05-19-2008, 06:46 PM
#511
Raw Wave
Vehicle: 01 Ford ZX3
I believe that the prob has been fixed, and I'm still working on the this next update..
05-19-2008, 07:09 PM
#512
Confusion Master
Vehicle: 1997 BMW E36 328I
yep. OK now.
05-27-2008, 04:34 PM
#513
Quote:
*Advanced AVS settings ( may also be known as the RR screensaver )
looking how to disable the AVS form going into the screensaver mode
05-31-2008, 02:51 AM
#514
Raw Wave
1.0.1.0
Fixed:
*Screen limit when =3
*Song Intro/scan
*Winamp Cass
*Time&Date's
Changed:
*Tried to speed up the startup execution time a little
Added:
*ResumeCheck
*Phoco Disable
*HD Radio Comport
[Edited]
*Launch path auto fills in if in existing path
Coming Soon:
Post suggestions in thread!
Thanks to those who have donated!!
05-31-2008, 03:10 AM
#515
Vehicle: Citroen Xsara 2002
thnx for the update blue.. i am having trouble starting the EXE in Vista.. it does not start..even when using compatability mode.. my home pc is vista, so testing will not be possible, i will try it in the car..
EDIT:
not a vista problem..it seems like a problem with the SKIN FOLDER PATH..it will not run unless you delete the skin folder line from rr.ini..
when you run the config then it will let you browse for a skin folder but the config will hang there
05-31-2008, 02:19 PM
#516
EDIT:
The same here
Kanenas
05-31-2008, 04:16 PM
#517
Raw Wave
EDIT:
Quote: Originally Posted by Kanenas
The same here
Kanenas
What is your guys skin path's? I do not have this problem on mine machine. When does it seem to hang, as soon as you click the browse button next to the path?
IDK... Try this one...
05-31-2008, 05:24 PM
#518
Vehicle: 2001 Ford Crown Victoria
just tried it. i click on the exe, then it appears it does not open, but in the task manager it shows it running.
edit: just removed the lines in rr.ini for skin directory now it opens.
edit2: now it opens everytime after saving settings, outside of the road runner folder. inside the folder it does not open.
05-31-2008, 05:43 PM
#519
ok heres what i did to get it to work, (at least for me).
I deleted rr.ini, then ran rrconfig.exe from post #517, in c:\program files\road runner\rrconfig.exe and let it make a new rr.ini......
now its working. weird but it is working.
05-31-2008, 06:44 PM
#520
Vehicle: 1981 Ford F-100
Neither open from within the RR folder; from the outside it opens but blank (no settings) - it does not read rr.ini
05-31-2008, 06:54 PM
#521
it does not work also..
the problem is the line for "skinpath"
if you delete manually that line it will run fone.. that is why it runs fine outside the RR directory..it does not find a rr.ini, so it creates it..as soon as you populate that line it will not run.
if you open the config then and press the browse button it will let you choose a path but then the config will freeze..not able to save etc..you have to close it with Ctrl-Alt-Del
My skin path is C:\Program Files\Road Runner\Skins\MMM nothing weird, i tried changing the path to something shorter..but no go as well
05-31-2008, 07:47 PM
#522
Raw Wave
Can someone post(attach) their NON working rr.ini file so maybe I can pin point as to where/why this prob is occurring...
Thanks..
06-01-2008, 03:29 AM
#523
here you are
by nono working i mean not working in the NEW config..
i actually opened the "working ini" with the old config and populated the skin path...to make it none working in the new config
06-02-2008, 12:56 AM
#524
Raw Wave
Ok problem found and fixed!!
Re download as I didn't change the version just for this fix...
Oh and Nomader what ever happen to that translation?
06-02-2008, 12:11 PM
#525
good job mate, i ve been meaning to finish it...i know  just been busy with life..moved to a new city, new job etc..
| Thread Tools |
| Display Modes |
Linear Mode
