 12:02 AM
RR, Xport and GPS Naesstrom Road Runner 7 08-19-2006 03:34 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
