Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 06-22-2007, 08:49 AM   #1
CombatCQB is on a distinguished road
Switching between RR and copilot
I'm working on a new setup that uses RR for media player and ALK Copilot for GPS. I've configrued both to leave enough space for a task switcher called ObjectDock. ObjectDock has a nice feature where a shortcut will launch one instance of a program and switch back to it on subsequent clicks. This works like a charm with Copilot, every click will bring the guidance window to the foreground. But RR doesn't seem to want to budge! Click the shortcut 1st time works and launches RR. But once other apps are in front, RR won't come to the foreground. It is not minimized, just in the background. If I click the RR taskbar icon, RR will switch to the foreground just fine.
I see my options so far:
1) maybe it's a small issue in RR that I (end user) can fix.
2) find another utility that will call the RR window properly.
3) drop the shortcuts and use the task bar icons to switch.
Anyone know why RR doesn't come to the foreground?
CombatCQB is offline   Reply With Quote
Old 06-22-2007, 09:05 AM   #2
Raw Wave
ShawJohn's Avatar
ShawJohn is on a distinguished road
I think you have found some similar hitch to the one I had when trialling TomTom on the PPC emulator.
I have to make GPS load on startup, completely independant from RR.
Then have RR call up an empty batch file instead of giving RR your full GPS path, this then triggers RR to look for the window with the right name to embed.
If you don't use the blank batch file, it will try and load a new GPS instance everytime you try to switch back to it.
It might work, it might not.
Does ALK CoPilot come with EU maps? I bought a second hand copy a few years ago and it only had US maps
It would be nice to try it out.
ShawJohn is offline   Reply With Quote
Old 06-22-2007, 10:30 AM   #3
Using a empty batch file sounds like an interesting idea. Although I was not planning to use RR's embedded feature for GPS, I might see what this does with copilot.
I think ALK should have a EU version of Copilot. The one I bought came with US/Canada maps, but try to find the ALK website in europe that should carry an EU version.
So my issue is really switching back to RR after copilot is in the foreground. I might try writing a small program that will call the RR window to the foreground. But I need to find the code to switch windows first.
Old 06-22-2007, 11:12 AM   #4
Raw Wave
ShawJohn's Avatar
Just let it embed into RR and it solves the problem... If it will embed that is
The empty batch file is just so RR has a command to run, which I believe then makes it look for a matching window name to embed. As it is already open and running it will grab the Copilot window and embed it. Once embedded your problem should disappear.
Old 06-22-2007, 11:22 AM   #5
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Given some more info, I could write a very quick app the mimics the the your using already, with the RR prob fixed...
such as how many progs R U switching between, 3?
could also be a button located on the screen somewhere instead of clicking the icon, maybe even allow to change the button loc depending on what app is in focus?
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 06-22-2007, 01:30 PM   #6
I've found this very neat command line utility that might do what I need:
http://www.xsteve.at/prg/win/
I simply make a shortcut to it with an argument for th window name and it will bring that window to the foreground. Plus it will also launch an application if the window name is not found. This seems like a very useful util.
Old 06-22-2007, 02:02 PM   #7
The Curator
Blue ZX3's Avatar
well, I just jumped into it anyway as I just can't get away from these little helper kinda apps..
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 06-24-2007, 10:20 PM   #8
The Curator
Blue ZX3's Avatar
Here is my sm app.
features:
*button overlay w/ transparentcy setting
*diff button loc per app
*runs prog if not running
*easy setup
Put in a folder and Run. Upon first run will bring up a setup window to set up 1- 5 apps.
By default, App1 will start upon starting app
Use tray menu to enter setup again or exit app
App Switcher.exe
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 06-26-2007, 04:53 AM   #9
brodgar is an unknown quantity at this point
I was looking on their site. Yes Co-Pilot 10 is available for about $ 150. To this must be added either $ 99 for the UK map or another $150 for Europe.
Makes it somewhat expensive me-thinks
brodgar is offline   Reply With Quote
Old 01-26-2009, 09:41 AM   #10
legacygt2000 is an unknown quantity at this point
i know this is an older thread but has anyone successfully been able to integrate roadrunner and copilot. I have the truck version and would like to integrate it. If rr does not work, is there another one to recommend?
legacygt2000 is offline   Reply With Quote
Old 01-26-2009, 12:54 PM   #11
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Did you try the app-switch posted above ?
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 01-26-2009, 01:41 PM   #12
Chuck's Avatar
Chuck is on a distinguished road
I use Copilot with my skin - thats why the split top and the bottom bar
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 01-26-2009, 02:53 PM   #13
legacygt is an unknown quantity at this point
thanks guino, link wasn't working earlier but i see i can download it now. i'll mess around with and see what i can do
chuck, i clicked on your skin and it looks great but i don't see copilot anywhere in your screenshots or how it is integrated, can you expand on that?
legacygt is offline   Reply With Quote
Old 01-26-2009, 06:27 PM   #14
Chuck's Avatar
Here are some old pic but my skin still works the basic same way
http://www.mp3car.com/vbulletin/rr-s...16-07-a-3.html
2001 S10 ZR2
Newb question about Copilot and RR datruth99 Road Runner 9 04-24-2006 07:28 AM
Remote controll to always work even with rr minimised fire Road Runner 6 02-23-2006 01:18 AM
