Volume problem with RR.
I don't quite understand how the volume is set by RR, but I get something strange on reboots.
First off, when I press the (+) volume button, the volume increases, and the volume % bar also moves to the right up until it reaches 100%, and the display doesn't change anymore, but with more presses of the (+) volume button, the volume continues to increase.
Is that normal?
And second, when I reboot the machine, and the music starts up again, the volume is the same as when the machine was shut down, but as soon as I push the (-) volume button the volume drops to almost zero.
This happens only once, the very first time the (-) volume button is pushed.
Is that normal?
What I don't understand is what does the (+) and (-) volume buttons control. Is it the Wave volume or the main volume control, beacuse it seems that I can set both the wave and main volume manually (windows volume control panel), and as soon as I push either the (-) or (+) buttons, both the main and wave sliders jump to a low setting.
I'm a little confused.
