The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 07-20-2007, 04:09 PM   #1
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
RR wont start
When I try to run RR it shows the splash screen with starting winamp, my start button and taskbar disapear, then I hear the windows critical stop bong, then winamp starts, then its all hung, I can alt-f4 to bring winamp to the front and exit it, but the RR splash screen just says not responding.
I have to 3 key, kill RR, then kill explorer and restart it to get my taskbar back.
Odd as I dont have 'hide taskbar' in the config.........
Its also taking about 50% cpu use in its hung state.
I have tried using RR config, re-downloading winamp, and re-downloading the RR binarys (did not fix it.)
also when I did downloaded the installer, it links to rrdownloads.net, which seems to have become a portal for advertising spam
(and didnt fix it either)
I have virus checkers installed and anti spamware, I dont think I'm infected, I dont p2p for executable files, and everything else is still fine.
So, anyone else problems starting RR at the moment?
Lez.
XM 2.1TD ~ Morette triple headlights+HID ~ Leather kit ~ XC70 alloys
Exhaust rear boxes removed ~ meshed air filter
lez is offline   Reply With Quote
Sponsored Links
Old 07-20-2007, 04:21 PM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
nope no problems, but it sounds like your installer is prettty outdated if it asks for the old site. Someone here made a new one, try it first.
And if it hides the taskbar and you told it not to, then obviously the config file is messed up. Check in there.
Old 07-20-2007, 04:32 PM   #3
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
yeah thought it would be just me lol.
it was working last time I ran it, about a month ago.........
Lez.
Old 07-20-2007, 04:42 PM   #4
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
ok had a look in debug.tx says its images........
So I just reinstalled, and downloaded a skin I have never used before etc, and I get this.......
road runner splashscreen (from skin)
bong critical stop
winamp
50% cpu usage
application hung.
debug.txt says
20/07/2007 22:40:47: Start -- Version: 12/04/2007
20/07/2007 22:40:47: Master Vol: Volume Control/4
20/07/2007 22:40:47: GetLineControl Failed: 401
20/07/2007 22:40:47: No Treble Support
20/07/2007 22:40:47: No Bass Support
20/07/2007 22:40:47: No Master ON/OFF
20/07/2007 22:40:47: Source: Wave=&H1008/1
20/07/2007 22:40:47: Source: SW Synth=&H1004/2
20/07/2007 22:40:47: Source: Front=&H100A/3
20/07/2007 22:40:47: No Mute for Source
20/07/2007 22:40:47: Source: Subwoofer=&H100A/4
20/07/2007 22:40:47: Source: Center=&H100A/5
20/07/2007 22:40:47: Source: Rear=&H100A/6
20/07/2007 22:40:47: Source: SPDIF=&H1001/7
20/07/2007 22:40:47: Can't Open Source
20/07/2007 22:40:47: Source: Aux=&H100A/8
20/07/2007 22:40:47: Source: CD Player=&H1005/9
20/07/2007 22:40:47: Source: Line In=&H1002/10
20/07/2007 22:40:47: Source: Microphone=&H1003/11
20/07/2007 22:40:47: Source: Phone Line=&H1006/12
20/07/2007 22:40:47: Source: PC Speaker=&H100A/13
20/07/2007 22:40:47: ERROR loading image file(s) for: menu.skin
20/07/2007 22:40:47: SDK command: REQUEST;MotionLock;RRPATH
Lez.
Old 07-21-2007, 08:36 AM   #5
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
Ok deleted the whole lot, downloaded the installer as linked on post 1 in the RR thread, on the install screen it has a link for winamp to:
http://rrdownloads.net/winamp295.exe
which seems duff.
RR_updater.exe fails and whines about variables (subscript used with non array variable)
And its still not working..........
Lez.
Old 07-21-2007, 09:12 AM   #6
2k1Toaster's Avatar
My Photos: (1)
This one?
http://www.mp3car.com/vbulletin/road...r-updater.html
Old 07-21-2007, 09:39 AM   #7
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
yup, that one, the installer, when it stops to tell you to download the right winamp, if you click on the link...............
Oh and if I drop the updater from updater.zip into my RR directory, it says (Your Version is: 2007/04/12) , then update available, and then download failed...
{edit}
Ok now have /latest/ RR version, and updater say I'm upto date
BUT........... It still wont damn start and just ''stops responding''
No useful errors in debug.txt, its about as much use a windows 98 core dump, which is just annoying at a programming level.........
A debug output should do just that, tell you whats gone wrong!
Lez.
Old 07-22-2007, 10:29 AM   #8
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
Come on someone else must have had this problem !
Grief if I dont find a way to start it soon I may go back to FP !
Lez.
Old 07-22-2007, 11:56 AM   #9
blk02si's CarPC Specs
blk02si's Avatar
Vehicle: '06 Triple Black Mustang
My Photos: (0)
I usually just skip the installer and DL the binary. It gives you much more control on how things are set up. RR installers are a 'one size fits all' attempt to set your directory paths for installation. Best bet, download the binary, read all the txt files and run rrconfig.exe from the binary folder when your ready to setup RR.
Make sure you have a valid skin installed and RR knows where to look for it (set in rrconfig.exe)
My carPC - www.shocknet.us
blk02si is offline   Reply With Quote
Old 07-23-2007, 05:12 PM   #10
Raw Wave
Gobby's CarPC Specs
Vehicle: Pug 306 XSi
My Photos: (0)
Try starting with the standard BMV2 Skin.
Those are the two lines stopping RR from running.
Gobby is offline   Reply With Quote
Sponsored Links
Old 07-23-2007, 06:21 PM   #11
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
been their done that.........
I thougt bmv2 had a problem so downloaded another skin, wont work with bmv2, wont work with alpine, wont work.
got this now....
24/07/2007 00:22:14: Source: Microphone=&H1003/11
24/07/2007 00:22:14: Source: Phone Line=&H1006/12
24/07/2007 00:22:14: Source: PC Speaker=&H100A/13
24/07/2007 00:22:14: Winamp window not found.
24/07/2007 00:22:15: Shell: "C:\Program Files\Winamp\winamp.exe" /CLASS="Winamp v1.x"
24/07/2007 00:22:15: Winamp window not found.
24/07/2007 00:22:17: ERROR loading image file(s) for: menu.skin
Lez.
Old 07-23-2007, 06:56 PM   #12
blk02si's Avatar
My Photos: (0)
well menu.skin is the first menu RR looks for when launching its GUI. I would say you have a problem with the skin itself or the path to the skin. You will see an entry in RR.ini for the skin path. Make sure it has an absolute path to your skin correct.
example of the line in RR.ini
skinpath=C:\DEVEL\RoadRunnerBinary\skins\Shock v3.0\
Old 07-25-2007, 08:05 PM   #13
volum3rider's CarPC Specs
My Photos: (0)
It seems to be more of a winamp problem from what i can see from your previous debug. I would try doing a fresh install of winamp and another skin. Also make sure all your configurations in rrconfig are good.
volum3rider is offline   Reply With Quote
Old 07-26-2007, 03:25 AM   #14
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
The paths are correct in the rr.ini, its afresh install of RR, I have even done a fresh install of another skin and changed skin path to that, same problem.
I have used RR since about 2 years ago, I have had to install it a fair few times as I have upgraded MB and HD etc, so I'm used to setting it up.
I thought it may have been a winamp issue but winamp is starting.
I may have to put another machine together to test this out again, it cant be the install files as others would have the issue, its got to be the 'environment' of my XP and machine, but if something is wrong with my 'bigger picture' I should expect a message and for it to exit, not hang.
I dont think I will get to the bottom of this, I thikn it would need a fresh XP install, and I dont want to do that (yet) as it means installing all my other apps etc as well.
Lez.
Old 07-26-2007, 03:34 AM   #15
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
What should RR do if I clear the path to winamp and uninstall winamp, should it still start, or quit, or hang ?
I still get the same hang, but with a complaint in debug about winamp(as expected)
Oh and I changed to the idrive skin, I know thats worked for me in the past
Problem is it say cant load menu.skin, what or where should be menu.skin ?
26/07/2007 09:33:10: Source: Phone Line=&H1006/12
26/07/2007 09:33:10: Source: PC Speaker=&H100A/13
26/07/2007 09:33:11: Winamp window not found.
26/07/2007 09:33:11: Shell: "\winamp.exe" /CLASS="Winamp v1.x"
26/07/2007 09:33:11: Winamp executable not found.
26/07/2007 09:33:12: ERROR loading image file(s) for: menu.skin
Lez.
Sponsored Links
vB code is On
Trackbacks are Off
EniCar the RR Clone enitalp Software & Software Development 292 05-05-2008 05:28 AM
XMD RR Hibernation & XMRESET hank_kls65 Road Runner 17 10-25-2007 03:14 PM
Before I start a skin, can RR do this? wilsonj Road Runner 14 01-04-2006 07:23 PM
Generalized Perception of RR from a new user replicant Road Runner 2 11-15-2005 10:41 PM
RR doesn't start Phoco on initial load.. DutchBurner Road Runner 16 11-04-2005 01:17 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
